First Scheduled Maintenance - When and what they do?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kungfupanda, May 26, 2011.
  1. May 26, 2011 at 8:56 AM
    kungfupanda
    kungfupanda [OP] Well-Known Member
    So Cal, Cerritos
    2010 4x2 Taco TRD SPORT
    HID - Low, LED interior lights, LED license plate light, HID Yellow fog lights, Access Limited Roll Cover, Hitch/Tow Package, Ceramic Tint, Wet Okole's, Magnaflow Exhaust, DFab Bars, Bully Bar Back, HID Yellow Fog Lights
    I have a 2010 TRD Sport 4 Door with 18K, when do I need the first major maintenance? Is there anything that you can do to save money on the first maintenance (other than change oil)? If there is a thread on this please point me there. Thank you!
  2. May 26, 2011 at 9:26 AM
    EEtaco
    EEtaco Well-Known Member
    North Carolina
    09 V6 Prerunner
    I think the first maintainence is at 30k which invloves replacing the spark plugs, which is easy to do (There's also a guide here somewhere). In general follow the maintainence guide that you should have gotten with the manual.
  3. May 26, 2011 at 9:28 AM
    wmdpowell
    wmdpowell Well-Known Member
    Bill
    Selkirk, NY
    4x4 reg cab, 5 speed
    Better tires Hurcules Terra Track, trimmed front mud flaps, (access limited tonneau-took off) softopper, ats running boards, Piaa fogs, window vents, Wireless thermometer, extra bed rings, valley hitch
    at 30 for a 2011:
    30,000 miles or 36 months​
    Check installation of driver’s floor mat
    Inspect and adjust all fluid levels
    Lubricate propeller shaft (4WD models and all Prerunners with 4 cylinder engines)
    Re-torque propeller shaft bolt
    Replace engine air filter
    Replace engine oil and oil filter ​
    Replace rear differential oil (Prerunner and 4WD vehicles with optional limited slip
    differential only)
    Replace spark plugs (1GR-FE engine only) ​
    4
    Rotate tires
    Maint Maunal for 2011 http://www.toyota.com/t3Portal/document/omms/T-MMS-11Tacoma/pdf/2011_Tacoma_WMG_lr.pdf
    I imagine 2010 is similar but Toyota Care website has specfics; essentialy the paper manual in computer form.
  4. May 26, 2011 at 10:24 AM
    kungfupanda
    So Cal, Cerritos
    Thank u gentlemen!
  5. May 26, 2011 at 10:42 AM
    nomad_archer
    nomad_archer Well-Known Member
    Trevor
    Brickerville (Lititz), PA
    08 DC Tacoma V6 SR5
    Thats the same for my 2008 DC Sr5 4x4 so Im guessing they are identical. Thank goodness I dont have the lsd. I really didnt feel like changing the oil in there.
    Also get the denso plugs from the dealer they where cheaper for me then autozone and advance auto and they didnt have to be ordered from the factory. Good luck. Im doing my 30K this weekend and it should be easy. Hardest part will be the plugs because there is no lsd for me..
