First plug change at 210k miles
Discussion in '2nd Gen. Tacomas (2005-2015)' started by knottyrope, Apr 14, 2019.
  1. Apr 14, 2019 at 8:07 PM
    DayTripper85
    DayTripper85 Well-Known Member
    2005 Tacoma DCSB Off Road
    Yep
    I'm almost scared to see the engine bay on that monster.
    The only time consuming part checking out at the auto parts store. It takes about 30 minutes to change the belt/plugs. I use a Husky brand torque wrench to install them and repeat every 30k.
    I usually devote an afternoon to greasing the drivetrain, changing motor/diff oils, belt, plugs, filters. When I'm done I usually detail the engine bay, check the tires, change the cabin air filter, grease all the hinges, ect. I know it's a deteriorating assett, but I try and slow that as well as I am able.
    TRD-ED, windtzu and jca like this.
  2. Apr 14, 2019 at 8:23 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    They are annoying but not that bad once you get use to them, Im a tech at a ford dealer so here is a 3.5L (non eco boost) from a current ford explorer.
    Blue part is the intake manifold and red part is the airbox to throttle body, I remove the red part so its easier, then pull the blue part of to get to the rear bank of plugs. I can remove blue part, replace plugs and reassemble one of these in less then a hour, its just being careful and double checking you havent forgotten any lines/wires the first time you do it. Also I put painters tape over the intake when the manifold is off, dropping shit into the engine is not fun.
  3. Apr 14, 2019 at 8:33 PM
    DayTripper85
    Yep, I remove the engine cover, intake tubing from the filter outward, and one of the right side intake manifold support brackets. I use two extensions with one on a swivel for the Tacoma. Pretty smooth. I once found a squirrels nest and a pile of acorns in there. Needless to say we no longer have ground squirrels at our place in the sticks.
    My other motors at home are all different but , only the VW GTI is sideways and that sucker is still easy to swap plugs in. Just replaced the three cam chains on that one, along with the updated cc-tensioner. I did not enjoy that particular job.
    My Miata is super simple, and I feel the Tacoma 4.0 has been a breeze too.
    Sounds like you are careful, which I like.
  4. Apr 14, 2019 at 8:54 PM
    DayTripper85
    @joeyv141 , P.S. When I said engine bay I was talking about the OP's lol. Thanks for that though, always learn something new. Definitely a good move to cover up the intake on that puppy.
  5. Apr 14, 2019 at 9:06 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    I'm going to put another 210,000 miles on my truck before I change the oil.
  6. Apr 14, 2019 at 9:10 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Just make sure you use Amsoil.. that'll do the trick ;)
  7. Apr 14, 2019 at 9:10 PM
    oretaco
    oretaco Daddy and/or Papí
    Cameron
    Vancouver, WA
    2019 SW SR DCSB
    Mods in signature
    Might as well run the tires until the wires regenerate the rubber.
    2015WhiteOR likes this.
  8. Apr 14, 2019 at 9:10 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    lol.... right the plugs on this motor are a breeze to change.... zero point to pull them and gap them when they are cheap. just change them like toyota says at 30k.
    You want a bitch of a motor... try the #3 plug on my honda 919 motorcycle... backbone spine covers the hole... if you are very crafty you dont have to pull the valve cover to remove the plug!!!!
    CanisLupus and DayTripper85 like this.
  9. Apr 14, 2019 at 9:12 PM
    2015WhiteOR
    Gainesville TX
    Reminds me of the airbox on a 87 Honda XL600R. I swear the bike was designed AROUND it... Like Louis CK says, it was like trying to fold a bowling ball to make that fit back inside there.
    DG92071 and DayTripper85 like this.
  10. Apr 14, 2019 at 9:19 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Surprised that one plug even came out. Less surprised people wait that long to change plugs
  11. Apr 14, 2019 at 9:32 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I’m not going to feed you negativity OP.
    It’s good you got them changed.
    I’m betting the truck runs better now?
    Now all that’s left to to is drive it like it was intended.
  12. Apr 15, 2019 at 2:53 AM
    12valve
    12valve Active Member
    2012 sport 4x4 shortbed 6spd
    Snug top, airbags, abs kill switch, yellow wire, greased frame no rust, popnlock, 265/75r17 duratracs, 2wd low
    U still have to check the gap on a new plug before installing. Takes 30 seconds or less to clean it.
  13. Apr 15, 2019 at 4:57 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    I am basically incompetent and I was able to easily change the plugs in my 4.0. The gearwrench 9/16 magnetic spark plug socket with the wobble extension is a big help. No reason not to change them out regularly. It was actually fun and gave me a sense of accomplishment. Can’t wait to do it again!
    ChadsPride likes this.
  14. Apr 15, 2019 at 5:17 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    You could just leave them in long enough to have the threads come out with them.
  15. Apr 15, 2019 at 5:22 AM
    #35
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    So tell me how do you clean your plugs put them in the dishwasher?
    knottyrope[OP] likes this.
  16. Apr 15, 2019 at 5:30 AM
    #36
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    This just proves to me that 30k is a little on the short side for these plugs. I planned on every 50k from the beginning and thats what i am gonna stick too.
  17. Apr 15, 2019 at 5:35 AM
    #37
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Did the stumble go away?
    New plugs = < mileage doesn’t make sense or does it?
  18. Apr 15, 2019 at 5:37 AM
    #38
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    So you don't think burnt out spark plugs waste fuel? The 30K mileage Toyota recommends is all about emissions it is stated in your owner's manual will they last longer? I'm not going to debate that it's called responsibility vers being cheap.
  19. Apr 15, 2019 at 5:52 AM
    #39
    windtzu
    windtzu Active Member
    I couldn't agree more. There's too much effort in pulling each plug to only re-gap them. I just replaced mine at 34k.
  20. Apr 15, 2019 at 6:13 AM
    #40
    TRD-ED
    TRD-ED Well-Known Member
    Lenoir NC.
    2020 Army Green TRD PRO - 2023 Genesis GV70
    Stock FOX 275/65/18 At3w 18X9 Fuel Vapor's
    Then you can install the new quick disconnect plugs. Just spark "plug-n-play" :D
    Toy4me likes this.
