First Oil Change 2011 Tacoma - Engine Oil, how much is to much? See photo
Discussion in '4 Cylinder' started by litegide24, Sep 19, 2011.
  1. Sep 19, 2011 at 6:16 PM
    litegide24
    litegide24 [OP] Well-Known Member
    I took my truck to the dealer about a week ago to get the oil changed for 1st time. It had just over 5,000 miles. After some guidance they finally understood this was written in the toyota care booklet as an exception ("the 2011 2.7's are to be scheduled every 5k miles and synthetic oil is to be used").
    The dealer receipt says:
    5,000 MILE SYNTHETIC VEHICLE SERVICE- COMP MAINT
    05KSYN COMP MAINT 27CPTCM0.50
    1 90975-YZZG1 FILTER S/A, OIL
    5 00279-OWQTE -01 OW20-SINGLE QUART (W
    TACOMA 4CYL OIL CHANGE AT 5K WITH TOYOTA SYNTHETIC 102R 4 CYL MAINT WITH OIL CHANGE AT 5K 27 ISP 0.00
  2. Sep 19, 2011 at 6:21 PM
    Superx2
    Superx2 Well-Known Member
    Joey
    Iowa
    chill out dude, when i purchased my neww 11' i was told to bring it in at 5,000 miles. i was like WHAT!! :eek: but then i got something in the mail that wrote something about 10,000 miles. anyway, think of if as the dealership is the one who thinks they are right. you have warrenty right? i would just listen to them. but i did get my oil change at 5,000 mioes. i wouldnt worry too much man.
  3. Sep 19, 2011 at 6:30 PM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    Too much oil is bad, The crankshaft will splash into the oil whiping it into a frothy mix.
    If it was me I would drain it into a clean drain pan and see how much was in there.
    Measure out the correct amount called for in the manual and pour it in Note W/O filter amount not with filter change amount.
    Do your own changes in the future if it is possible to avoid this dealer if they did in fact put too much in.
    Good luck.
  4. Sep 19, 2011 at 6:40 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    Yea, too much oil is not good for the motor. I would take it back to the dealer and explain what happened...see what they say.
    This is why I do all my own maintenance BTW.
  5. Sep 19, 2011 at 7:09 PM
    gt4som
    gt4som Active Member
    Nelson
    Tampa, FL
    They definitely over filled it. I was at the dealer about a week ago to get my 5k service done. I also have a 2.7 DC. The service manager told me it was at 10k, I told him I couldn't believe it but ended up taking his word. That was on a Friday.
    I get a call from the service manager on Monday, he told me there was an "update" and indeed my oil change should have been done on Friday. I was really pissed off. Made him change it when they were closed. I even received a survey from the dealer, they got all negative remarks and I even wrote them an essay on how incompetent their service department was.
    I normally do all the maintenance on all my vehicles. 2 year Toyota care is included on the truck so I will take advantage of it.
    I should really check my fill level now that I see your picture. I'm actually going to see it now. Will report back. If it's overfilled I'm going in early tomorrow to bitch them out some more. :eek:
  6. Sep 19, 2011 at 7:10 PM
    easyeatlanta
    easyeatlanta Artificial Intelligence beats natural stupidity
    Eric
    Memphis
    14 DC Trd Off Road
    did you pull the dipstick out then wipe it off then measure the oil?
  7. Sep 19, 2011 at 7:24 PM
    gt4som
    Nelson
    Tampa, FL
    Just checked. It looked OK... Thankfully. Can't wait till the 10k service /sarcasm...
  8. Sep 19, 2011 at 7:38 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    Did you flip over the stick and check the other side? On some vehicles it will look way over filled on one side and spot on on the other side. I work in the used car dept at a dealership and change oil on a lot of different cars and trucks and see that a a lot. Sometimes I see what you are seeing and am like WTF and then I check the other side of the dipstick and realize it's all ok. Worth a look anyway before you go back and complain.
  9. Sep 19, 2011 at 8:54 PM
    FOUR X FOUR DUDE.
    FOUR X FOUR DUDE. Well-Known Member
    Barry
    Mountain Center, Ca.
    Tacoma 4x4
    TRD wheels, BFG tires, factory installed option.
    I just changed mine myself (first change, 970 mi) Don't want to go 5 k till first change. 6 qts plus filter, perfect on the dipstick. However, I also lubed it and each gerk took 5 pulls on the gun handle, which irritated me. Seems it left the factory under lubed. I think you are overfilled, shouldn't be that high on the stick. Also, your pic of the work order, says 5 qts of something and then 1 qt of OW 20. What's up with that ?
    My packett originally said conventional oil then was replaced with a syn packett. (2.7)
  10. Sep 19, 2011 at 8:57 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I'd drain it asap...looks like they over filled.
  11. Sep 20, 2011 at 2:45 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    I use 5.5 qts when I fill.
  12. Sep 20, 2011 at 3:34 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    3,000 miles at my first change... and under 5,000 for each one there after... usually close to 4,000 miles.
  13. Sep 20, 2011 at 4:27 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    holy shit that is way too much! they are only supposed to take 5 quarts
  14. Sep 20, 2011 at 7:48 PM
    Ivan
    Ivan Well-Known Member
    Ivan
    Western Mass
    06 Tacoma, 4x4 + SR5
    Definitely, otherwise you get some stupid tech that'll top it off too much or to litte
  15. Sep 21, 2011 at 4:42 AM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    With my first oil change I put 6.1 quarts into the crank and the dipstick looked exactly like the OP's. I ended up draining almost a quart back out before I felt comfortable with the level. A few days later I was picking up some maintenance items at the local dealer and happened to ask the shop foreman which was correct, the owner's manual or the dipstick? He said that he usually puts 5.5 quarts in the 2.7L, so that's what I've been doing ever since. It usually puts the oil level about 1/2 inch above full mark on the dipstick. It's weird that 1/2 to 3/4 quarts makes such a difference on the dipstick.
    It's better to be slightly underfilled than overfilled. Overfilling can cause the frothing problem mentioned earlier and starve bearings. It can also clog up your catalytic converter, causing backpressure issues in addition to the cost of a new cat.
  16. Sep 21, 2011 at 7:49 AM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    6.1 QTS. is for a completely dry motor. 5-5.5 QTS. is plenty for a normal oil change.
  17. Sep 21, 2011 at 10:18 PM
    NelsonTacoma
    Tucson, AZ
    Glad I could finally give some good advice to someone. :) Keep us updated on your 2nd check. But I'm sure it's ok :thumbsup: . And by looking at your picture that you posted, I wouldn't worry about being over the top dot by that amount.
  18. Sep 22, 2011 at 6:07 AM
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    That is how mine looks when I use 5 1/3 quarts. As Andrew said and what I have been saying for 2 years now is that the 6.1 qt number is for a dry fill. On a DOHC engine with the fancy VVT-i there is a lot of oil left in the heads.
  19. Sep 23, 2011 at 5:54 AM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    6.1 Qts. is for a brand new motor being assembled. You really only need to fill 5 or 5.5 Qts. for an oil change because there is no way you're going to get all the oil out without disassembling the motor.
  20. Sep 24, 2011 at 6:26 PM
    91r100gs
    Dan
    Kansas City area
    Gelo760
    Prove us wrong. Next time you change oil if you are a DIY type, collect the used oil and measure it. Your filter will have about 1/3 qt in it. Add the two and let us know. Then we can finally settle this issue that has many threads. I'm assuming your current fill is a 6 quart change.
