First post, '14 Tacoma lift question...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bisons36, Nov 20, 2015.
  1. Nov 20, 2015 at 8:30 PM
    talofox
    talofox Northwest Member
    Justin
    Port Angeles, WA/Minot,ND
    '07 DCSB 6spd
    If the lift uses new spindles that are beefier than the stock ones or flips the tie rod ends you would probably have to go up to a 17" wheel. Otherwise I don't see how it would be required. What size tire are you going to? They probably just want you to get a wider wheel to better fit some wider tires. I think skinny rims and wide tires looks silly but that's just my opinion.
  2. Nov 20, 2015 at 8:33 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    EXACTLY STAY AWAY FROM 4WP
  3. Nov 20, 2015 at 8:33 PM
    JohnNP
    JohnNP ForeRunners Future Wife :)~
    Hobe Sound, FL
    2014 DCSB 4x4 TRD Sport JBL
    As of 11/4/15 1) Tailgate Anti-Theft Mod 2) ND4SPDBP's Fog Light Mod 3) Devil Horn Emblem 4) Weathertech Digital Floor Liners 5) ADD W-1 Vers 2 Baffled Oil Catch Can- constantly surprised at how much oil this thing captures 6) Weatherproof Under the rail LED bedlights Warm White (by Mattgecko) with hidden small cubby switch 7) Sliding Window Security Bar 8) Hood Lighting Kit Warm White /Pro Kit (by BeeRad) 9) Morimoto mini D2S retrofit HID lights w/ 55W ballasts and XB 5000k bulbs from TRS- one of the best modifications I have ever made, blows the stock lights out of the water 10) ImMrYo bracket 11) Scangauge II 12) Autodimming mirror w/ Compass/Temperature/Homelink 13) Bedrug Mat and Tailgate rug. 14) Pop n Lock Power tailgate lock w/ bolt coded to factory key. 15) Map Light w/ Door Mod 16) BakFlip HD Tonneau Cover 17) 35% Front windows ceramic tint - a very good match to factory 19) Gerber machete, because every truck needs a machete 20) Various flashlights, really love my Black Diamond Miner Mole Headlamp 21) AFE Pro Dry drop in filter 22) removed secondary charcoal air filter 23) Back up light Mod- I used the light bulb as found on page 14, 35W from Lowes. https://www.tacomaworld.com/threads/886-backup-light-mod.209578/page-14 24) Hi-Lift Off Road Recovery Kit- thank you TW Secret Santa 25) Tailgate Seal 26 interior footwell/rear seat dome light controlled LEDS https://www.tacomaworld.com/threads/footwell-and-rear-seat-led-light-dome-switched-mod-lots-of-pics.409428/#post-11529460 27) pelfrybilt aluminum front skid 28) morimoto XB fog lights 29) mob town front recovery bar with 2 Smitty bilt D-Rings 30) 48" Extreme Hi-Lift Jacks w/ ATO rail mounts 31) Prinsu rack 32) Rigid D2 Ditch lights 33) 40" Heretic LED bar on Prinsu Rack 34) Kawell x 6 side lights 2 spot and 1 wide per side 35) Rigid SRQ2 x 2 rear facing asshole/backup lights 36) NSA switch panel to 150amp bussman fuse on custom made mount 37) 267/70/17 BFG KO2's in C rating Pending installation 1) Rock Lights Upcoming/Possible Mods 1) Katzkin Leather Seats in black/ice grey (supposedly better factory match for the 2014) w/ Degreeze heater/cooling and TRD stitched into the seat faces thru jhuey - once I get to Arizona will buy them and have him install them 3) Total chaos UCA's 4) Kinda want to get some of the 2016 TRD Sport Rims or the grey TRD wheels the FJ cruiser/4Runners have. 5) BAMF LCA Skids 6) ICON or KING coilover 8) BAMF hidden grill light mounts 9) 20" or 30" LED light by Rigid Industries for behind the Grill. . 10) full leave pack maybe the Deaver 10 leaf set 11) ? Warn m8000 winch- really depends on if I end up doing more off roading 12) Possibly a console vault, not entirely convinced those are as secure as they would have you believe.
    Just saying!!
  4. Nov 20, 2015 at 8:40 PM
    Bisons36
    Bisons36 [OP] Member
    Keith
    2014 Tacoma 4x4 6spd
    I think it was procomp, nitro or something,hell I can't remember. Retailed at $275. When I told him what I was looking for he went right to it.
  5. Nov 20, 2015 at 8:44 PM
    talofox
    Justin
    '07 DCSB 6spd
    Ya I'm not familiar with the pro comp lift, I was just throwing some ideas out there. I'm 4x4 and got new spindles with my lift (drop bracket RCD) so it is possible. The shop definitely should have asked about tire size before claiming new rims were needed.
    Blackout14 likes this.
