First Oil Change 2011 Tacoma - Engine Oil, how much is to much? See photo
Discussion in '4 Cylinder' started by litegide24, Sep 19, 2011.
  1. Mar 6, 2012 at 6:33 AM
    #41
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    Put in 5.5 qts of Mobil 1 0w-20 last fill and it is about 1/4" above the full mark 2000 miles later. But I do drain my oil parked slighty uphill and on ramps. Maybe this makes a difference.
  2. Mar 6, 2012 at 8:56 AM
    #42
    hotrod45
    hotrod45 Well-Known Member
    paul
    sarasota fl
    16 sr 5 access cab
    rich, don't argue with an idiot. he'll bring you down to his level and win with experience.
  3. Mar 6, 2012 at 5:37 PM
    #43
    91r100gs
    Dan
    Kansas City area
    Gelo most likely does everything by the book. Either the dipstick has been wrong for 8 years, or the book is wrong. If you fill it to the upper mark and it blows because of being a half qt low its Toyota's problem, because I wont buy another one.
  4. Mar 6, 2012 at 6:02 PM
    #44
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Yup.
    And while vehicles have been marketed (and subsequently recalled) with inaccurate dipsticks, it is far more common for something to be lost in the "translation" from metric to Imperial/US when the manuals are translated from Japanese to English.
    I've got a shop manual for my Kawasaki Vulcan 1600 that lists 56ft/lbs for the fork pinch bolts. They are 6mm fasteners.
    The Newton/Meter spec is correct, but in the translation, they indicated ft/lbs when it should have been 56 INCH/pounds!
    I've found a few places where that was done, so if a spec doesn't sound right for a fastener, I go with the metric spec.
  5. Mar 6, 2012 at 8:57 PM
    #45
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    6.1 Qts. is for a completely dry motor. Obviously you cannot drain every last drop of oil from the motor when doing a standard oil change. This is where the difference is. End of discussion.
  6. Mar 7, 2012 at 2:35 PM
    #46
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    It truly does not matter where the dipstick reads....put in 5-6 qts. of oil and you're good to go. 6.1 qts will fill a completely dry motor...5.5 qts. is plenty for a standard oil change.
  7. Mar 7, 2012 at 4:56 PM
    #47
    91r100gs
    Dan
    Kansas City area
    They just might to make sure a motor does not run low by 5K, if a engine should use some oil during breakin. Not every engine is perfect.
  8. Mar 22, 2012 at 9:54 AM
    #48
    alexander323bc
    alexander323bc Well-Known Member
    Eric
    Buffalo New York
    4cyl access cab
    Is everyone here pretty much using mobile? And for the warmer weather what weight?
  9. Mar 22, 2012 at 1:41 PM
    #49
    91r100gs
    Dan
    Kansas City area
    I have Mobil 1 in my Taco. It is the 0w-20 AFE. It runs good and I think it does help with fuel mileage a bit, .5 to 1 MPG would be my guess.
    I have run other oils. As long as they are SN/GF-5 rated, and changed every 5-10K your engine will last much longer than the rest of the truck.
    3 out of the my next 4 changes are going to be Valvoline Conventional 5w-20. Picked up 16 qt for $21.50 on Amazon about a year ago. It will get changed every 5K along with a medium grade filter. I have another fill of the Mobil 1 but I'll save it for a winter oil change.
  10. Mar 22, 2012 at 7:23 PM
    #50
    Rich91710
    Rich
    Los Angeles
    08 Base
    Mobil-1, 5w30 here in SoCal (temps range from no lower than 35 to as high as 120).
  11. Mar 23, 2012 at 4:59 AM
    #51
    scgunslinger
    scgunslinger Well-Known Member
    SC
    11 taco 4x4 2.7 man trans
    bone stock
    I have five free oil change cupons and a 36000 mile warranty for free if anyone knows how to use them. I voided the warranty at first oil change I used a fram oil filter and not toyota parts from the stealership. I dont want a 18 year old kid learing how to change oil on my truck. Guess who they always put on the grease monkey rack. Avoid the stealership and warranties at all cost. I tried to sell them my warranty when I bought the truck new for 100.00 they refused so I gave it to em. Guess you can tell i hate car dealers and warranties.
  12. Mar 23, 2012 at 5:05 AM
    #52
    Rich91710
    Rich
    Los Angeles
    08 Base
    You did not void your factory warranty by doing the work yourself.
    That is a violation of Magnusson-Moss, and if the dealer told you that, get it on a recording and take it to your state Attorney General.
    The law says that if the manufacturer requires factory parts and dealer labor, those things must be provided at no charge.
    Your oil change coupons were not "free"... you paid for them in the price of the truck.
    You CAN void an extended warranty. Those should not even be called "warranties" because they are actually service contracts. Depending on what's in the fine print, they can require anything.
    IF you have an extended warranty, the dealership may be legally obligated to buy-back the unused portion. Depending on the value, it may or may not be worth contacting an attorney... but it's always worth it to threaten.
