First Plug Change on 2010
Discussion in '2nd Gen. Tacomas (2005-2015)' started by whippersnapper02, Mar 19, 2011.
  1. Mar 19, 2011 at 7:38 PM
    whippersnapper02
    whippersnapper02 [OP] Well-Known Member
    Christian
    Yorba Linda, CA
    10 MGM TRD OR 4wd Auto DCSB
    Banks Monster Exhaust, Pop n Lock tailgate lock, Hook-Ups tie down brackets, USA Spec Ipod adaptor, WO seat covers, color matched grill with Grillcraft insert, Tuffy locking bed box
    I just did the plugs on my 2010 at 30K miles. I did the passenger side in like 5 minutes and the driver's side in like 20. Lol. I don't have too much room for my big hands. So of course I did it the right way with an impact gun set at the highest level and the regulator maxed out. It worked perfectly.:D
    So do these plugs look normal for a 4.0? To me it looks like the combustion is a little lean. Chris4x4 where are you?
  2. Mar 19, 2011 at 7:43 PM
    Mxpatriot
    Mxpatriot Arctic Prerunner
    Chase
    North Pole, Alaska
    '06 4x4 AP LT and Locked
    Money pit.
    Tag for response - I plan on changing mine tomorrow.
  3. Mar 19, 2011 at 7:44 PM
    Machete Eddie
    Machete Eddie Well-Known Member
    Eddie
    Texas
    2011 DC TRD OffRoad
    I thought a brown to tanish color was normal. To me they look OK. Is the one on the left side different in color?
  4. Mar 19, 2011 at 7:45 PM
    whippersnapper02
    Christian
    Yorba Linda, CA
    Yeah it was a little darker than the rest. I forgot what cylinder it came out of.
  5. Mar 19, 2011 at 7:49 PM
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    AVID off road bolt on sliders, upper grillcraft, OEM color matched front grill color matched-rear bumper, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,Timcha shackle receiver,bulaculla trailer harness relocate harness,ICON 2.5 Coilovers, ICON tubular UCA's. Allpro expo leafs, SS lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts/lights (cube). 20" OK LED bar and BAMF LED light mounts behind grill.
    I just did mine today and they look almost identical to yours...
    Azbackcountry
  6. Mar 19, 2011 at 8:30 PM
    chris4x4
    chris4x4 With sufficient thrust, pigs fly just fine. Staff Member
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Those look normal to me..
  7. Mar 20, 2011 at 2:59 AM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2007 AC TRD OFFROAD
    Why are you changing plugs @ 30k?
  8. Mar 20, 2011 at 4:40 AM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    Because that's when the manual calls for it.
  9. Mar 20, 2011 at 4:40 AM
    DEEVON911
    DEEVON911 Semi-pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Thats when they are due to be changed.
  10. Mar 20, 2011 at 5:02 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    looks normal
  11. Mar 20, 2011 at 5:17 AM
    woody6047
    woody6047 McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    100%stock, except for the exhaust leak and custom windshield crack mod
    I did mine at 50k and thats about what mine looked like :anonymous:
  12. Mar 21, 2011 at 1:55 AM
    BUZZCUT
    Georgia
    2007 AC TRD OFFROAD
    ok.
    I guess I need to stock up on blinker fluid and left handed monkey wrenches.
    Just because the "manual" say so doesn't mean you have to change them. Those plugs shown show normal combustion. I would have chacked the gap and put them right back. Newer engines don't eat plugs like in the past and unleaded fuel helps keep them clean.
    Yea but what do I know rite?
  13. Mar 21, 2011 at 2:36 AM
    muddog321
    muddog321 Member
    fl
    09 tacoma doublecab 4wd trd w/e locker
    Because your Tacoma has expensive catalytic converters that the Dealer can then not cover if you do not follow their schedule - running too rich due to plugs could destroy them. Yes, they should last 100k but why risk the voided warranty. That's also why we change Mobile 1 every 5000 miles - not because it's really needed.
  14. Mar 21, 2011 at 8:28 AM
    whippersnapper02
    Christian
    Yorba Linda, CA
    On maintenance I like to go by the book. 30 bucks and an hour of my time to keep my truck running at its best is more than worth doing IMO.
  15. Mar 21, 2011 at 8:30 AM
    BUZZCUT
    Georgia
    2007 AC TRD OFFROAD
    If it is due to warranty why use M1?
    If you have a misfire (due to plug) it will set a code and a check engine light. An overly rich condition would not necessarily be caused by a plug. This would be more by a MAF or injector. Modern syn oil can go way longer than 5K. But we already know that right?
    With so many tools available to determine useful life and condition of things from spark plugs to oil and yet the manufacturer dictates on how to waste ones money.
    I was just asking the questionn and no offense meant to those who choose to do the manual thing. I guess thats why I always buy things a couple years old.
  16. Mar 21, 2011 at 8:31 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    This ^^^^^
    To add, at 30k miles, the plugs are used up pretty good. Comparing the electrodes of the worn vs. new plugs shows a great difference. Will tehy still fire at 80k? Sure. But performance is going to be diminished. Like metioned, for an hours time, why not replace them? Checking the plugs at 30k is a good way to see how the engine is doing anyway.
  17. Mar 21, 2011 at 8:47 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Mine looked similar at 40,000 miles (I was a little late on the plug change). My driver side gaps (NGK) were .060 - .065, the passenger side gaps (Denso) were .040 - .045 and looked a little better. I put back all Denso plugs so I guess I'll see next time if the drivers side is doing something funky or if the NGK plugs just didn't last as long.
  18. Mar 21, 2011 at 8:49 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    OME lift. 884 coils, 1.5" AAL's installed on nonTSB leafs. front diff drop kit.
    plugs are cheap and easy. i like tinkering, and tinkering on cheap and easy stuff is much better than difficult and expensive stuff. always.
    it fills a void..haha.
    those plugs look normal, well like mine..which i pulled at 40k.
  19. Mar 21, 2011 at 8:55 AM
    wyotaco06
    wyotaco06 Well-Known Member
    Offroad 4x4 06
    Those plugs look almost identical to mine after a 30K change, with one of the plugs a little darker than the rest...I think mine was the driver side rear.
    Just a little side question
    My friend who has a 2008 tacoma with the 4.0 recently did his plugs after I suggested he should, he was at almost 75K, and gave him the TW link that chris 4x4 posted with the pics.
    That was a little over a month ago and after two full tanks, he claims that his gas mileage is worse, from around 20 to 15mpg
    I think that it may be a loose plug. Wouldn't a loose plug cause the CEL to come on though?? Guess his right foot might have gotten heavier since the plug change also..:cool:
  20. Mar 21, 2011 at 9:00 AM
    Watari06V6
    Watari06V6 Faster than a speeding ticket
    Wounded Knee
    TRD-V6-SR5-06
    Right on Chris- i replaced my plugs at 80K (they still look fresh as a daisy) but my truck acceleration was slow. after the change i thought i have 6 Secretariat in there! :D
    "If it ain't broke, why fix it."
