First plug change at 210k miles
Discussion in '2nd Gen. Tacomas (2005-2015)' started by knottyrope, Apr 14, 2019.
  1. Apr 15, 2019 at 8:02 PM
    #61
    MPA2point0
    MPA2point0 Well-Known Member
    Evan
    Havertown, PA
    2015 Super White DCLB Trd Sport
    Nothing but downhill highway driving?
  2. Apr 15, 2019 at 8:09 PM
    #62
    DirtTaco
    DirtTaco Well-Known Member
    I cannot even get 420 KM per tank and I am light on the pedal.
    coopcooper likes this.
  3. Apr 15, 2019 at 8:19 PM
    #63
    DayTripper85
    DayTripper85 Well-Known Member
    2005 Tacoma DCSB Off Road
    Not unreasonable, I regularly got 22-23 mpg in my PreRunner that had over 200k miles when I kept speeds under 75mph. I was easy on the gas and ran stock tire sizes with BFGoodrich Rugged Terrain tires @31PSI. It had zero mods though, and was very well maintained.
    My current 2005 with average maintenance, and K02's gets 16mpg with a topper and roof rack installed. I've yet to check it without. Guess I need to knock this out just to see.
    knottyrope[OP] likes this.
  4. Apr 16, 2019 at 6:54 AM
    #64
    knottyrope
    knottyrope [OP] Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    Just back roads 35-50 mph
  5. Apr 16, 2019 at 6:57 AM
    #65
    knottyrope
    Knotty
    Bahstun
    My ex has an 05 sienna with 215k miles. Plugs never changed. Still goes great
  6. Apr 16, 2019 at 7:01 AM
    #66
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    Yep. My plugs have gapped fine at 30k every time. I still change them. Copper plugs aren’t expensive.
    windtzu likes this.
  7. Apr 16, 2019 at 7:02 AM
    #67
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    :laugh:
    b_r_o and Sprig like this.
  8. Apr 16, 2019 at 7:02 AM
    #68
    Accipiter13
    California
    '11 DCLB 4x4 Sport
    This makes sense. You won’t get 22-23 on the highway at 65+. More like 19-20 maybe.
  9. Apr 16, 2019 at 7:17 AM
    #69
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    Try 16mpg mixed driving in Houston. 35" tires + 6" lift will net you about 11-12mpg, which is what most of my friends run on their vehicles.
    I get about 250 miles to the tank city driving, maybe 330-350 on the highway.
  10. Apr 16, 2019 at 7:26 AM
    #70
    knottyrope
    Knotty
    Bahstun
    My 1995 F350 4x4 CCLB 7.3 turbo with big heavy 35s and a four inch lift gets 19 MPG with the AC on.
    will.i.was[QUOTED] likes this.
  11. Apr 16, 2019 at 8:01 AM
    #71
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    Good to know, I will look into that socket and attachment!
  12. Apr 16, 2019 at 8:40 AM
    #72
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
  13. Apr 16, 2019 at 8:45 AM
    #73
    Hook78
    Eastern NC
    2015 DCSB TRD OR
  14. Apr 16, 2019 at 8:49 AM
    #74
    TheDevilYouLove
    Marylandistan
    For starting the new plugs by hand so you don't cross thread them. Worked perfectly.
  15. Apr 16, 2019 at 8:50 AM
    #75
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    Awesome. Appreciate the advice.
  16. Apr 17, 2019 at 10:08 AM
    #76
    Ghostly
    Ghostly Active Member
    lol, Bought a used car, don't know if they've ever changed the sparks, maybe I should check them...
  17. Apr 17, 2019 at 10:54 AM
    #77
    Rick's 2012
    Rick's 2012 Well-Known Member
    Rick
    Costa Rica
    2012 Double Cab 4x4 Grey with leather
    Stock
    I would just so that you know. If they're fine then you can just leave them. You've got nothing to loose.
    I always checked this when l bought a used vehicle. Plugs, filters, belts, hoses. etc..Just in case for peace of mind.
  18. Apr 17, 2019 at 11:00 AM
    #78
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    Yes we know, its in your sig.
  19. Apr 17, 2019 at 11:09 AM
    #79
    Ghostly
    I happened to check everything else, but didn't even bother checking the spark plugs. I just complete a full transfer case and diff fluid replacement. I don't think they ever changed the front diff fluid, cause that shit was as black as engine oil.
  20. Apr 17, 2019 at 3:07 PM
    #80
    cbrann35
    cbrann35 Well-Known Member
    Tahoe City, CA
    2012 White SR5
    They probably didn't.
    Ghostly[QUOTED] likes this.
