First set of rear brakes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CorrosiveTendency, Nov 24, 2019.
  1. Nov 24, 2019 at 2:04 PM
    CorrosiveTendency
    CorrosiveTendency [OP] When up to your nose in shit, keep your mouth shut
    Nathan S.
    Schuylkill Co, Pa
    05' DblCab SB Speedway Blue
    OME 885's, Locker Mod. Bilstein 5100's on 4 corners
    So at 220k miles my truck has finally failed an annual inspection for rear brakes. I figured I would tackle this myself.
    It took me 45 minutes and retapping the bolt hole oversize because I stripped it out, heat, a brass drift, 4 lb mallet and a lot of beating to get each drum off because they were siezed onto the hub from never being off for 15 Pennsylvania winters.
    Overall, not too bad for never doing brake shoes before. Only one bloody knuckle and few curse words. I still had the ambition to weld a cracked exhaust down pipe bracket.
    Just finished adjusting them. Here is to another 200k miles.
    JC15Taco and EatSleepTacos like this.
  2. Nov 24, 2019 at 2:14 PM
    IL Capo
    IL Capo Well-Known Member
    Sidney BC Canada
    Congratulation on a job well done!
    JC15Taco likes this.
  3. Nov 24, 2019 at 2:15 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Congrats, drums are annoying, especially getting them all adjusted.
  4. Nov 24, 2019 at 3:11 PM
    GorgeRunner
    GorgeRunner Out There
    2005 PreRunner
    I grew up in Cleveland. I thought rust came on new cars. Crawling under the car, always a joy.
    I would either adjust the rear brakes backing up and using ebrake or, in the summer, manually adjust the rear brakes. Rear brake parts will move and not rust away and truck will stop better. Front disc brakes do most of the stopping, the rear drums need a little attention or the shoes won't even hit the drum.
  5. Nov 24, 2019 at 7:46 PM
    JC15Taco
    JC15Taco Well-Known Member
    Jeff
    SK, Canada
    '15 TRD DCLB
    Not a real nice job...I did it several times. Congratulations on doing that....dirty job, but satifying!!
