First Oil change
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Texas_bjj, Oct 29, 2015.
  1. Oct 30, 2015 at 7:55 AM
    Pktgumby
    Pktgumby Well-Known Member
    Colorado
    2016 DCSB TRD Sport - Magnetic Gray
    Don't :infantry:the messenger, just stating what's in the manual.
  2. Oct 30, 2015 at 7:59 AM
    Ars3nalTRD
    Ars3nalTRD I Know Nothing!
    NoVA
    2016 BRM Tacoma TRD Sport
    Hah ... I just checked the manual and saw that... so original question is, why wouldn't I use synthetic oil? more below...
    Oh don't worry, AR still under the back seat. Just wondering why would you recommend not using synthetic oil, that's all.
  3. Oct 30, 2015 at 8:02 AM
    Pktgumby
    Colorado
  4. Oct 30, 2015 at 8:15 AM
    Pktgumby
    Colorado
    Not recommending it, just clarifying that if you stray from 0w-20, the manual calls for 5,000 mile intervals.
  5. Oct 30, 2015 at 8:18 AM
    Ars3nalTRD
    NoVA
    He he he .... that's what I've come to conclude as well. Well... @TXTee said it best... "Your truck, your money: do what you want."
  6. Oct 30, 2015 at 8:28 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Manual also states 0w-20 has to be used at least every other interval if you stray.
  7. Oct 30, 2015 at 8:45 AM
    AlanKA
    AlanKA Well-Known Member
    From the maintenance Guide -
    Change every 10,000 miles with OW-20 for normal use.
    Change every 5,000 miles if do this excessively, and not "occasionally".
    • Driving on dirt roads or dusty roads.
    • Driving while towing, using a car-top carrier, or heavy vehicle loading.
    • Repeated trips of less than five miles in temperatures below 32 degrees F.
    • Extensive idling and/or low speed driving for a long distance such as police, taxi or
      door-to-door delivery use.
    I'm thinking - maybe split the difference and change every 7,500 miles. :)
  8. Oct 30, 2015 at 9:43 AM
    allvuong
    allvuong Well-Known Member
    I'm more concerned about the first oil change. Becuase If the factory does put some additives that may be beneficial for the life of engine. I'm wondering if it's better to leave it for 10 k before my first oil change. Only after that would I chsnge every 3-5k. Obviously of they just put in the same thing dealer does, I would do my first 1 at 1k. Then every 3-5 after that.
  9. Oct 30, 2015 at 11:02 AM
    Bumrush
    Bumrush Well-Known Member
    Brian
    Middle TN
    16 TRD OR SB quicksand
    In other words the engine is broken in within a few minutes of a test fire? The manual calls for a break in period, if one chooses not to abide by this that doesn't mean you will have engine failure. It is simple a safe guard.
  10. Oct 30, 2015 at 11:34 AM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    what type and weight oil is in the 2016.
  11. Oct 30, 2015 at 11:44 AM
    taco206
    taco206 Well-Known Member
    Mill Creek, WA
    14 DCSB SR5 PreRunner 2.7L
    Changing your oil every 100 miles increases your Tacomas resale value.
    These threads just need to get locked and deleted like other forums.
  12. Oct 30, 2015 at 2:49 PM
    splitbolt
    NW Arkansas
    I'm willing to get an oil analysis done at 500, 5k, and 10k; someone else want to wait until 10k?
    If we get a large enough sample size, we can have more than just opinions.
  13. Oct 30, 2015 at 3:02 PM
    Hank_Mille
    Hank_Mille Well-Known Member
    PNW
    2016 Tacoma Limited
    Is the initial oil Toyota uses at the factory anything special? Or is it just the usual standard full synthetic type oil that they recommend for all other oil changes?
    if that is the case, change it when YOU feel it needs to be changed based on whatever YOU believe.
  14. Oct 31, 2015 at 4:02 PM
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    For anyone changing their own oil on a V6 with tow, with filter change mine took less than 5.5 qts to be full. Manual states 6.3qts. So, maybe start on the low side before running then engine a bit a rechecking.
  15. Oct 31, 2015 at 4:05 PM
    #35
    BAMA-256
    BAMA-256 Well-Known Member
    Rex
    Huntsville Alabama
    2017 SR 4x4 5 speed manual Past-2016 TRD Offroad 4x4
    Thanks for the tip! You probably just saved quite a few of us from overfilling lol
  16. Oct 31, 2015 at 5:29 PM
    #36
    Frank_Zuccarini
    Frank_Zuccarini Obscure Member
    Frank
    Chicagoland
    AC-TRD-OR-4x4-Barcelona Red
    That is a HUGE difference, and more than a little alarming.
    I will do as you suggest, and proceed cautiously.
    Thanks for sharing this little tidbit............................ Frank
  17. Oct 31, 2015 at 5:33 PM
    #37
    Markc1024
    Markc1024 Well-Known Member
    I did mine and it was spot on per the manual. I put in 6 quarts to start and then added a small amount after a day.
  18. Nov 1, 2015 at 7:27 AM
    #38
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    This would be the best way to know.
