First Post and oil filter rant
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mlcasey, Sep 2, 2008.
  1. Sep 2, 2008 at 9:42 AM
    mlcasey
    mlcasey [OP] Active Member
    Goldsboro NC
    08 Red TRD sport
    Hi everybody this is my frist post. I bought my Taco about a month ago. Its a 2008 red D Cab TRD sport 6spd. I rolled over 1200miles last week and decieded to go ahead and change the oil and oil filter (even though i know its not in the manual i just wanted to get any metal flakes out asap) When I first saw the oil filter I thought sweet it will be easy to get to and it had that nice little catch with what I thought was a drain tube on the bottom. Little did I know that was acctually a pluged tube and didnt drain the oil rather all the oil from the filter got all over my belt, radiator hoses, oil cooler and down on my skid plate. I wiped most of it up and havnt had any problems or smoke yet. I was just wondering if any body else found this problem the hard way. Im planning on taking off the cap and putting a tube on there so it drains out under my truck. Thanks
    mlcasey
  2. Sep 2, 2008 at 9:46 AM
    ERdept
    ERdept Well-Known Member
    Yes, I found this out the hard way too. What I do now is to wrap a microfiber shop towel around the body of the holder. It absorbs the most, the best.
    Then I take another microfiber and have it at the ready and unscrew the filter, once off, I wipe right away.
    I was under the assumption that the filter, because of the way it was oriented with the opening down, had ALL the oil drained from it, but there still some residual left.
    Now I know. The position of the filter is conveneint though. Not behind the block under the car.
  3. Sep 2, 2008 at 9:46 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I use and empty water bottle to catch the oil. Before you remove the filter get an empty water bottle. Pull the rubber plug then wedge the bottle down where it can catch the oil, finally remove the filter it should all drain out.
  4. Sep 2, 2008 at 9:47 AM
    mudduck
    mudduck Nobody makes me bleed my own blood.
    the bluegrass state
    09 TRD Sport
    black painted wheels, tinted windows, sockmonkey decals
    i didnt that would happen either. good to know going into my first oil change.
  5. Sep 2, 2008 at 10:01 AM
    BeefTaco
    BeefTaco WESTern Alliance: NORCAL COAST
    Santa Cruz County Ca.
    +1
    You might want to take her down and steam clean the A/C clutch to make sure there is no oil left on it it is right below the oil filter I have seen a few fried clutch's because of this.;)
  6. Sep 2, 2008 at 10:05 AM
    Gene563
    Gene563 Well-Known Member
    Eugene
    Lanoka Harbor, NJ
    08 Double Cab, LB, TRD Sport
    TRD catback exhaust, Undercover hard tonneau, Vent visors, Husky liners, customized seat covers, front license plate bracket, rear suspension TSB, Eibach springs w 5100s@0, & General Grabber AT2 (265.70.17).
    Mine doesn't have any line on it, only the open nipple on the filter drain catch. I was going to run tubing down by the drain plug, but the water bottle idea might be better.
  7. Sep 2, 2008 at 11:05 AM
    Caddmannq
    Caddmannq MotoNerd
    California
    2012 PreRunner TRD Sport DC LB
    Undercover toneau
    Good info. I wondered how this thing would drain without making a mess.
  8. Sep 2, 2008 at 3:15 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    I find ingenious, drain the oil filter first, I got my tube from the auto part store, 3.5 feet in length, then the oil pan,take your time, and the mess will be very small if any
  9. Sep 2, 2008 at 5:38 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    I just get one of the neighborhood kids to lie on the ground under the truck with their mouth open. Works like a charm.
  10. Sep 2, 2008 at 5:59 PM
    TacoCo
    TacoCo Aspiring wrench monkey
    Colorado
    09 TRD Off-Road DC V6 Magnetic Gray
    Snugtop XV Shell, Yakima Rack, AFE Pro Dry Filter, Secondary Air Filter Removed, Michelin AT2's, Partially Debadged, HID conversion, Dynomax Super Turbo Muffler, Rear leaf spring TSB, Foglights always on Mod, URD Short Throw Shifter, Toytec Coilovers on the way!
    Haven't had to change my oil yet, but that seemed like the obvious solution to me upon my first inspection of the oil filter and catch. :p
  11. Sep 2, 2008 at 6:23 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    4 foot rubber 3/8" hose from Ace Hardware. $1.00 and no mess. :)
  12. Sep 2, 2008 at 7:36 PM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    I have a 20oz pepsi bottle sitting in the barn just to fit under the nipple once I pop the cap off and crack the seal on the filter. Works perfectly. Certainly less mess than ANY other vehicle I've changed the oil on. :D
  13. Sep 2, 2008 at 7:44 PM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Sierra Denali Ultimate, 6.2
    A few additions to make me feel cool.
    Okay, Just strange to me that some folks don't get the concept of changing the oil. Anyway I just drain it from the oil pan and then use the stuffed rag to cram down in the lip until after the filter is replaced.
  14. Sep 3, 2008 at 6:06 AM
    mlcasey
    Goldsboro NC
    08 Red TRD sport
    Yeah the rag thing might would work if your oil filter was empty cause that was alot of oil. Most of stayed in the catch or ended up in the skid plate where I just wiped it up with like 3 of those blue shop towels.
    I think Im going to do what chris4x4 said and just run the tube I just hope it doesnt get dirt in it and get clogged or it will be the same problem all over again.
  15. Sep 3, 2008 at 10:53 AM
    Angus_NB
    Angus_NB Well-Known Member
    Riverview, NB, Canada
    '08 Tundra DC SR5 4x4
    You didn't know it was plugged. So were you intending on letting the oil from the filter just run out on the ground?
    The water / soda bottle idea works well.
  16. Sep 3, 2008 at 11:12 AM
    mlcasey
    Goldsboro NC
    08 Red TRD sport
    Yeah...NO i had the oil pan down there and thought there was a tube running down there somewhere and was going to move it once i figured out where it was coming from. I also dont change my oil in the dirt it would have just made a puddle on the painted concrete floor that i would quickly put oil dry on. :cool:
