First post and it’s a doozy!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sflanagan21, Jul 20, 2019.
  1. Jul 20, 2019 at 8:42 AM
    #41
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I would drive it a little more. My uneducated guess is, you have air in the system, and since it’s basically a hydraulic system with the torque converter that relies on fluid to shift gears, you simply have air bubbles in the system that is effecting the shifting. I bet once the air works itself out, it will be fine.
    sflanagan21[OP] likes this.
  2. Jul 20, 2019 at 8:44 AM
    #42
    sflanagan21
    sflanagan21 [OP] Active Member
    Thanks sir, I had it running with the AT temp light on solid when I drained out the 4 ounces after the incident.
  3. Jul 20, 2019 at 8:44 AM
    #43
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Thanks for always being there to help us out with transmission problems @gearcruncher!
    OP-spend any time here on TacomaWorld and you'll quickly find this man knows his stuff. Not to take anything away from anyone else, but his is the information to follow here.
    Blockhead, Jimmyh and sflanagan21[OP] like this.
  4. Jul 20, 2019 at 8:46 AM
    #44
    sflanagan21
    Awesome thanks!
  5. Jul 20, 2019 at 8:48 AM
    #45
    sflanagan21
    Apparently this wasn’t my first post, nonetheless it’s still a DOOZY haha! Thanks again for all of your insight.
    Skyway and wilcam47 like this.
  6. Jul 20, 2019 at 8:58 AM
    #46
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    Any update?
  7. Jul 20, 2019 at 9:01 AM
    #47
    sflanagan21
    What scan gauge do you recommend?
  8. Jul 20, 2019 at 9:03 AM
    #48
    HighCountryTacoma
    HighCountryTacoma Well-Known Member
    Colorado
    2017 DCSB TRD Off Road Quicksand
    Many people turn there head 180 degrees when reversing.
    Spare Parts and seanb06 like this.
  9. Jul 20, 2019 at 9:23 AM
    #49
    Trouble_The_Tacoma
    Trouble_The_Tacoma Well-Known Member
    Conrad
    Even with the drain plug out, there is still fluid in the system, I want to say it’s like 10qt or something crazy. Unless you’d been working at getting it completely empty.
    There is a chart online somewhere that talks about how increase of temperature decreases transmission fluid life. I would not think you damaged much if anything.
    wilcam47 likes this.
  10. Jul 20, 2019 at 9:24 AM
    #50
    Notoneiota
    Notoneiota Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    If the motor and tranny were cold, and she truly only moved it 30 feet, I would say any damage is minimal to none. As has been mentioned: get it back to its correct fluid level and scan and clear codes.
  11. Jul 20, 2019 at 10:09 AM
    #51
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    2nd Gen ATF Fluid Capacity:
    PzTank likes this.
  12. Jul 20, 2019 at 1:06 PM
    #52
    sflanagan21
    Here’s where I’m at... I performed a full flush per mountain lion thread. I bought a scanner and these are two the codes it’s throwing.
    P0746 pressure controlled solenoid
    A performance/stuck off
    P0771 shift solenoid e
    Performance/stuck off
    scottalot, spitdog and wilcam47 like this.
  13. Jul 20, 2019 at 1:35 PM
    #53
    Lester Lugnut
    PzTank, Jimmyh and sflanagan21[OP] like this.
  14. Jul 20, 2019 at 1:38 PM
    #54
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    have you disconnected the battery? may help that. Since its electrical, may be helpful to do a reset
  15. Jul 20, 2019 at 2:13 PM
    #55
    sflanagan21
    Yes I disconnect the negative for about an or so.
  16. Jul 20, 2019 at 2:31 PM
    #56
    sflanagan21
    So I took it for a about a 10 mile or so spin. The first mile seemed fine but I was never over 25, then I got it up to about 45 I could feel it shifting. When I came to a stop it down shifted hard. Took off again and it shifted fine. I got up to 70 and it never shifted into the OD. The hard down shifting went away completely but still no OD.
    Should I drive it some more and hope it clears itself out? Or is my best bet to throw in the towel and take it to a tranny shop? I want to drop the pan now and test those solenoids but I’m honestly over smelling tranny fluid for a bit haha.
  17. Jul 20, 2019 at 4:51 PM
    #57
    spitdog
    I think it’s time for a pro.
    Knute and sflanagan21[OP] like this.
  18. Jul 20, 2019 at 4:57 PM
    #58
    sflanagan21
    I concur bud...
    Trouble_The_Tacoma likes this.
  19. Jul 20, 2019 at 5:46 PM
    #59
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    Let it cool then get it to temp and check the level again.
    wilcam47 and sflanagan21[OP] like this.
  20. Jul 20, 2019 at 7:56 PM
    #60
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Good luck O.P.
