First post: Toyota V6 6spd manual rev during shift?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by '16goingon'17, May 26, 2016.
  1. May 26, 2016 at 9:17 PM
    '16goingon'17
    '16goingon'17 [OP] Well-Known Member
    Trailslayer
    NoVA by way of NWA
    2017 TRDOR 4x4 DCSB MT
    JBA STD UCAs. 6112/5160 @6/5. Wheelers 1.5" 3AAL with Superbumps. BROG molle headrest covers. GMRS & Ham radios with roof-mounted NMO Laird Phantom antenna. Thinkware front/rear dashcams, FreshMexicanTaco's DMM, Meso's dome/map LEDs & Flipfob, Swingcase on driver side. Accumulator Delete Mod (ADM). Two-wheel drive Low Range Mod (2LM). Overland Tailor Tune (OTT) 7.0. Extra juicy oil spill on the bed mat.
    Currently I drive a 2011 Camry :(. Whenever I depress the clutch to shift into higher gears, the tach revs slightly up, maybe 50-100 RPMs before dropping down. Even if my foot is nowhere near the accelerator, it still revs up slightly during shifting.
    I was planning on ordering a '16 TRD OR 4x4 DCSB V6 with a 6spd manual, but the 6spd manual Camry experience has left a bad taste in my mouth about Toyota manuals now. I won't bother if the Tacoma the same issue.
    I've requested to test-drive one at the local dealers several times over the last seven months, but no one has offered me the ability to do that since apparently all are sold before they arrive. If anyone in Scottsdale, AZ has a 6-speed and wouldn't mind going for a quick drive around the block, please lmk. Thanks guys!
  2. May 26, 2016 at 9:37 PM
    nickj604
    nickj604 Well-Known Member
    Nick
    Vancouver BC
    2019 RAM 1500
    To be announced
    Hey there trailslayer
    I'm going to take a wild guess and say you don't have much mechanical back ground. And you haven't driven a lot of other vehicles that are standard. When your engine is turning your transmission and you let out the gas pedal and push the clutch in to shift there really isn't much holding the engine back. So it will Rev up a little bit it's not abnormal for that to happen. And if that's enough to turn you off of a vehicle I suggest maybe you go look at a versa
    venezian, Large, NMW 4x4 and 2 others like this.
  3. May 26, 2016 at 9:57 PM
    '16goingon'17
    Trailslayer
    NoVA by way of NWA
    Yeah, mostly just shadetree. I drove a '99 Ford Contour SVT before the Camry and I did all my own wrenching—new suspension (UCA/LCA/Stab bars/struts), driveshafts, brakes, UIM, LIM, engine mounts. Before that I drove a '02 WRX and only had to install a new radiator and brakes. All my vehicles have been manual, but none have revved up when I upshifted.
    jpb2 likes this.
  4. May 26, 2016 at 10:05 PM
    SilverBullet19
    SilverBullet19 Well-Known Member
    Scott
    Sacramento County
    2015 DCLB Prerunner TRD Sport
    My GTO is a 6 speed. I gotta ask how you even notice 50 RPM? Are you going by the tach, or feel? Can you hear it rev? Anyway...I'd do some research on it before discounting a Tacoma. Perhaps its something they program in, like a "rev helper" to help drivers avoid stalling out. It could be user error, it could be a bad MAF sensor (the MAF sensor went out on my GTO and caused rev issues. Sometimes a high idle, or a rolling idle. $20 fix). There's really a lot it could be.
    Bottom line, you're using a 2011 passenger car to judge a 2016 truck. Thats a big "apples to oranges" comparison, if you will.
    Simple solution: find a manual Tacoma and test drive it.
    Mr. Torgue likes this.
  5. May 26, 2016 at 10:12 PM
    AdventureKid
    AdventureKid Let's Go Places
    Jake
    Oceanside, CA
    17' DCSB TRD OR 4x4 6MT
    Camper Shell
    I really don't understand why something so nominal is a big deal to you. Are you trying to hypermile this truck or what?
    Also every time I down shift I always Rev match for engine breaking and save on the brakes...
    rockguitar316 and PROseur like this.
  6. May 26, 2016 at 10:19 PM
    '16goingon'17
    Trailslayer
    NoVA by way of NWA
    I know what y'all mean, it's really lame but it's still so annoying. I can hear the rev slightly and see it on the tach, but can't feel it. It is the first car that has been drive-by-wire (solenoid actuator vs. direct cable link), maybe it has something to do with that? And yeah I'm slightly exaggerating that it would be solely responsible for decision to buy the Taco.
  7. May 26, 2016 at 10:36 PM
    AdventureKid
    Jake
    Oceanside, CA
    Camper Shell
    Yea, there are a lot of annoying things in life, and no vehicle is perfect. What do you expect? This truck holds an awesome resale value and is extremely reliable. Even if you find it does Rev 50-100rpm while upshifting, it's really negligent in the big picture. Just trying to put things into perspective.
    George1441 likes this.
  8. May 26, 2016 at 10:53 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    So, if I can step in for a second, pretty sure its the same thing, its not an actual rev increase, its a rev hang. I dont remember the exact details, but Toyota built the rev hang in to pretty much all its manuals for MPG reasons if I recall. Something to do with maintaining revs for a second after you push the clutch in and let out the gas to burn off the extra gas. Something along those lines. If you drive it like a truck and shift it slowly, youll never notice. The only time I notice is when I'm trying to bang through the gears, and the only way to avoid it is to just pin it constantly and drop the clutch in each gear. Guess thats why I blew through my clutch in about 6k miles. But Im pretty happy with my URD Stage 3 now :)
    numbah57 and PROseur like this.
  9. May 26, 2016 at 10:57 PM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    Most all newer manuals do that, it helps to sync up the gears for the shift.
  10. May 26, 2016 at 11:00 PM
    '16goingon'17
    Trailslayer
    NoVA by way of NWA
    Interesting. This sound exactly like what happened with my Contour SVT. The guys over at Contour.org came up with a solution that I used for eliminating throttle hang by jamming a copper end cap with a drilled hole into the EGR valve's intake hose, thereby choking most of the exhaust air return that causes the throttle hang.
  11. May 26, 2016 at 11:23 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Camry's came with a manual in 2011? :confused:
    numbah57 likes this.
  12. May 26, 2016 at 11:26 PM
    eon_blue
    Azusa, CA
    oh and just so I have something constructive to add, I've driven manual Toyota's for the last several years (2 Scions, 1 Tacoma) and none of them have done this, at least not that I've noticed. Now I feel compelled to look for it though..
  13. May 26, 2016 at 11:42 PM
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    I second what @VolcomTacoma said. It's called rev hang. I would be shocked if the 3rd gen Tacoma didn't do it.
    Honestly most new (drive by wire) vehicles do this. My moms 2009 Jeep Wrangler does it too.
    I actually like it for when I'm shifting slow. I only really notice it trying to bang thru gears but it's really not a big deal. Kinda pulls you down into the next gear lol
    I'm intrigued that in 2011 you could get a Camry with a manual! Badass!
  14. May 26, 2016 at 11:46 PM
    Ihatetacomas
    Ihatetacomas Because tacomas hate me
    Dylan
    Elko NV
    '12 White LB TRD Sport
    Used @ 23,283 Volant Intake (w/ scoop)(removed August 2016), BAKFlip G2 Tonneau Cover, (drain tube mod), Pop & Lock Tailgate Lock, Stampede Vigilante Premium VP Series Hood Protector, 5lb Extinguisher, Shovel & Axe mounted in bed, Shok Industries Sound Deadener, Mercury: (K62, MGR-1200, MGR-495) Triton 8" Subs, Custom-Made: Sub Box, Speaker Templates, Vapor Barrier, All-Pro Bumper w/Kickouts, hidden trailer hitch, wooden cup-holder Misc: Knukonceptz RCA, speaker, and power wires, Big 3 Upgrade, a very full Husky technician tool box
    Sorry but someone had to say it
    3rd gen probs ;)
    daddy_o and dakotasyota like this.
  15. May 26, 2016 at 11:47 PM
    numbah57
    numbah57 GIVE THE MALL A BREAK...WHEEL THAT SHIT
    kahai
    Maui, Hawaii
    09 tacoma 2.7 Beaten not Babied
    URD ARB G2 PELFREY BAMF LCE AFE
    ^^^^ they all said it.
    My 2009 taco does it as well. I kinda got used to it.
    Ihatetacomas likes this.
  16. May 27, 2016 at 3:04 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Mine does it, but it's really not that noticeable unless you're winding it up in each gear.
    The delay in throttle response is way more annoying, especially when doing a quick rev match when downshifting.
    Meh, you just gotta stomp on it sometimes :D
    Frank
  17. May 27, 2016 at 4:34 AM
    aquasurf
    aquasurf Member
    Yes, it is a relatively new "feature" found in many recent model cars and trucks and quite annoying to some drivers, including myself.
    My explanation of rev hang with videos and charts is here.
  18. May 27, 2016 at 4:41 AM
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    its the stupid computer and electronic throttle ???
  19. May 27, 2016 at 4:44 AM
    FishaRnekEd
    New Orleans, LA
    we used to need the foot skill to keep revs where you want them...
    SilverBullet19 likes this.
  20. May 29, 2016 at 2:04 PM
    '16goingon'17
    Trailslayer
    NoVA by way of NWA
    Yeah I learned to drive using heel-and-toe downshifting to match revs. I think this is about emissions :/
