First oil change smells like gas
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bluebros, Jun 18, 2023.
  1. Jun 19, 2023 at 5:53 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Anytime synthetic oil is used, it takes the rings longer to seat in which fuel will get passed into your oil. Sometimes I think changing out synthetic oil at 1k miles with new synthetic oil only prolongs the issue with ring seating where in the end you loose performance....this was shown to be true on our buddies engine dyno. Why they don't use a dino breakin oil for the first 500 miles or so beats me.
    Travlr likes this.
  2. Jun 19, 2023 at 6:04 AM
    goingplacesanddoingstuff
    goingplacesanddoingstuff Well-Known Member
    2019 TRD Off Road
    2.5” OME lift, Koenig Six Shooter wheels, 275/70r17 Nokian Outpost AT, CMC, Nitro 4.88s, Greenlane aluminum sliders, CBI aluminum skid, Greenlane aluminum front bumper, Out Gear Solutions HC rear bumper, Baja SAE fogs
  3. Jun 19, 2023 at 6:05 AM
    terryhutchinson
    terryhutchinson Well-Known Member
    Terry
    2023 Tacoma TRD Off Road
    I recently changed my new '23 at 1000 miles. Oil was black, like yours. I figured just break in oil and that it was capturing loads of particulates so it didn't concern me. I didn't smell fuel though . . . but then I wasn't sniffing it. Under warranty, personally I would just change it again at 4 or 5 k and see how it looks then. If there really is a problem it will only get worse and you will have less of an argument at the dealer.
    Travlr and TRDRed like this.
  4. Jun 19, 2023 at 6:09 AM
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    Just for data point sake. My oil at 1000
    Miles looked brand new… didn’t smell like
    Fuel either.
    everything else is speculation let us know what happens. But I would spend the $25 at Blackstone
    TRDRed likes this.
  5. Jun 19, 2023 at 6:17 AM
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
    Because they don't want to have to tell you that you need to change your oil in 500 miles. There's no way I would go 10,000 miles on the original oil but I agree that changing it too soon is not a good idea either.
    Vmax540 and TRDRed like this.
  6. Jun 19, 2023 at 6:19 AM
    GeauxTacoma
    GeauxTacoma Well-Known Member
    Maryland
    2022 TRD Sport DCSB Lunar Rock
    My oil at 6k miles still looks pretty clean FYI…
    TRDRed likes this.
  7. Jun 19, 2023 at 6:27 AM
    dangeroso
    dangeroso Just float along and fill your lungs
    Jon
    Dallas, TX
    2018 Tacoma TRD Sport 4x4
    This is my thought. Most of us probably did not do our own first oil change and therefore don't have a baseline for a normal first oil change. Why not change it again in 1000 miles and see what that looks like. I think you will get "It's normal" from your dealership regardless of whether it is or isn't.
    TRDRed likes this.
  8. Jun 19, 2023 at 6:43 AM
    GorgeRunner
    GorgeRunner Out There
    2005 PreRunner
    Install a Fumoto valve. After an oil change, drain a few ounces of oil at certain mileage intervals, have a look and compare to previous samples.
  9. Jun 19, 2023 at 6:45 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    If you have doubts that this is normal, take it in. Make them explain what’s going on and get it in writing, just in case something is actually wrong and it becomes an issue later.
    TRDRed and Bluebros[OP] like this.
  10. Jun 19, 2023 at 7:01 AM
    AM6217
    AM6217 Well-Known Member
    2021 SR-5 DCSB Silver metallic
    There is an amount of assembly lube that's going to be mixed in with the factory fill. My first change at 1000 miles was black. Each and everyone has been black. It's always been my thought that the oils doing its job by suspending particulates etc in the oil. The filter grabs the big stuff. So when you dump the oil, your dumping the dirt in the oil.
    joba27n, TRDRed and FL_TRD Sport like this.
  11. Jun 19, 2023 at 7:02 AM
    AM6217
    joba27n and TRDRed like this.
  12. Jun 19, 2023 at 7:30 AM
    Pickeledpigsfeet
    Pickeledpigsfeet Well-Known Member
    Foothills, CA
    How did you break the motor in? I have had 4 new Toyotas in recent years and every one gets broken in so as to give the best ring seal possible.
    cryptolime and faawrenchbndr like this.
  13. Jun 19, 2023 at 7:44 AM
    Firn
    Firn Well-Known Member
    White OR
    Personally I wouldn't worry just yet.
    That first oil fill is a weird one and could use different oil, could have different assembly lubes mixed in, could have a lot of things.
    I would run it another 3000 miles and see what it looks like. Oil is cheap so do a dump and fill, no need to change the filter. Or, get a thin hose and pull some out of the dipstick. Take a look at it then and maybe send another sample to Blackstone.
    No reason to suspect that your Toyota motor is going to have an issue. And frankly, if it's as serious as some folks here seem to want to believe that motor is going to pop itself anyways and you get a new one for free, and you don't want to try and save this motor in that case anyways.
  14. Jun 19, 2023 at 7:57 AM
    Lunar Squirrel
    Lunar Squirrel Well-Known Member
    24 TRDOR Hybrid SPF100-Octane
    Really good points here that range from normal to not, so I’ll refrain from weighing in on the technical side beyond noting that fuel smell and dirty oil by themselves aren’t necessarily red flags for a serious issue, even at 1000mi. Driving conditions can also be a variable.
    That said, it’s a long-term and considerable financial investment on your part, and it’s also under warranty, so why not have it checked out, for peace of mind. You’re the customer here, so make sure you’re 100% satisfied. And if it does unearth an issue, better to fix sooner than later.
    23MGM, AM6217 and TRDRed like this.
  15. Jun 19, 2023 at 8:00 AM
    #35
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    Hats off to you for having your A&P ticket and doing these, but using a GE turboprop or turbofan GA or commercial engine as a point of reference for this really isn't a fair comparison. A Lycoming piston engine probably yes. It does speak to your experience though.
    zoo truck and Firn like this.
  16. Jun 19, 2023 at 8:04 AM
    #36
    jjsinaz
    jjsinaz Well-Known Member
    Jim
    Sun City West, AZ
    2023 TRD Sport DCLB Ice Cap 4X4
    FL_TRD Sport likes this.
  17. Jun 19, 2023 at 9:22 AM
    #37
    Bluebros
    Bluebros [OP] Well-Known Member
    BucksB
    Lexington, KY
    2023 Tacoma Trail Edition
    I appreciate everyone's comments. Thank goodness we have this forum and such knowledgeable contributors.
    I reached out to the dealer and spoke with the service manager and the shop foreman, both were left scratching their heads. I've submitted a formal written description to which they are, "escalating to the top" (which means checking on TacomaWorld :D ) so we'll see what the dealership advises. I assume since any diagnostic work would be on their dime, they'll suggest I keep driving it... Which might actually be the solution.
    Thankful to have your input @joba27n and I am certainly not challenging your knowledge and experience but of all the threads I've read, I haven't seen anyone with black oil smelling like gas on such a new truck. Not to say it couldn't happen but it does seem to be rare. Of all the Youtube videos, I've never seen anyone complain about a similar circumstance on their new Tacoma but I have read a bunch of articles about how gas in your oil is bad and a sure tell sign that Satan is returning :devil:
    My oil filter was actually clean as a whistle. I was considering reusing it because it didn't even have a spec of dirt. The only reason I switched it out was the gas smell.
    Spike Strip, TRDRed and zoo truck like this.
  18. Jun 19, 2023 at 9:31 AM
    #38
    Bluebros
    BucksB
    Lexington, KY
    If I'm building engines all day, all week, all month, all year, all decades, I just find it odd that one would have a unique build or treatment. I mean, "Oops, I added some assembly lube to this engine but not the thousands of other engines I was working on" just feels very unlike Toyota.
    I mean, this oil wasn't a shade of black. It was black on black and a 9 out of 10 gas odor. Like you said, the oil was doing it's job and it was collecting soot or some kind of contaminant so that's good.
    TRDRed likes this.
  19. Jun 19, 2023 at 9:39 AM
    #39
    zoo truck
    None
    I will say that filter looks cleaner than the one I pulled last fall with 9k miles on it. I guess that what extra gasoline in your oil will do.
    TRDRed likes this.
  20. Jun 19, 2023 at 9:39 AM
    #40
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    There are 3 modes. Direct injection is used from the startup and throughout all rpm ranges(loads). The amount of fuel injected via DI is being determined by loads.. DI injection happens on the compression stroke.
    The ecu switches over to DI only when engine load >75%. So on the highway you can be in 3 different modes
    Junkhead and TRDRed like this.
