First Oil Change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jmed99, Feb 9, 2009.
What's the Optimum Mileage to Change Your Oil For the First Time?
  1. 200 Miles
    1.8%
  2. 500 Miles
    11.9%
  3. 2,000 Miles
    28.1%
  4. 5,000 Miles
    51.8%
  5. 10,000
    0.7%
  6. Other...please specify
    5.7%
  1. Feb 9, 2009 at 7:40 PM
    jmed99
    jmed99 [OP] Well-Known Member
    SC
    09 DC PreRunner TRD OR
    I just bought my Taco a couple weeks ago and I'm trying to decide when I should get my first oil change. :confused:
    With all that said, when do you think is the optimum mileage to change your oil for the first time???
  2. Feb 9, 2009 at 7:42 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you can change it whenever really. go 1k miles, then change over to synthetic.
  3. Feb 9, 2009 at 7:44 PM
    jmed99
    SC
    The first recommended oil change is at 5000 miles. :cool:
    As a Mechanical Engineer I'm wanting to change it the first time at like 500 miles (I've done this on all my previous new cars) because most of the wear happens in the first few hundred miles. This wearing causing small metal pieces to be in the oil. It seems like those small metal pieces in your oil for the first 5000 miles would cause additional unnecessary wear. :(
    Personally, I think changing it at 500 miles then at 2000 then at 5000 and every 3000 from there on makes the most sense to me. I want to see what y'all think because y'all know these Taco's way more than I do.
  4. Feb 9, 2009 at 7:46 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    go for it..........................500 miles is a good round number!:D
  5. Feb 9, 2009 at 7:56 PM
    tacoholic
    tacoholic Well-Known Member
    East Bay, CA
    I ran break-in oil too far in the Mazda...actually way too far, when I changed the oil it was at 3,064 miles. Hopefully it didn't cause anything permanent to the engine but we just won't tell whoever comes to buy the car that little mishap. Then again I put in Mobil1 full synthetic so that should have fixed anything.
  6. Feb 9, 2009 at 8:01 PM
    sweater914
    sweater914 Well-Known Member
    North Dakota
    '09 I4 5spd Access Cab Timberland Mica SR5
    I just bought the wife's Taco, I'm thinking about 2500 miles for the first oil change. I worked on airplanes and the first oil change was at 25 hours using straight mineral oil which has horrible protection properties but is needed to seat the rings in '30's designed air cooled engines. By 50 hours things were seated and "normal". The new engines will break in with much less wear and purchasing the right filters will catch the biggest trash. I love my(her) 4 banger.:)
  7. Feb 9, 2009 at 8:04 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    I typically change it in the 1000-1500 range.
  8. Feb 9, 2009 at 8:08 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    I just follow the owners manual. Every 5000 miles or six months. As long as you care enough about your engine to change it at regular intervals you should be fine. Do whatever you feel comfortable with. JMO.
  9. Feb 9, 2009 at 8:27 PM
    Tilt
    Tilt Well-Known Member
    Lyle
    Alberta, Canada
    In between Tacomas at the moment.
    This is a topic that seems to be all over the map. I too usually change the oil on a new vehicle at around the 1000 to 1500 km mark. I mentioned this to the people at the dealership as I was doing the final paperwork picking my truck up (I get 4 free oil changes with my deal). They told me that Toyota runs the engines at the factory for a set time, then flushes the oil prior to the engine going into the truck. Not sure if that's true, or if it was a load of bs. Plus they told me to stay away from synthetics for a good long time.
    They recommended simply getting the 1st change at 8000 Km's (as noted in the service manual) and all should be fine. I've read on these boards, and other info, 20 or 30 different points of view. This is enough to drive one crazy.
    I think I'm just going to change the oil at around 1500 km's and then go back to the scheduled 8k km's, 16k km's....etc.
  10. Feb 9, 2009 at 8:34 PM
    tacoholic
    East Bay, CA
    You should never stray away from oil you plan on using in the future. If you use a full synthetic and then put in some non-synthetic oil then the engine will not accept it and it will be like an organ transplant from a person with a different blood type...not good in the end. (either you die or the organ dies)
    If you plan on putting in full synthetic then do it ASAP otherwise you won't be able to.
  11. Feb 9, 2009 at 8:47 PM
    Tilt
    Lyle
    Alberta, Canada
    See.......now right there. :confused:
    Talk to the dealership.....they say don't touch synthetics for several thousands of miles. At least until the engine has had a real good chance to break in. Then you read about people switching to synthetics right away. I don't know. Think I'll just stick with good quality regular oils at decent intervals until I feel the engine is broke in nice. Mind you......I don't put a lot of km's on my vehicles. My last 4 year lease went back with 44k km's on it. :p
  12. Feb 9, 2009 at 9:30 PM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    The first couple oil changes was done at the dealership, they gave me 3 free oil changes(each every 5k). I took advantage of that deal. I found out they were using semi-synthetic. (whatever that means). Since then I have been doing my own oil changes with synthetic oil (thanks TW!).
  13. Feb 9, 2009 at 10:03 PM
    BUK 0H5
    BUK 0H5 Still For Sale
    Queen Creek, AZ
    Silver 09 2.7L Manual AccessCab SR5 PreRunner
    Removed Mud Flaps, Suspension TSB, 5100's all around, JVC KW-AVX710 Head Unit with Metra surround.
    The 5000 mile recomendation probably has some stipulation for being under non severe duty aplications. I'd say about 2% of the people who own a vehicle in the US actually fall under that category. Living in Phoenix I make sure to change mine every 3000 miles. As far as the Break in oil change i was almost convinced after reading all the post on this forum to NOT worry about it and stick with the normal interval, but when I wiped the dip stick to check it earlier it seemed to turn rhe rag the normal yellow oil color but with a sort of silver/grey streak in the middle like metalic particles. I have a little over 800 miles right now so I think I will change it tomorrow. My last new car was an 07 Ford Focus and I chande the oil at about 800 miles then 3000 and every 3000 after that and I regularly got 5-8 mpg over the EPA rating.
  14. Feb 9, 2009 at 10:16 PM
    tacoholic
    East Bay, CA
    I guess stick with the break-in oil for about 3000 miles (dunno the KMs) and then change it. Just don't haul anything...or ass until you get a good change in there. When I changed, the engine on the Mazda got significantly quieter and smoother. It also fixed some issues I was having with the engine. I was told by many service departments and such that if you wait too long to change your oil to synthetic then the engine has adjusted fully to non/half synthetic and if you switch bad things will happen. Whatever oil you plan on using, use it for your first change and then stick with it through the life of your truck.
    Then change it at every 3K miles or so. 5K if you feel like saving money or are really light with it.
    BUK 0H5 has some good info there too.
  15. Feb 9, 2009 at 10:32 PM
    BUK 0H5
    Queen Creek, AZ
    Thanks for the props tacoholic
  16. Feb 9, 2009 at 10:39 PM
    Tilt
    Lyle
    Alberta, Canada
    Yeah, all-in-all this is good info to digest. I guess the main thing to remember is that we're the types that are on top of this stuff. I read in that other forum thread about the neighbor that hadn't changed their oil in like 50k (ish) miles. That's enough to make your head spin.
  17. Feb 10, 2009 at 9:58 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
  18. Feb 10, 2009 at 10:48 AM
    BUK 0H5
    Queen Creek, AZ
    Does anyon know where to get 0W-20? I've seen Mobil1 0W-30 but no 0W-20
  19. Feb 10, 2009 at 11:01 AM
    NAAC3TACO
    2014 SR5 DCLB 4x4
    I've seen 0w20 Mobil 1 at Kragen and Walmart. I think it has a bright green cap on the bottle. I use 5w20 Mobil 1, because it comes in a 5qt jug at Walmart and you save a little coin.
  20. Feb 10, 2009 at 11:02 AM
    Caddmannq
    Caddmannq MotoNerd
    California
    2012 PreRunner TRD Sport DC LB
    Undercover toneau
    IMHO every engine will wear less with synthetics. The rings seat fine with synthetics too, if you don't baby the engine during break in. The problem with changing to synthetics is that they are thinner when cold. This lets them lubricate faster, but OTOH it lets them leak through seals sooner.
    That is why I think many dealers warn people away from synthetics: they don't want to be fixing oil leaks under warranty.
    BTW, my break in oil got changed at 550 miles. Not because Toyota said to, but because the fan belt shredded and went around the crank snout, cutting the front main seal. I'm now almost at 3000 miles & will have it changed at that mileage.
