First post and question
Discussion in 'Audio & Video' started by RickO, May 5, 2010.
  1. May 5, 2010 at 2:19 PM
    RickO
    RickO [OP] Member
    Rick
    Minneapolis, MN
    08 Access Cab
    Intermittent wipers Alternating Turn Signals / Markers Tail gate theft mod 4x4 illumination mod
    Hi all,
    Picking up my (new to me) 2008 Tacoma Access Cab tomorrow and I want to change things right away. The truck comes with the stock HU (AM/FM/CD). I am told that a satellite receiver can be hooked up to this HU and can be accessed by pushing the AM button twice. Can anyone comment on this being correct? Also, can I get an aftermarket sat receiver to connect to this HU and if so what would you suggest? If I need a new HU, what would you suggest? My budget is tight so < $300 would be great.
    I did indeed search all threads I could find here and on TN but did not find the info I need.
    Thanks to all in advance!!
  2. May 5, 2010 at 2:24 PM
    BRP27
    BRP27 When I grow up I want to be just like Me
    So far south in Texas my feet are in salt water
    04 4X4 Tacoma SR5
    3 in Ultimate ToyTec, set @ 2.5 in. AAL PINCH Weld Mod ( beat the pinch weld over inside the fender) Painted the pinch weld on bottom of cab Black Hi Lift Knock off
    You can get Sat recievers for around $100 that access the HU using a FM signal. You lose bandwidth when you take Sat and convert it to FM.
    But I'll bet you want a unit that plugs in so you don't lose the bandwidth
    And welcome to the forum
