First Repair @ 145,600 miles
Discussion in 'Technical Chat' started by genxer36, May 2, 2010.
  1. May 2, 2010 at 4:50 PM
    genxer36
    genxer36 [OP] Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    My truck had a strange vibration at low speed. I emailed Chris4x4 & he mentioned Universal joint as a possible issue. Sure enough he was right as usual.:bowdown:
    The Universal joint connecting the drive shaft to the transmission had failed. One of the pins was coming apart. The guys at Goodyear showed me the failing part. I'm glad I didn't ignore it. $200 to have it repaired. Stealer probably would have charged $500. Not too shabby for 145,600 miles & this was my first repair.:)
  2. May 2, 2010 at 6:00 PM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    Glad you got it squared away. This is good news for people starting to doubt the reliability of the second gens.
  3. May 2, 2010 at 6:29 PM
    genxer36
    Sean
    Bethlehem,GA
    Still a damn good truck. Paid for, only costs me gas & maint.
  4. May 4, 2010 at 3:22 PM
    Peru
    Peru Well-Known Member
    Jonathan
    Redmond WA
    SR5 -- V6 -- 2005 -- 4X4
    none
    How often did you grease the parts in question?
  5. May 4, 2010 at 3:37 PM
    genxer36
    Sean
    Bethlehem,GA
    There aren't any zerk fittings on the U joint on the 2nd gen trucks. I was told they don't get greased.
  6. May 4, 2010 at 4:35 PM
    Peru
    Jonathan
    Redmond WA
    none
    maybe I am missing something here but on my 07 there are several on the whole driveline.
    I have to be missing something here 145k -- what year, when did the 2nd gens start being sold?
  7. May 4, 2010 at 4:43 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    2nd Gen Prerunners have no grease zerks on the driveshaft.
    2nd Gen 4x4s have 5, 3 on the rear shaft, 2 on the front.
  8. May 4, 2010 at 4:48 PM
    Peru
    Jonathan
    Redmond WA
    none
    Thanks for the clarification -- sill 145k and one u-joint which does not get greased is IMO very good
  9. May 4, 2010 at 5:01 PM
    genxer36
    Sean
    Bethlehem,GA
    Thanks for the info. I wasn't sure on the 4x4.
    Yes I am pleased with my truck. 146k as of today, & that is the only repair.
  10. May 4, 2010 at 5:16 PM
    jandrews
    That's just Toyota for you. My Matrix has 170k and the only repair was a catalytic converter that went bad in the first two months and Toyota had a TSB for it.
    Since then (it's an '03, bought late '02), I haven't had to repair anything, NOTHING, just regular maintenance. And it has been thoroughly used, possibly occasionally abused, depending upon your definition. Still buzzing around in it as my daily driver, and plan to keep it til it finally gives up the ghost....300k on the original engine/transmission is my goal.
