First oil change - unknown history
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jfly69, May 6, 2024.
  1. May 6, 2024 at 4:54 AM
    jfly69
    jfly69 [OP] Member
    Tacoma 2016 SR
    What up—— What do you think about an oil change for a new-to-me 2016 Tacoma SR 2.7? It has 83k on it and I don’t know the oil change history. I want to change it and get this maintenance item and other items “reset” for my ownership. For what it’s worth, the oil in it now looks clean when I pull the dipstick. Although the maintenance is unknown, the previous owner did care enough to get it in to the dealer and get the frame treated in time for the zka program extension…
    anyway - just swap the oil and filter and keep going at 5k/6 mo intervals?
    do quicker intervals?
    do some sort of treatment/flush?
    thanks
  2. May 6, 2024 at 5:01 AM
    Trail Limo
    Trail Limo Well-Known Member
    Don't overthink it. Just change the oil and do the regular intervals.
    If the oil looks clean the previous owner probably did an oil change pretty recently.
    soundman98, wilcam47, 45Frank and 3 others like this.
  3. May 6, 2024 at 5:42 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    If you bought it from a dealer, they should have done an oil change before they put it on the lot as part of the inspection process. Your carfax should have also listed it if they had it serviced at the dealer or a repair shop (the only reason I have my oil changed at the dealer).
    shakerhood likes this.
  4. May 6, 2024 at 5:56 AM
    jfly69
    jfly69 [OP] Member
    Tacoma 2016 SR
    Yeah I think the dealer changed it but they don’t have any records on the Toyota maintenance history site except for the frame treatment for the warranty/service bulletin k0d.
    hopefully they changed the fluids on time :fingerscrossed:
  5. May 6, 2024 at 6:05 AM
    lastcall190
    lastcall190 Well-Known Member
    NJ
    2023 Silver DCSB TRDOR
    50 bucks or so and 30 minutes for peace of mind? No brainer IMO
    Enjoy the new truck
    soundman98, BMH, Chew and 2 others like this.
  6. May 6, 2024 at 6:05 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    5/6k is great. I would change the diff oil, transmission too. Plugs in the V6 are due at 60k - idk about the 4banger but you could do those too.
    wilcam47 and kakwvu like this.
  7. May 6, 2024 at 6:06 AM
    Clearwater Bill
    Billy
    Largo Florida
    Create your own baseline and move on.
    If you were going to fret over past care you should have done that before purchase.
    0w20, 10k OCIs like the manual says, unless your use meets the severe duty criteria. Then use those guidelines.
    soundman98, RIX TUX and Chew like this.
  8. May 6, 2024 at 6:13 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Take the oil cap off and see what the inside of the engine looks like, if it's clean your good. If it's all black and sludgy looking it probably wasn't maintained very well.
    RIX TUX and 3JOH22A like this.
  9. May 6, 2024 at 6:13 AM
    SmoothTRD
    SmoothTRD Well-Known Member
    Change oil every 10k, whatever brand of synthetic on sale. Your engine will last far longer than you own the truck
  10. May 6, 2024 at 6:20 AM
    Lunar Squirrel
    Lunar Squirrel Well-Known Member
    24 TRDOR Hybrid SPF100-Octane
    As long as the prior owner didn’t beat on it, that 2.7 is so stout that it would practically operate another 250k mi on maple syrup…
    But if changing now versus waiting to the next scheduled interval makes you feel better, then why not.
  11. May 6, 2024 at 7:19 AM
    jfly69
    jfly69 [OP] Member
    Tacoma 2016 SR
    Sounds good! Thanks folks
  12. May 6, 2024 at 7:22 AM
    kakwvu
    kakwvu Almost Heaven
    Kyle
    WV
    ‘24 JLURX
    This. Change your diff fluid.
    Chew and jfly69[OP] like this.
  13. May 6, 2024 at 8:01 AM
    Jesse H
    Jesse H Well-Known Member
    Jesse
    Texas
    '22 TRD Pro 6MT
    Brake fluid is often overlooked.
  14. May 6, 2024 at 8:02 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Momma knows best.
  15. May 6, 2024 at 8:02 AM
    Pungo1
    Pungo1 Well-Known Member
    Mark
    I'd drain/flush/fill everything if I didn't know for sure. Peace of mind.
  16. May 6, 2024 at 8:08 AM
    Clinch Mountain Preacher
    Clinch Mountain Preacher Serpent handler
    3rd gen AC SR5 4x4
    Change all fluids and filters and hit the road. Change sparkplugs if you're unsure if they've ever been done. Inspect accessory belt too in case it looks old. Check the date on the battery too.
    Avoid 10k m oil change intervals and you'll be just fine
    jfly69[OP] likes this.
  17. May 6, 2024 at 8:18 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Most guys change it when the axle seal leaks. :rofl:
    I am one of those guys. :anonymous:
  18. May 6, 2024 at 9:06 AM
    M85
    M85 Well-Known Member
    Colorado
    2019 SR ACLB
    The Carfax report for mine shows all the oil changes that were done at Grease Monkey. The Toyota site only shows what was done at Toyota, or you can log your DIY maintenance there going forward.
    jfly69[QUOTED][OP] likes this.
  19. May 6, 2024 at 9:22 AM
    ThreeBeers
    ThreeBeers Well-Known Member
    Ron
    2020TRDOR
    I do my own maintenance, write it down in a notebook and leave it in the glove box for the next owner. I know it is probably a boomer thing but I am an analog guy in a digital world.
    Toycoma2021, mquibble, BMH and 2 others like this.
  20. May 6, 2024 at 10:05 AM
    jfly69
    jfly69 [OP] Member
    Tacoma 2016 SR
    Good call- I’ll see about that thanks!
