First oil change on my 2023 Sport
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Wenty, Mar 21, 2023.
  1. Mar 22, 2023 at 5:52 AM
    #41
    redneck pilot
    redneck pilot Well-Known Member
    North Texas
    2023 SR TSS Off-Road 4x4
    Many of us believe it is more conducive to engine longevity to do a 1,000 mile break-in oil change, which I did with my Tacoma and the wife’s new 4Runner. I even change the oil every 5,000 miles thereafter.
    Yeah, I went there.
  2. Mar 22, 2023 at 6:03 AM
    #42
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    +1 on the 5K Oil Change Intervals.
    22Coma6MT and Delta09 like this.
  3. Mar 22, 2023 at 6:10 AM
    #43
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    I did my first oil change at 10K and have been doing 5K intervals since. I’ll report back if my truck implodes.
    PentictonTacoma4 and 98_3RZ_NIC like this.
  4. Mar 22, 2023 at 6:53 AM
    #44
    Pungo1
    Pungo1 Well-Known Member
    Mark
    Watch some Youtubes by "The Car Care Nut" (expert Toyota mechanic) and others on extended oil change intervals (OCI). You'll be changing your oil at most every 5,000 miles for the rest of your life. Doing the 10,000 mile crap "might" get you to the end of the warranty period with no troubles, but likely not much beyond that. At 100,000 miles, rings start sticking and other bad things start to happen like oil consumption when you use extended OCI's.
    22Coma6MT and redneck pilot like this.
  5. Mar 22, 2023 at 7:06 AM
    #45
    blackZEBRA
    blackZEBRA Well-Known Member
    California
    '23 TRD OR DCLB
    I do 10K on my 1st gen. I'm pretty sure its not rated for it but it currently has 350K.
    It has lived a long good life and is still my daily driver.
    zoo truck likes this.
  6. Mar 22, 2023 at 10:26 AM
    #46
    Benny22
    Benny22 Well-Known Member
    20Tacoma
    Because some folks need Prozac to calm their mind, and some need early maintenance. What ever works for you is the correct therapy.
  7. Mar 22, 2023 at 3:24 PM
    #47
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    That was popular back in the 60's when your pappy told you that stuff. They had dino oils, and the machining process wasn't anywhere near what we have now. It was a common practice to change out what was called a break in oil. Today these engines are already broken in by the time we get them, plus the machining tolerances are far more exact. They run a lot hotter, and cleaner, requiring synthetics with the latest additive packages. No longer do these oils get as contaminated from emission byproducts, or break down as yesteryears engine oils requiring those 3k-5k oil change's.
  8. Mar 22, 2023 at 3:29 PM
    #48
    zoo truck
    None
    Thats total horsechit if you use good quality synthetics. Yes using a cheap dino oil will turn todays engines into sludge engines by 100k miles if 10k oil changes are done.
  9. Mar 22, 2023 at 6:09 PM
    #49
    redneck pilot
    North Texas
    Your opinion is duly noted.
    Irons likes this.
  10. Mar 22, 2023 at 6:21 PM
    #50
    TacoDinner
    TacoDinner Well-Known Member
    I was about to install a Fumoto valve on my 3rd gen SR5 V6, but decided against it because the skid plate on my model doesn't cover the oil drain plug, so it would not be protected. That could be different on other models.
