First oil change isn't going well
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bigbastian, Apr 30, 2023.
  1. Apr 30, 2023 at 10:23 AM
    Bigbastian
    Bigbastian [OP] Member
    2021 Army Green TRD OR
    Wheels, lift, tires, bars
    This is probably hoing to be too long but I am losing my mind.
    So, this is the first time I've self performed an oil change on my Tacoma. I've done oil changes on my other vehicles for years.
    I watched a couple videos on YT leading up to the procedure. Someone suggested replacing the oil filter cap with the aluminum equivalent. So, I did. My first fuck up was I forgot to change the crush washer untile after I had put the plug back in and filled with oil. No big deal, I will wait til the next change and take care of it then.
    Went to Home depot, came home, oil was dripping on the ground. What the fuck. Started taking everything apart. Realized I had also forgot to replace the rubber seal that goes on the outside of the oil filter cap and the little cap that you screw off first. Great, wiped everything off, installed o-ring, drove it around a couple days, started noticing oil on the ground. What the fuck.
    So, I did what any sane person would do, I bought all the supplies to perform the oil change a second time. Someone had gofted me a magbetic GReddy oil drain plug so I had another part to install. Fuck it. $50 lesson.
    Yesterday, took everything apart and inspected the aluminum oil filter cap and compared it to the original, plastic part. Sure enough, there is a small difference in the parts (see second photo) there is a notch on the aluminum part where there is no such notch in the plastic part. So, decided to reinstall the original plastic oil filter cap and return the aluminum one. I thought for sure, this notch is qhy oil continues to drip. So, went about the rest of the oil change. Pulled the old crush washer off put new washer and GReddy plug on. Everything screwed on smoothly, Im always worries I will cross thread something but, all good. Filled with oil and patted myself on the back for doing it right even though it cost me $50 in supplies.
    Well, drove around this morning. Decided to look underneath and sure enough. Oil dripping around the drain plug and collected on one other low spot on the truck. Gave the drain plug another 1/4 turn and wiped everything down
    Now, Im just really confused. Is it possible that its just residual oil still accumulating from the first fuck up? Idk. This truck is maling me feel like an idiot today.
  2. Apr 30, 2023 at 10:34 AM
    jego
    jego Well-Known Member
    2020 TRD Off Road DCSB
    Could you have gotten oil on your skid plates and it is still dripping down?
    RIX TUX likes this.
  3. Apr 30, 2023 at 10:40 AM
    Halloween
    Halloween Well-Known Member
    Toyotas a plenty
    I just remove my trd skid plate so I can visually see everything. Like Jego said it could be spilled oil running off. Sounds like you did everything right. Sometimes the easiest jobs end up being headaches.
    Kolohe07 likes this.
  4. Apr 30, 2023 at 10:50 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Get rid of all the bullshit everyone said you needed. Go to STOCK.
    You need oil, washer, oring.
    Problem is you are trying to improve on a process a high school kid can do in his sleep.
    Kolohe07, BRBNNEAT, joeyv141 and 9 others like this.
  5. Apr 30, 2023 at 10:51 AM
    Blak Shinobi
    Blak Shinobi Well-Known Member
    taco
    2020 MGM Sport DCSB 4x4
    n/a
    well atleast you changed your oiled yourself, dont be like the the guys in the 2nd gen section where they dont believe in transmission fluid change lol
    Dfpftw and cryptolime like this.
  6. Apr 30, 2023 at 10:53 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    I know a few people that installed the alloy cups and had issues.
    Would think the residual oil may be from driving and coating components. Now it’s just collecting at the low points
    Dfpftw likes this.
  7. Apr 30, 2023 at 10:54 AM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    maybe im not a sane person but i wouldnt have done a second oil change. I also have an alloy oil filter housing that i havent had issues with.
    Lt. Dangle and Bigbastian[OP] like this.
  8. Apr 30, 2023 at 10:55 AM
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    I must admit, I’ve never changed an oil plug crush ring, I’ve never had a plug leak.
    I have moved to Fumoto valves and love them
    gsubioguy, Dfpftw, monoman and 3 others like this.
  9. Apr 30, 2023 at 10:57 AM
    auskip07
    Skip
    Atlanta, Ga
    same, when i did it without a fumoto i never had an issue for 10's of thousands of miles
  10. Apr 30, 2023 at 10:57 AM
    19992021Taco
    19992021Taco Well-Known Member
    1999 and 2021 Tacoma
    Shit happens, Did you lube the o-ring on the second install?
    Did you remove the skid plate and clean after the first mishap?
    Al least you didn't forget to put the oil in! :)
    Dfpftw and faawrenchbndr like this.
  11. Apr 30, 2023 at 11:38 AM
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    I got distracted once when changing oil in the FJ. I’ll admit, a few, like maybe five or was it nine Coronas were involved as well,…..but…
    I forgot yo reinstall the drain plug. Dumped the new in. It ended up in the drain pan.
    I wrote this off as “an oil pan flush and drain”
  12. Apr 30, 2023 at 11:46 AM
    Bigbastian
    I wasnt being serious when I said "sane". I just wanted to start over from the beginning.
  13. Apr 30, 2023 at 11:47 AM
    Bigbastian
    Yep, lube orings, dropped the skid plate. Wiped down all the oil I saw. I think (hope) its just residual that is collecting in low spots.
  14. Apr 30, 2023 at 11:47 AM
    auskip07
    Skip
    Atlanta, Ga
    is it still leaking?
  15. Apr 30, 2023 at 11:48 AM
    Bigbastian
    Hahaha, thanks for making me feel better! This is great!
    Dfpftw likes this.
  16. Apr 30, 2023 at 11:49 AM
    Bigbastian
    Not actively leaking from what I can tell. Gonna checknit the next couple days to see if there are any more leaks.
  17. Apr 30, 2023 at 11:50 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    What groove did you put the large O-ring into?
    bulalo likes this.
  18. Apr 30, 2023 at 11:51 AM
    Bigbastian
    Yea, I think its just residual from the original fuck up...
  19. Apr 30, 2023 at 11:52 AM
    Bigbastian
    Ah yes, the infamous fumoto valve!
  20. Apr 30, 2023 at 11:55 AM
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    They really are a plus…..IMO. Topic is about as despised as MPG and the Gashole
    Gave you found any residual under the plate again? Has it stopped? Might wash it out
    gsubioguy likes this.
