First oil change on my 2021 TRD Sport...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gc9773, Apr 10, 2021.
  1. Apr 11, 2021 at 9:45 AM
    Chaosh1
    Chaosh1 Well-Known Member
    2021 Tacoma TRD Pro
    I'm sure it's just me, but I had a friend that went to one of those places. Left with a loose drain plug. He caught it the next morning in his driveway. Secured it and that was the end of it.
    Up until then I used to always use the valvoline places.
    And yes sir! My daughter will need to be able to change oil and tires before she is allowed to drive the car. So we have some time
    shakerhood and ugawino[QUOTED] like this.
  2. Apr 11, 2021 at 9:54 AM
    bgio67
    bgio67 Well-Known Member
    2020 TRD OffRoad DCSB
    I put on the TRD skid and as other have said oil changes are pretty easy and quick. I also found if I use a glass bottle (beer/soda) the plastic oil filter drain piece fits perfect and it is also rigid that the piece clicks right into the housing without leaking oil down your arm.
  3. Apr 11, 2021 at 10:03 AM
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    I did my oil change around 5000 miles too. I actually did send a sample to blackstone labs. They said the oil was all good but had high metals in it and that this was normal for a new engine. Nothing to worry about as long it's changed regularly.
    Some tools I got just for the job were the motiveX cap wrench from Amazon and a 27mm socket to turn it with. I did get a cheap screw in plastic drain hose for the filter drain but that proved pretty much worthless. I'd use the plastic tool that comes with the new filter and a piece of hose from Lowes on that or an empty 20 ounce soda bottle next time.
    As for the filter well it's not as bad as some say. Just be careful about getting the o-ring in the correct place and don't over tighen. I did buy the aluminum filter housing but didn't put it on. Just going to keep it on a self until needed.
  4. Apr 11, 2021 at 10:09 AM
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    https://www.tacomaworld.com/threads/steel-skid-plate-options-with-oil-filter-access.508054/
    The Toyota one is marked up, you can get an aftermarket cheaper. Though to be fair now that I've looked around quickly, not as much cheaper as I expected to see!
    Keep an eye on classified section here.
    I have a TRD OR 2020, the stock skid plate is useless as a skid plate, first of all. Second of all, they nascar whipped the bolts and stripped one of the mounting points, and then long term the nut that's welded on the back of it broke off from the cross beam. Went with an aftermarket anyway, so I didn't care, but a pain in the arse.
  5. Apr 11, 2021 at 10:29 AM
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    Seizing up, having to go to great lengths to remove it, for the most part.
  6. Apr 11, 2021 at 10:36 AM
    RatDaddy
    RatDaddy Well-Known Member
    Roy
    2017 Tacoma TRD O/R Premium pkg
    None
    The first oil change should always be sooner than later, so I have always done those on every car, at 5k. After that and because I have always used mobil 1 synthetic oil, I only change the oil every 7500 to 10k on every car. Of course that all depends on the type of use. Synthetic oils do not degrade on normal engine use and I have drained mobil 1 at 10k miles and it did not look much different than when I put it in.
  7. Apr 11, 2021 at 10:45 AM
    ugawino
    ugawino Well-Known Member
    Bill
    Paola, KS
    2021 TRD Off-Road, Silver Sky Metallic
    Mods? We don't need no stinking mods.
    I think that happened to my dad once, too. I know it happens. But it has to be a rare occurrence or those places would be out of business now.
    And I made sure all my kids knew how to change a flat before I let them drive, too. That's just a good life skill to know.
  8. Apr 11, 2021 at 10:46 AM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    I’ve seen plenty of other complaints about overall ease of use with the aluminum ones. After doing 13 oil changes on my ‘16 with 65k I have had zero issues with the plastic housing.
    Kevin Jones[QUOTED] likes this.
  9. Apr 11, 2021 at 4:22 PM
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
    Sounds like you cross threaded it. I don't see any way it would seize if used correctly.
    Taco_mike73 likes this.
  10. Mar 26, 2022 at 2:41 PM
    Ranamow
    Ranamow New Member
    Randy
    2021 Tacoma TRD sport double cab Long box - Cement
    Redarc Tow-Pro Elite in dash Trailer Brake Controller, Redline tuning hood srtuts, Toyota tonneau cover, black tailgate letters, center console tray, glovebox organizer.
    Hi everyone I'm a newbie here. I have a 21 TRD sport. My biggest complaint changing the oil is reading the dipstick! Even the service manager at the dealership can't seem to figure it out. Other than that, it's an oil change.
    Canadian Caber likes this.
  11. Mar 26, 2022 at 3:21 PM
    WinterFalco
    WinterFalco Well-Known Member
    Donald
    2018 Midnight Black SR 4x4 Double Cab
    Added aftermarket Rims and Tires, Fog Lights, Mudflaps, Entune with Nav
    I agree, I have been using the aluminum housing since 20K miles and I am at 50K and never had an issue. I just put it on my hand, tighten by hand and then torque to specs (18 ft/lbs).
  12. Mar 26, 2022 at 3:28 PM
    malatx
    malatx Well-Known Member
    2022 TRDOR DCLB Army Green
    I've tried sandpaper the dipstick, still pretty hard to read, so I decided to try the blue shop towel method, oil doesn't travel fast on the paper towel so after inserting into the tube you carefully fold the paper towel over the dipstick on 2 sides, one side will be always covered in oil, and the other side will have a shorter oil absorption area that corresponds to the oil sump level, measure the oil on paper and compare that length to the dipstick you get the good reading that way
    WinterFalco likes this.
  13. Mar 26, 2022 at 3:50 PM
    RatDaddy
    Roy
    None
    Change dealerships. My advice.
    shakerhood likes this.
  14. Mar 26, 2022 at 4:27 PM
    Taco X
    Taco X Man of almost frightening genius
    James
    Midwest and Southwest
    2022 SR 4x4 V6
    lift, 255/85r16, 5.29 gears
    I've read this a few times. Since I don't have my truck, I haven't done an oil change, but older members of my family always said to fill the oil filter with oil before installing it. That's because after changing oil, a lot of the engine isn't lubricated properly until the oil is pumped through the filter and around. They taught me to turn over the engine as well without actually starting it, so the oil would pump.
    So unless technologies change or the old dogs in my family mislead me, having an oil filter on top or at an angle is worse, especially if you have a push start button rather than a key you can manual crank
  15. Mar 26, 2022 at 4:39 PM
    #35
    NorrinRadd
    NorrinRadd Well-Known Member
    WA
    2019 Sport, access cab, MT, Eibach 2.0 stage 2, tow, silver.
    Thought Toyota gives you two years of free service, which includes 2 "inspections" and 2 oil changes. My dealer told me I could use them whenever I wanted within the two years...
  16. Mar 26, 2022 at 8:04 PM
    #36
    Spacecoast
    Spacecoast Well-Known Member
    2022 White SR5 2.7L
    Trailer wiring kit, hitch, seat risers
    That's correct. Both of our vehicles will be low mileage....so I had my oil changed in the Highlander at the 12 month mark...along with the tire rotation.
  17. Mar 26, 2022 at 8:11 PM
    #37
    Spacecoast
    2022 White SR5 2.7L
    I've been changing oil in cars/trucks now for over 50 years and yes always pre-fill the filter....even if it is mounted horizontally. But since I haven't dealt with a cartridge type filter I'm not 100% sure that can be done, but I will give it a try sometime soon when I change the oil in my Highlander. I've got the 2.7L in the Tacoma which uses a spin on filter. Do not play around with trying to spin the engine without starting....it doesn't make any difference...and if you pre-fill the filter then there is no reason to not start it.
  18. Mar 26, 2022 at 9:36 PM
    #38
    Taco X
    James
    2022 SR 4x4 V6
    Post if you can do it. I'll try too if/when I get my truck.
    I'm not a mechanic but I think the idea (especially when you can't pre fill the filter) to crank the engine without starting it is that the oil pump is driven off the crank shaft, so theoretically the oil will start to pump
  19. Mar 26, 2022 at 9:46 PM
    #39
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Prefilling is a diesel thing. There's absolutely no harm in mounting a dry filter on most gasoline engines.
    Why would Toyota mount my 4.0 filter upside down if they were worried about it draining?
    malatx likes this.
  20. Mar 27, 2022 at 4:59 AM
    #40
    Ryeguy
    Ryeguy Well-Known Member
    43* North
    2021 TRD Off Road 4X4 Blackout
    OEM Bed Extension, Bed Mat, Lomax Bed Cover, Auto lock tailgate (OEM)
    FWIW, I just changed my oil / filter on my 2021 V6. The vertically mounted canister makes it very easy to pre-fill the filter with fresh oil.
    The filter element mounts in the canister (just like a home water filter if you are familiar with those) and you can just pour a bit of oil into the filter at this time.
    As an aside, this was my first oil change with this truck. It took me about 45 minutes with the TRD Pro skid plate.
    Only hiccup being the realization I need a better oil catch pan as this oil is very thin and splashes out of the cheap Walmart pan I use now.
