First service at 5000 miles
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaTD13, Sep 10, 2013.
  1. Oct 4, 2013 at 1:17 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The service writer is full of crap. The 2.7 liter 4 cylinder takes full synthetic at 5,000 mile interval or 6 months whichever comes first. I had my oil changed at the dealer at 6 months with only 3,800 miles on it.
    Link: http://toyota.custhelp.com/app/answers/detail/a_id/7604/~/what-are-the-oil-change-intervals-using-synthetic-oil%3F
    What are the oil change intervals using synthetic oil?
    Only Toyota vehicles in which 0w-20 synthetic oil is required (except for the 2TR-FE & 3UR-FBE Engines*) have been approved for extended oil change intervals of 10,000-miles/12-months. (However, you should continue to check the oil level regularly and top off if needed. That will help your engine get the full benefit of synthetic oil.)
    • Vehicles in which 0w-20 is an option to 5w-20 mineral oil, (or 5w-30), will continue to require 5,000-mile/6-month oil change intervals, even if 0w-20 oil is used.
    • In the case of vehicles with 10,000 mile oil change intervals, the 5,000 mile service interval has not been eliminated. The traditional 5,000 mile maintenance procedures (such as tire rotation) will continue to be required, and the fluid levels (such as brake fluid) will need to be checked and adjusted at this time.
    • If the vehicle operation meets the standard criteria for "Special Operating Conditions" such as: driving off-road, on dirt roads, towing a trailer, making repeated short trips under 32˚ F, or extensive idling; the engine oil must be replaced at 5,000 mile intervals, regardless of what type of oil is used.
    *The 2TR-FE (4Runner / Tacoma) and the 3UR-FBE (Flex Fuel Tundra / Sequoia) are the exceptions to this new change interval program; these engines have not been approved for the 10,000 mile interval at this time. A 5,000-mile/6-month oil change interval is still required for these vehicles. Also, the Flex Fuel 3UR-FBE requires a 2,500 mile interval when operated on E85.
    This is what is listed as the 5,000 mile 6 month service for the 2014 Tacoma with the 2.7 liter engine:
    5,000 miles or 6 months
    Check installation of driver’s floor mat
    Inspect and adjust all fluid levels
    Inspect wiper blades
    Replace engine oil and oil filter
    Rotate tires
    Visually inspect brake linings/drums and
    brake pads/discs
  2. Oct 6, 2013 at 7:28 PM
    joelt
    joelt Well-Known Member
    Joey
    Anchorage
    '17 TRD Off-Road
    Just did my oil change at 5000 miles...that dipstick is useless!
