First post is a beat to death tire question.
Discussion in 'Wheels & Tires' started by jburetz, Jul 4, 2011.
  1. Jul 4, 2011 at 1:24 PM
    jburetz
    jburetz [OP] New Member
    Hello from a first time poster. I just got my first taco last week. Its a 2009 4 Door 4X4 TRD Sport. Currently it has 265/65/17 Dunlop Grandtrek tires(bald) on it and im going be getting some new tires in the next few weeks. Ive read all the post talking about the biggest tire, the best tire, etc. Now that im ready to start shopping i want to make sure of a few things. Sticking with everything i have now(Stock 2009 TRD Sport) the largest tires i could run without rub or having to do any major mod is a 265/70/17? Another question would i be better to stick with a 17" rim or drop down to a 16", ive read alot of post about more rubber than rim being better, why is this? Also being a sport model, will i have any problems running an offroad/all terrain tire? Thanks for any information you can provide.
  2. Jul 4, 2011 at 1:27 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Yes you can fit the 265/70/17 no problem, or 265/75/16 if you downsize to a 16" rim.
    I'm not really sure what you mean by "will I have any problems running an AT tire on a sport"?
  3. Jul 4, 2011 at 1:37 PM
    jburetz
    Well i was looking at getting some more aggressive tires(looking at duratracs, kelly safari tsrs, or a kumho road venture m/t) as opposed to the milder all season dunlops im running now. While i expect to loose the smooth ride and develop some road noise are there any other issues i may encounter with a mud/off road tire.
  4. Jul 4, 2011 at 1:38 PM
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
    You can run an AT tire, It will potentially ride a little rougher is all, depending on the tire you pick.
  5. Jul 4, 2011 at 1:40 PM
    jburetz
    Thanks for the quick replies.
  6. Jul 4, 2011 at 2:13 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    More sidewall typically provides a cushier ride. Then again on road it won't corner quite as well but in a truck it shouldn't really matter. It will also air down better off road.
    Tires for a 16 are typically cheaper as well. I'd just stay with stock wheels unless you want something else though.
    No issues with whatever tire you want to run. 265s should be perfect
  7. Jul 5, 2011 at 6:20 AM
    TacoMan709
    TacoMan709 Well-Known Member
    Newfoundland (the Rock)
    03 Tacoma Xtra cab 4x4
    285 km2s, 2.5" lift, mashed pinch weld, Flowmaster, wicked piss
    You are right about the maximum tire size for your setup. Go with the 16" rim if you can, just because more sidewall is not only better for a "cushier" ride, but it adds an extra inch between the side of your rim and the rocks when you're off road. Think about it: if you're spinning in a rut with rocks on each side, which wheel setup is gonna catch the rocks first?
    My buddy just upsized from 16" to 17" rims (we drive 1st gens) and after one wheel his pretty little streetlocks have definitely gained some "character." We did air down, though.
    But hey - in the end, who gives a friggin frig?
  8. Jul 5, 2011 at 6:28 AM
    TexasTacoma37
    If you switch to 16s just be aware that some brands and models of 16s do not clear the Tacoma brake calipers.
  9. Jul 5, 2011 at 7:05 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You only gain 1/2" of clearance between the ground and the bottom of the rim going from 17" to 16" rims (assuming overall diameter stays the same). You are correct though, 17's will hit the rocks before 16's.
