First Post, Need some help with a fuse location
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AKASL, Sep 10, 2020.
  1. Sep 10, 2020 at 9:08 AM
    AKASL
    AKASL [OP] New Member
    Hello All,
    I own a 2017 Toyota Tacoma TRD and I am having difficulty finding a particular fuse that controls the side panel exterior lights. I have the Type B light control switch with the DRL, Side Lights, and Low Beam controls located on the rotating switch left of the steering wheel.
    When I rotate the switch to the DRL position the DRL lights activate, when I rotate the switch to the Side panel position the lights do not activate. When I rotate the switch to the Low Beam position the Low Beam lights activate.
    Which fuse should I be checking in either the interior fuse box or the engine compartment fuse box?
    Thanks in advance,
    AKASL
