First Post: Solid Axle and Engine Swap
Discussion in '1st Gen. Tacomas (1995-2004)' started by Yotazilla 36, Sep 17, 2013.
  1. Sep 17, 2013 at 7:47 PM
    Yotazilla 36
    Yotazilla 36 [OP] New Member
    Austin
    Livingston, LA / Shamrock, TX
    01 Taco SR5
    3" suspension lift
    Ok, so here's the rundown.
    Current Condition:
    2001 Tacoma SR5 4x4
    2.7L 4 banger (300k+ mileage)
    5 spd tranny
    3" suspension lift
    Alright, here goes the good, the bad, and the ugly.
    The good, look at the mileage I have ;)
    The bad, engine is starting to give a little trouble, nothing serious tho.
    The ugly, time to replace:
    - front struts
    - passenger knuckle
    - brake rotors
    - brake pads
    - timing belt
    - rear shocks
    - all bushings
    - coil springs
    - all ball joints
    - tires
    - both cv axles
    All this being said, I have gone the route of getting another daily driver (82 c10 step side). Well, now it's time to show my baby the love and care she deserves and turn her into the beast she deserves to be. I have acquired a few things over the last few years I would like to incorporate into this build:
    -Dana 44 front axle
    -Ford 5.0L 302ci engine
    -Borg-Warner T18 manual 4spd tranny
    My plan is to do the sas and engine swap, 6" suspension lift, 2" body lift (not a fan, but required for most v8 conversions), 37" tires, and various other mods.
    I know the toyota engines are amazing, and I know a lot of people here will have negative things to say about my decisions.
    What I am requesting is useful links and information that will help me in my endeavors.
    Also, does the 4 banger come with the 21 or 23 spline transfer case?
    Thank y'all in advance for your help.
  2. Sep 17, 2013 at 9:49 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    awaiting the SAC gurus...but I am sure they will say the same thing, either upgrade the shafts in that 44 or sell the thing now and just get a 60, especially with that ford motor.
    at 300k, if you dont really want to go and do a full rebuild, and you know the ford engine is solid, hell go for it man!
    as for links, will have to be more specific on what you want. im assuming you are doing a basic leaf sprung front end? are you keeping the factory rear axle? What are you thinking for gears?
    Check out the Solid axle section on the forum, and start perusing pirate 4x4, that place is a gold mine
  3. Sep 17, 2013 at 9:54 PM
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
  4. Sep 17, 2013 at 11:10 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Agree with mark. Find a d60 especially with the big v8.
    And ya, leafs or 3 link?
  5. Sep 18, 2013 at 6:40 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    What's wrong with a SBC? :p
  6. Sep 18, 2013 at 10:07 AM
    Yotazilla 36
    Austin
    01 Taco SR5
    3" suspension lift
    Sbc = short block chevy?
    Also, I plan on running a leaf spring setup. I've never done much climbing.
    The only reason I said d44 is because I have one on hand. I would love to run a d60.
    I'm planning on running the stock transfer case BUT I'm not 100% positive what the best adapter is
  7. Sep 18, 2013 at 2:03 PM
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    Small block chevy? It would be cheaper than the Ford motor to build and what not
  8. Sep 18, 2013 at 4:14 PM
    Yotazilla 36
    Austin
    01 Taco SR5
    3" suspension lift
    Chevys are cheaper to build, and my personal favorite. However, Sbc require more modification than the ford, and I already have the ford motor lol
  9. Sep 18, 2013 at 8:58 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    oh well that's fair I suppose
  10. Sep 18, 2013 at 9:11 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    It sounds like it will be a build to watch. But i would think twice about the chain t case behind the 5.0 and the D44 if you plan on driving the 5.0 like it should.
  11. Sep 19, 2013 at 2:57 PM
    Yotazilla 36
    Austin
    01 Taco SR5
    3" suspension lift
    I'm going to post full progress. I just started redoing the interior. I'll post pictures of that as soon as I get a chance.
