First pistol
Discussion in 'Guns & Hunting' started by CoMo Taco, Jun 26, 2020.
  1. Jun 26, 2020 at 8:41 PM
    CoMo Taco
    CoMo Taco [OP] Well-Known Member
    Judah
    Columbia, Missouri
    2018 Toyota Tacoma SR Access Cab 4x4
    Alpine stereo replacement, 6x9 Kicker front door speaker upgrade, Kicker tweeter upgrade. 6000k HID upgrade, Running boards installed, Rear seats installed, Pedal Commander, Meso Map Lights, TRD pro grille, Raptor lights, TRD Pro rims, 4600's Bilsteins, Diode Dynamics SAE Yellow Fog lights, Custom fuse box.
    I am buying my first pistol. I only own a Remington shotgun 870 at the moment. I am looking for a gun to use as my conceal and carry. So far I am a fan of a Glock 19 and 20. Leaning more toward the Glock 19 Gen 4.
    NMBruce, ColoradoTJ and wilcam47 like this.
  2. Jun 26, 2020 at 8:42 PM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
  3. Jun 26, 2020 at 8:48 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Check out the Mossberg MC1SC.
    CoMo Taco[OP] likes this.
  4. Jun 26, 2020 at 8:49 PM
    tcjacado
    tcjacado Well-Known Member
  5. Jun 26, 2020 at 8:51 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    lethal force is Not idyllic
    its life changing.................. if U have to take life
    if U have to save/protect a life
    make a good choice
    Not done by consensus or committee
    get truly good training
    good luck
  6. Jun 26, 2020 at 8:51 PM
    Fiend13
    Fiend13 Well-Known Member
    Chad
    Waddell/Phoenix area
    08 TRD O/R DC Prerunner
    Go with whatever you are comfortable carrying and using. Last you thing you need is someone telling you what to get and then you end up hating it. Go to a range and try a few out to get feel for them. That's what I did for my first handgun. Tried different guns and different calibers and ended up liking the gen 3 G17 the most so I went with that. Also, before you mod it or anything, I would use that money for a few ccw/gun use classes. Not the typical safety course, which I also recommend if you new, but the classes that actually teach you proper draw from concealment, quickly put rounds on target, etc.
  7. Jun 26, 2020 at 8:53 PM
    CoMo Taco
    Judah
    Columbia, Missouri
    Will be visiting a range soon to try out some pistols just curious on ones people like so I can seek them out and shoot them myself.
    Fiend13[QUOTED] likes this.
  8. Jun 26, 2020 at 8:53 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    A Glock 20 is a pretty large pistol to conceal on a daily basis without purposely dressing for the gun.
  9. Jun 26, 2020 at 8:55 PM
    Fiend13
    Chad
    If your set on a glock and want it for coneal carry then I'd recommend either the double stack G26 or single stack G43, I carry the G43 and love it. Gives it more of a concealed appearance with it being a single stack
  10. Jun 26, 2020 at 9:02 PM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    Glock 43x(9mm) with the Standard Arms aftermarket mags that can hold 15. If your state is a ten round only state then a Glock 27(40s&w) all day holds 9+1 standard. It’s what I carry every day
    Dirk Diggler likes this.
  11. Jun 26, 2020 at 9:03 PM
    Nunya Bizness
    Springfield armory Hellcat 9mm. Love mine. 13+1 super concealed and compact. Custom holster.
    Put 300 plus rounds through it and not a single issue. But dont run anything other than brass casing.
    ChadsPride likes this.
  12. Jun 26, 2020 at 9:03 PM
    El Duderino
    Jeremy
    HI->PNW
    Just get real comfortable and train a lot with whatever you buy. You want to be proficient an almost second nature drawing from your holster. I dry run practice at least 10 times a day.
    SilverBulletII and Fiend13 like this.
  13. Jun 26, 2020 at 9:16 PM
    svermilyea
    svermilyea Well-Known Member
    Scott
    East Tennessee
    2018 Taco Sport (Cement)
    3in leveling lift (Coilovers and AAL) 285/65R18 tires 18" Fuel wheel/tire package Pro Grill, Morimoto XB LED Headlights, DD SS3 Pro Fogs Body Armor Front and Rear Bumpers Pioneer WC6600 head unit w/ OEM Audio + Reference 500 System with dedicated sub amp Meso signal lights, gas hole, led interior lights, ECT relocate, Chrome delete kits Meso Overhead Molle Rack, Seat Risers, Katzkin Leather seats (self installed...it was a fucking bitch) VFTuned .....KDMax Pro!
    Like @Fiend13 said, you gotta try on a few to find what works for you. There is a lot of difference between a carry gun and a range gun. Remember that if it is not comfortable, you won't carry it. Same goes for weight. If it is too heavy, you won't carry it. Anything larger than a glock 19 or sig p320 compact becomes more difficult to conceal (not impossible - read skinny guy with loose clothing). Likewise, micros are lower capacity generally speaking (sig p365 and Hellcat being the exceptions) and are more difficult to manage accurately under stress. The trade off being they are easily concealed. Caliber will be another barrier in your choice. 9mm is relatively easy to control and allows for quick follow up shots. 40 and 45 are a little more difficult, but good technique and practice will tame the additional recoil. Wheel guns in 38 special or 357 are tried and true, but lack capacity.
    Test a few, and while your shooting them, feel the weight and look at the size and consider how you would carry that firearm and conceal it. Going armed is a choice. There is a lot of preparation. Maintenance in terms of training, practice, and repetition is never ending. The two pieces of the puzzle most people forget are mindset and preparation for what will come after you have deployed your firearm.
    JSB10 and Fiend13 like this.
  14. Jun 26, 2020 at 9:25 PM
    tacomaccountant
    tacomaccountant Well-Known Member
    Florida
    2019 Metallic Grey SR5 4WD
    Get the largest 9mm that you will actually carry every day. A glock 19 is perfect for this (especially appendix) but if you’re worried about the size something like the 43x is a great option.
    do.not.buy.anything.chambered.in.40. They’re fine, but there is no significant benefit to them over a 9mm especially when you are just starting out.
    Train. This doesn’t mean buy some ammo and go shoot. This means go train at a reputable school like valor ridge, tactical response, etc. I promise you it’s worth it.
    get a good holster. Kydex from a company like trex arms, tier 1 concealed, or nsr tactical.
  15. Jun 26, 2020 at 9:28 PM
    Ch78
    Ch78 GBO!
    Tomball, TX
    25’ Landcruiser 1958
    Tuned By D3 Performance
    I’m really loving the Springfield Hellcat I just picked up. Best part is it’s a small, easily concealable 9mm but it’s also a double stack unlike many small CC pistols.
  16. Jun 26, 2020 at 9:35 PM
    Pixeltim
    Pixeltim Misunderstood member
    77 square miles surrounded by reality.
    '15 Black DCLB SR5
    Tires, Softopper, fully armored, winch, many pinstripes.
    I have a Sig 232 and that's a good size for CC, and it's very comfortable in the hand too. If you feel the need to Concealed Carry, take the classes. They spend a lot of time telling you how to avoid ever being in a situation where you might need it. If you ever actually need to draw, much less fire, then something very wrong has occurred on multiple levels. Make sure you realize this.
  17. Jun 26, 2020 at 10:57 PM
    El Duderino
    Jeremy
    HI->PNW
    There’s a nice benefit between 9mm and 40
    Ch78 likes this.
  18. Jun 26, 2020 at 11:02 PM
    StevenP
    StevenP Well-Known Member
    Steven
    Alta, Ca
    2003 Tacoma DCSB TRD
    Build thread in Signature
    I have 20, and it is TONS of fun, but probably a bit much to CC, ammo is also costly.
  19. Jun 26, 2020 at 11:04 PM
    gixxerphil
    gixxerphil @concretelander
    Phillip
    Auburn, Alabama
    2013 DCLB
    If you're set on a Glock 19. I would buy a Glock 23. That way you can buy a 9mm conversion barrel, recoil spring, and 9mm mags for 2 guns in one :D
    I'm not one to give advice on a brand. You need to get what feels good in your hand and you can shoot. Nothing worse than having a gun you don't like/can't shoot.
    I'm a Glock fanboy by the way. I like the way the fit my hands and shoot.
    BlackGT99 and El Duderino like this.
  20. Jun 26, 2020 at 11:29 PM
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    Ahh youth. So easily convinced that the latest and greatest really are. Buy a 1911.
    FlyingWolfe and EdgemanVA like this.
