First Oil Change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kazz, May 6, 2010.
  1. May 6, 2010 at 8:19 PM
    Kazz
    Kazz [OP] Active Member
    Calgary
    2010 SR5 4x4
    No Mods yet
    My truck is coming up to 2500mi and is wondering if there is any advantage/disadvantage to getting the oil change now and again at 5000mi. I get free oil changes thru the dealer every 5000mi so this would only cost me 1X. I read all about break in oil from the factory to metal shavings in the first 1000mi etc.. Please chime in and give me your thoughts, I can't think of any reason not to unless in fact there is special oil from the factory that needs to be in there for 5000mi.
  2. May 6, 2010 at 8:27 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    On new vehicles, I do mine around 1500 miles and then at 5000 mile intervals thereafter. If there ever will be any metal shavings or other debris, it will most likely happen at the beginning of the engine's life so I change it early.
  3. May 6, 2010 at 8:30 PM
    arrowhead
    arrowhead Active Member
    Do it yourself.
    I just did mine, for the first time on this truck The oil shoots out of there like a jet stream! Just FYI.
    God knows why they used such a small bolt to drain the oil.
  4. May 6, 2010 at 8:31 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    ^Remove the oil filler cap first and it shouldn't do that.
  5. May 6, 2010 at 8:44 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    I don't think the trucks come with "special break-in oil". I changed it early for the first few. If you want to make it really easy to do yourself, attach a hose with a clamp to the drain under the filter.
  6. May 6, 2010 at 8:54 PM
    arrowhead
    ...... Ohhhhh
    Wait there's that much crank case pressure?
  7. May 6, 2010 at 9:18 PM
    bakerla
    bakerla Man, Myth, Legend
    Lyndall
    Pearland, TX
    '10 4wd OR
    CBI Moab front and CBI Trailrider rear, Budbuilt skids, Shrockworks sliders, OME Dakars w/ OME Nitros, OME 886x w/ OME Nitros, Light Racing UCAs, stainless steel brakelines F/R, Cobra 75 w/ Firestik antenna, 255/85/16 Cooper ST Maxx on 1st gen alloys, Weathertech liners, Engo 9000S winch, stickars and other shit.
    x2. my first oil change rivaled the spill in the gulf. did my second oil change yesterday with the Fumoto valve, must cleaner. oil filter wasn't easy to remove on the first change either....
  8. May 7, 2010 at 6:51 AM
    Snake~
    Snake~ Big Member
    Blake
    DFW
    2010 DCSB TRD Sport
    Autolumination Yellow fog light bulbs, Dynomax Ultra Flo muffler, AFE Pro Dry S air filter, tailgate security mods, TRD skid plate, DeeZee bed mat, Armor Lid tonneau, OEM roof rack, TRD center caps, Satoshi grille, Sockmonkey tailgate decal
    Ditto on the Fumoto valve. That thing is great. Also, there is a drain hole under the oil filter mount. Before you remove the filter, slide the rubber cap off the hole and slide some 1/2" (if I remember right) tubing on. Put the other end in your oil catch pan and voila - mess free filter change too.
  9. May 7, 2010 at 6:57 AM
    jester156
    jester156 Well-Known Member
    Cumberland, RI
    08 V6 4x4 DC TRD, 6spd
    TRD Supercharger, TRD CAI, Sirius, Rear TSB, Front 5100 with Eibach coils, 1.5" AAL, URD short throw, fog light mod, weather tech liners,
  10. May 10, 2010 at 11:43 AM
    Drewboto
    Drewboto Well-Known Member
    Drew
    Missouri
    Base model ಠ_ಠ
    17" Mustang wheels, Eclipse AVN 5435, Deck plate mod, vertical Maglite mount, K&N high-flow air filter, Delta gullwing box, amp, sub, 30 percent tint, floor lighting, tilt activated glove box lighting, lighting behind seat, engine bay lighting, SR5 grill surround, power windows, outside temp display
    I'd say go for it. Just keep your types of oil the same. You probably don't need an über expensive filter if you're oy going to use it for 2,500 mi (but check with your dealership and warranty about that)
    I shoulda checked out this thread before staining the driveway. First gen filter location sucks.
  11. May 10, 2010 at 12:02 PM
    kris77
    kris77 Born in the Backwoods
    West Virginia
    08 DC TRD Sport Speedway Blue
    In channel Vent Visors, AVS Bug Shield, Hankook Dynapro RF10 265/70/17
    If you dont want to get a hose, just get a pop bottle and put under there and when its done, just empty the pop bottle.
  12. May 10, 2010 at 12:25 PM
    Collins
    Collins Well-Known Member
    North Carolina
    09' Tacoma, 2.7L, 5spd, 4x4
    Change it now and again at 5k...and yes keep the same viscosity.
    Bear in mind the oil filter was put on by a robotic process
    at the factory (or by a gorilla) as it is a complete beotch to remove the first time.
    I bought a filter wrench with a 3/8" socket drive and unfortunately that didn't quite fit on the stock filter
    without slipping so i finally had to put a couple metal screws into the wrench and into the filter to get enough
    bite on the filter and do it the messy way.
    I blew half the afternoon trying to get that damn filter off.
    never noticed the oil filter drain plug though...good tip with the hose
    attachment.
    oh, and dont use the wrench to put the new filter on...hand tight is good.
    PC
  13. May 10, 2010 at 1:02 PM
    1980 Well-Known Member
    The Dust Bowl
    I agree -- this is the way to go -- a plastic pop bottle fits under there just about perfectly.
  14. May 10, 2010 at 2:40 PM
    Koov
    Koov MonStar
    Seattle
    06 Prerunner Dbl Cab TRD Sport
    Tint 20%, USA spec IPOD adapter, Debadged, Leer canopy, Michelin MS/2 tires, AFE Pro Dry drop in air, Husky liners, D ring Mod, Bed mat.
    No harm in doing it now. I would just do it myself.
  15. May 10, 2010 at 4:35 PM
    lazaro
    lazaro Well-Known Member
    Garry
    Chesterfield, Virginia
    2010 DC BSP 4X4 TRD Off-road
    Stainless Nfab Steps painted black, Acces Tonneau cover, LED dome and map lights, Weathertech floor mats, EGR slimline visors, Wicked Flow 13 mufflers, ultragauge and 4X4 illuminated switch mod, receiver shackle from Timichi and Redline QL plus hood struts.
    I hit 1556 miles on my 2010 tacoma and just followed Chris 4x4 oil change procedure and its easy. The original filter is on tight. Get some Oil filter pliers and get a grip near the bottom of the filter. Lefty loosy, righty tighty. I gave it a firm grip and turn and i felt the thing just gave way. Use OEM filters, I got mine at $5 a piece with one of those gasket washers from the dealer. I was so proud of my work. Next change will be the 5K mark.
  16. May 10, 2010 at 5:28 PM
    MachoTaco10
    MachoTaco10 Well-Known Member
    Nick
    New Hampshire
    2010 Tacoma TRD Sport
    why dont you buy a "real" filter wrench. The ring style.
  17. May 10, 2010 at 7:35 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    ^That makes absolutely no difference, at least in my case. That filter was pretty tough to get off the first time.
  18. May 10, 2010 at 7:44 PM
    bakerla
    Lyndall
    Pearland, TX
    '10 4wd OR
    for sure...the first time, i used a screwdriver and jammed it through the filter
  19. May 10, 2010 at 7:52 PM
    SlurpeeBlueMetallic
    SlurpeeBlueMetallic FFFFFFUUUUUUUUUUUUUUU...
    On my first oil change I broke one strap wrench and finally got the filter off with the second one... :eek: They must put it on with 30lbs of torque at the factory.
    I'll chime in on the Fumoto, too. I like mine although if you wheel often you may want to skip it as it would absolutely suck to have it snap off and watch all your oil drain away into the dirt. It does drain slower than the stock setup but that gives me a couple of minutes to check all my other fluids, brakes, hoses and tires. I setup the drain pan, pop open the Fumoto, pop off the filler cap, hook up my drain hose to the plug under the filter and run it to my pan then swap out the filter. By the time I do that then check the other stuff it's ready to fill again... my last oil change took less than 20 minutes from opening the garage door to washing my hands and required no tools.
  20. May 10, 2010 at 8:06 PM
    bakerla
    Lyndall
    Pearland, TX
    '10 4wd OR
    I've wondered about this lately. not that i do much wheeling, but a well placed rock could probably do some damage.
