First post newb
Discussion in 'Technical Chat' started by trfcsux, Feb 16, 2018.
  1. Feb 16, 2018 at 3:42 AM
    trfcsux
    trfcsux [OP] Member
    2010 dcsb off road
    Hello fellas, new here but not new to Toyotas or 4wd. I just picked up a 2010 4wd DCSB off road. It has 70k and is surprisingly clean but it came with a problem. If I put it in 4wd it locks the rear locker, high or low doesn't make a difference. The rear locker button is not on and the dash light does not indicate that it is on but it is locked as far as I can tell. I have owned several trucks with arb lockers so I'm pretty sure I know the feeling of a locked axle. The dealer that it came from has given me 60 day 2000 mile warranty so if I can figure out what is wrong they are going to fix it, so the clock is ticking. Ant thoughts or help would be appreciated
    Thanks
    ChadsPride likes this.
  2. Feb 17, 2018 at 9:03 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Seems to me that the dealer should figure out what is causing it, not you.
    That being said, its possible the previous owner did some creative wiring to intentionally make the locker come on immediately. Check behind the locker switch, and around the actuator if anything looks non-stock.
