First Mod: reAngle the Backup Camera
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jage, Feb 17, 2013.
  1. Feb 17, 2013 at 10:23 PM
    jage
    jage [OP] Well-Known Member
    Franktown CO
    '010 Silver Double Offroad Leather/Sunroof
    With the factory camera, half of everything I could see was the tailgate paint. Useless except the rare case of hooking up a trailer or trying to knock an apple off a pylon. I really want to be able to see what is behind me, not immediately at my bumper.
    So here is what I did:
    Start by taking the tailgate down.
    Remove the camera bracket (10mm).
    Remove the camera from bracket.
    Mark view area.
    Check new angle, note top half of screen is black.
    Perfect, we're done!
    Consider cutting up bracket.
    Decide to make new one instead.
    Bend and drill hole for fitting.
    More bends to utilize the original mounting bolts.
    Final bends.
    Placement
    Marked around camera. Had to estimate and mark with camera out, then place and adjust cut marks.
    Start with a pilot hole. Fail at cameraing.
    The plastic is so soft you can drill by hand (but don't because it will snap off!)
    Get out the dremmel to fix the broken plastic.
    Exactly as planned.
    Go back to brackets. Little L is a counter piece that turned out not to be necessary.
    Note the divot to help with placement. It doesn't.
    Installing. Again, counter L shown wasn't needed.
    Simulating a friend holding it in place to simulate the other bracket.
    Beef curtains.
    Trim number 3.
    Perfect, we're done! But just to be sure some markers.
    Perfect, except I love taking the camera out so, so much…
    Trim number 7. Some trims edited for time.
    Finally let's just make the second piece. This is the 2nd second piece, incidentially.
    Ignore the divot, note the washer added to vertically position.
    Installed.
    Perfe… ah, I'm not saying it.
    Looks factory.
    Nice field of view.
    How close?
    This close.
    How close?
    Close enough, we're done.
    Thanks for reading.
  2. Feb 18, 2013 at 4:05 AM
    scottw1
    scottw1 Well-Known Member
    Scott
    Norfolk, VA
    2010 SR5 Tacoma 4x4
    Lighted 4wd dial, Sirus XM radio
    Is the camera sealed up from weather? Looks like there are some gaps in the 6th pic from the bottom. Nice job overall.
    The only thing I don't like about this is that the backup camera should only be used when backing up and stopping close to another car or object; IMHO. It shouldn't be used as a wide angle shot; this leads to people looking at the camera and nothing else. I.e. my wife looks at the camera and tends not to put her head on a swivel when backing up. You can guess what this has caused.
  3. Feb 19, 2013 at 8:53 AM
    jage
    Franktown CO
    It's not sealed and I haven't figured out exactly what to put in the gap yet.
    As for the camera being on, I'm a strong proponent of "all the time", when I put it in D I want to see how far I pull up away from something, or how I'm aligning as I move forward. Suddenly blinding part of my overall view is just stupid.
    I put a camera in my van that I use as a full time rear view mirror and it's insanely helpful- whether merging on the interstate or watching a trailer load as I drive. I'm actually planning a second camera on the taco, one in a more useful position.
    That said, my wife immediately backed into our trailer after I installed the van camera, for the same reason you stated. But limiting the camera into uselessness doesn't address the real problem, the camera is no more or less of a tool than blind spot mirrors.
  4. Feb 20, 2013 at 10:10 AM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Well done! Nice writeup, good pics! Rep sent. :)
  5. Feb 20, 2013 at 10:21 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Nice job OP
  6. Feb 20, 2013 at 10:31 AM
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    A little lift and a little armor
    You didn't happen to notice what gauge wires are used for the camera did you?
  7. Feb 20, 2013 at 9:57 PM
    2006KJ
    2006KJ Well-Known Member
    Front Royal VA
    well done sir! and great write up... the beef curtains snuck in there :D
  8. Feb 20, 2013 at 11:57 PM
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    What position would you mount the 2nd camera?
  9. Feb 21, 2013 at 6:01 AM
    jage
    Franktown CO
    Small, like 20g? It's in connectors at each end so it's hard to say exactly, but the OEM camera is only 6v so it can't take much.
    I was thinking around the 3rd brakelight, so I can watch bed loads and see well to the sides of the rear- thing is I will likely cobble something together on a long lead and test a bunch of positions (read: blue painters tape) before installing. I'd also like to find a less fish-eye camera than stock, most aftermarket cameras are 170º and the taco cam seems like more.
  10. May 13, 2013 at 11:23 AM
    clcoyle
    clcoyle Well-Known Member
    Well done.
  11. May 13, 2013 at 11:40 AM
    Okeetee
    Okeetee I like the Anaheim Ducks
    Kyle
    Huntington Beach, CA
    '11 MGM TRD Sport DCSB 4x4
    OME 887 coil springs, Bilstein 5100s (front/rear), Light Racing UCAs, Wheeler's HD 1.5" AAL, 18x9 Pro Comp series 7032, Toyo Open Country A/T II (LT285/65R18)
    Nicely done. The expanded view from the backup camera looks great.
  12. May 13, 2013 at 1:08 PM
    majorhavok
    majorhavok Rabid Conservative
    Mike in Cali..
    Peoples Republic of Caulifournia
    '13 TRD Sport DoubleCab 4x4
    Ultragauge, ImMrYo mirror, Tailgate lock, Snugtop Rebel Shell.
    I'm not sure which was better... the simulated friend simulating the simulated bracket, or the through beef curtain view. LMAO.
  13. May 13, 2013 at 1:49 PM
    JayAre
    JayAre Well-Known Member
    OR
    13 TRD Sport DCLB
    Any pics of a boat or trailer in tow? My backup camera was much less usefull for backing down my boat then I expected. I was thinking about doing this too.
  14. May 13, 2013 at 2:21 PM
    littleblue81
    littleblue81 Well-Known Member
    Why would the camera be useful for backing down the boat? Do you just see the hull?
    The advantage of having the camera is seeing how close you are to a bumper/object when parking/backing up and also landing the ball right under the trailer receiver on the first shot. Backing up the boat should be down with side mirror and looking out the back window imo.
    Nevertheless, cool mod.
  15. May 13, 2013 at 9:24 PM
    JayAre
    OR
    13 TRD Sport DCLB
    all I see is the very front of the boat, can't tell the angle...I have a very steep driveway and I also have to back it in at a sharp angle then turn back sharply to get it straight into my garage. The boat disappears at a certain point doing this, so I can't see if I'm going straight in. It's a pain in the ass lol. There's also some really steep short boat ramps where I'm at. My boat's a short, flat bass boat. I figure the angle of the camera probably won't do much though. Another camera at the top of my shell seems like it would be better for that...and possibly side mirror extensions.
  16. Sep 24, 2017 at 7:32 AM
    2Toyotas
    2Toyotas Well-Known Member
    Ken
    Western NC
    '13 Taco SR5 AC
    (Old thread alert)
    Where did the photos go?
