First oil change on my 2023 Sport
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Wenty, Mar 21, 2023.
  1. Mar 21, 2023 at 3:54 PM
    Wenty
    Wenty [OP] Well-Known Member
    Minnesota
    2023 Tacoma Sport 4x4 V6
    Well it sprayed out of the oil pan onto the floor. :facepalm: Skid plate sucks but I managed and I cant read the damn long ass dip stick with new oil on it. :(
    Other then that I did my first oil change at 1500 miles on my new truck. :thumbsup:
    TnShooter and Blak Shinobi like this.
  2. Mar 21, 2023 at 3:56 PM
    Blak Shinobi
    Blak Shinobi Well-Known Member
    taco
    2020 MGM Sport DCSB 4x4
    n/a
    nice did you see any metal shavings?
    98_3RZ_NIC likes this.
  3. Mar 21, 2023 at 3:56 PM
    98_3RZ_NIC
    98_3RZ_NIC Well-Known Member
    1998 white extended cab
    Bilstein 5100’s with ome 881 coils on lowest setting, JBA upper control arms, LCE header, 31x10.5x15 falken wildpeaks.
    why’d you do that? Did your dealer specifically tell you that? My dealer said bring mine back in at 5k miles for tire rotation, fluid top off(if needed) and an inspection and back in at 10k miles for first oil change.
    Barsoom and kahanabob like this.
  4. Mar 21, 2023 at 3:58 PM
    Wenty
    Minnesota
    I looked a little in the filter and didn't see anything.
  5. Mar 21, 2023 at 4:00 PM
    Blak Shinobi
    taco
    n/a
    oh no here we go again, you can do as you as the manual says or get it done early, it wont hurt to get it done early maybe your wallet but thats it .
  6. Mar 21, 2023 at 4:01 PM
    twtaco$
    twtaco$ Well-Known Member
    Found like you I needed a bucket to catch oil instead of the normal catch pan. I blew out everywhere the first time. Lesson learned.
  7. Mar 21, 2023 at 4:01 PM
    Blak Shinobi
    taco
    n/a
    nice , i heard it doesnt get fully broken in after after 20k
  8. Mar 21, 2023 at 4:06 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I've done many of oil changes on Tacoma's. The 2nd gen makes a big mess as well. Changed the oil in my '21 today and despite my best measures still got oil on the floor draining the oil...
  9. Mar 21, 2023 at 4:19 PM
    98_3RZ_NIC
    If anything was wrong it should be covered under warranty anyways.
  10. Mar 21, 2023 at 4:45 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Never had a drop on the ground or garage floor changing oil on mine.
  11. Mar 21, 2023 at 4:51 PM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
  12. Mar 21, 2023 at 4:54 PM
    Hogleg918
    Hogleg918 Well-Known Member
    Oklahoma
    Ranger Raptor, sorry TW
    Are you trying to incite a riot?
  13. Mar 21, 2023 at 5:07 PM
    xp0nex
    xp0nex Taco Noob
    2022 MGM TRD Off-Road DCSB 4x4
    Take a bright light and shine it into the pan. You’ll see the shavings. Did mine at 200 miles and when the sunlight hit the pan you can see the glitters.
  14. Mar 21, 2023 at 5:08 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    The real reason why I run a fumoto valve: I can control the stream so that it doesn't ricochet like the piss after last call at the dive bar.
    Nice and neat, and the wife doesn't complain about the seat.
    essjay, Tacospike, 98_3RZ_NIC and 4 others like this.
  15. Mar 21, 2023 at 5:12 PM
    MGMDesertTaco
    Kind of like staring at a fire hose waiting for someone to turn on the hydrant.
    Tacospike likes this.
  16. Mar 21, 2023 at 5:13 PM
    na8rboy
    WI
    Dam straight, I am...
  17. Mar 21, 2023 at 5:16 PM
    Wenty
    Minnesota
    Thinking of getting one.
  18. Mar 21, 2023 at 5:21 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    once i brake it loose i use my finger and unscrew it and let it fall into the catch bucket and get it out when i am funneling it into old bleach bottles.
  19. Mar 21, 2023 at 5:23 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    photogr4x4 and Barsoom like this.
  20. Mar 21, 2023 at 5:24 PM
    RichochetRabbit
    Quite humble as well.
