First Oil change
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Texas_bjj, Oct 29, 2015.
  1. Oct 29, 2015 at 10:43 PM
    Texas_bjj
    Texas_bjj [OP] Well-Known Member
    Anybody change their oil earlier than the 5000 miles recommend?... for "break in" Let me hear some opinions!
  2. Oct 29, 2015 at 11:08 PM
    Snowman
    Snowman I have a problem for your solutionÂ…
    Craig
    Somewhere in Canada
    Check out my build
    I would follow the intervals laid out in the owners manual. No need to do them any earlier than outlined.
    Texas_bjj[OP] likes this.
  3. Oct 30, 2015 at 12:51 AM
    knhorn
    knhorn Well-Known Member
    San Diego
    2016 TRD Sport DCSB Quicksand
    Icon Stage 5 set at 3", Toyo ATII, Fuel Throttle
    My salesman informed me that Toyota Care will only be changing the oil every 10000 miles on these trucks. Rotate and inspection are every 5000.
  4. Oct 30, 2015 at 1:22 AM
    BAMA-256
    BAMA-256 Well-Known Member
    Rex
    Huntsville Alabama
    2017 SR 4x4 5 speed manual Past-2016 TRD Offroad 4x4
    I was wondering the same thing. I've always done the first oil change around 1500 miles on all my new vehicles for peace of mind. Also wonder if the oem filter is made from synthetic material? I would hope so with 10k mile oil change intervals. Will change mine every 5000 miles though bc I make a lot of short trips
  5. Oct 30, 2015 at 1:30 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    First oil change on a new vehicle is 500 miles. One would be surprised at the amount of casting swarf that still remains inside and engine and that, along with the break in, can result in far more contaminants then most people would think.
    Engines are not ''broken in'' at the factory, bedding in of the wear surfaces takes place over the first K miles of use but most of the wear is in the first 500 miles.
    My 2015 Tacoma didn't have too much in the oil/filter, I was surprised at the amount of swarf in my 2014 FJC's filter though.
    splitbolt and iltdi like this.
  6. Oct 30, 2015 at 3:20 AM
    axe
    axe Well-Known Member
    Waste of time. I go by what the manual says. Its not 1962 anymore.
  7. Oct 30, 2015 at 3:36 AM
    allvuong
    allvuong Well-Known Member
    My instincts are telling me to do my first one at 1k and then every 5 after that. But I never know if the factory oil has something in it that should be ran with the engine so I'm thinking of doing my first oil at 3k then every 5.
    Toyota says you can go 10 k every oil change and I kno people that have been following that guideline with over 200k miles so idk.
    If Toyota does put something in their oil at the factory. Maybe it'll be good to run the first one at 10k then 5 after that. But like I said. Idk kno for sure.
  8. Oct 30, 2015 at 4:20 AM
    LtTaco
    LtTaco Well-Known Member
    Tennessee
    2016 SuperWhite Limited 4X4
  9. Oct 30, 2015 at 5:00 AM
    HankP
    HankP Well-Known Member
    Indy
    Yeah, someone got the answer right! It's not the oil is 'worn', but all the crap from the engine and hopefully the filter caught. That is why you want to have your first oil change sooner than later. I don't care what the manual says, the manual doesn't tell me how much attention was given the engine when it was being built by some guy half asleep with the flu working a third shift and wanting to go home.
    AlanKA and TOMRR like this.
  10. Oct 30, 2015 at 5:26 AM
    Bumrush
    Bumrush Well-Known Member
    Brian
    Middle TN
    16 TRD OR SB quicksand
    Why do people keep saying this? There is no time to break in an ingine. They build them under the "just in time process" and install them! They don't drive them around.
  11. Oct 30, 2015 at 5:44 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    I do. 500-5k-10k-15k...
    What's it hurt?
    I'll probably change the diff and trans fluids early too.
  12. Oct 30, 2015 at 5:53 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    That has more to do with the type of oil you use not changing intervals.
    I would drop down to a 0W full-synthetic oil if you do a lot of cool engine running.
    Short trips don't break down the additives in the oil faster, it just doesn't lubricate your engine because it's too cold.
    OP: Changing the oil early is obsessive compulsive and not logical. There is no need to assume the oil can't be changed at 10k miles. No reason. Changing it earlier is just wasteful and harmful to the environment.
  13. Oct 30, 2015 at 6:55 AM
    forty2
    forty2 Well-Known Member
    Cascadia
    2016 DCSB OR 6MT
    Oil change interval on '16 Tacoma is 10,000 miles if not being used in harsh conditions, which (let's be honest here) most won't be. It's in your warranty and service manual.
    CusterFan likes this.
  14. Oct 30, 2015 at 7:13 AM
    2016_dbag
    2016_dbag Well-Known Member
    2016 POSTURD
    I don't understand what the big deal is. Maybe I'm just simple minded...
    An oil change before 5k miles is not covered by ToyotaCare, so you will have to pay for it or do it yourself.
    If you want to change your oil at 500 miles or 1k miles or even 100 miles, then do it. It takes maybe 30 minutes and 2 beers. I don't understand why people are stressing over an oil change. And I'm not referring to this thread specifically, this isn't the first time this has been brought up in 3rd gen.
    tl;dr - change your fucking oil whenever you want.
    LTacoman, Rock Lobster and SAMROD87 like this.
  15. Oct 30, 2015 at 7:18 AM
    Howanic
    Howanic Well-Known Member
    Utah
    2016 TRD OR Double Cab 4X4 A/T Inferno
    Might want to check your manual. It states break in period.
  16. Oct 30, 2015 at 7:23 AM
    Nighthawk
    Nighthawk 'streme spoats
    Levi
    Casper Wyoming
    2008 Red TRD OR AC V6
    Bilstein 5100's w/ Eibach coil overs in front (set at 3" of lift). Front diff drop kit. Extended Bilstein 5100's in the rear. Deaver 2" AAL in rear w/ axle shims. 285 x 75 r 16 Goodyear Duratracks. Wheelers steelies type B, AFE cold air intake. Sway bar delete. All Pro Apex front bumper (rattle canned Rustoleum primer + flat black). Plasti-dipped emblems. Mud flaps removed.
    This is the correct answer.
    2016_dbag[QUOTED] likes this.
  17. Oct 30, 2015 at 7:33 AM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    Funny story. On my first tundra Toyota let me take it for the weekend...it was brand new and I made sure it received a solid test drive all weekend..I took it back told them I like it, but I don't want this one, I want a different one.
  18. Oct 30, 2015 at 7:40 AM
    Pktgumby
    Pktgumby Well-Known Member
    Colorado
    2016 DCSB TRD Sport - Magnetic Gray
    Only if you continue using the synthetic oil, otherwise it is 5,000 mile intervals.
  19. Oct 30, 2015 at 7:50 AM
    Ars3nalTRD
    Ars3nalTRD I Know Nothing!
    NoVA
    2016 BRM Tacoma TRD Sport
    Why wouldn't you use synthetic oil? :notsure:
  20. Oct 30, 2015 at 7:54 AM
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    bobrown14 likes this.
