First snow
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Beerline123, Jan 6, 2015.
  1. Jan 6, 2015 at 6:07 PM
    #41
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    This ^^
    Just turn your brakes completely off, they suck
  2. Jan 6, 2015 at 6:08 PM
    #42
    StickShifty
    StickShifty Well-Known Member
    New Jersey
    2012 AC 4WD 6SPD
    i don't see the big issue, my truck stops just like any other car i have driven in the snow.
    Tires, tires, tires.
  3. Jan 6, 2015 at 6:09 PM
    #43
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    I believe that ABS is acting up, there's too many to just dismiss it. However, I also believe a large number of these people locked the tires up and are blaming ABS.
    I drive in the snow/ice ALOT and have never once had an issue with my ABS. I've locked the tires up sure, but I have never had the ABS release the wheels at a low speed on ice.
  4. Jan 6, 2015 at 6:11 PM
    #44
    Hair Missile
    Hair Missile Well-Known Member
    VT
    2014 DCSB TRD OR
    Lund Genesis Elite Tri-Fold tonneau, FJ Trail Team Wheels, Weathertech floor liners, Wet Okole seat covers, OEM bed mat, ND4's Fog Light Anytime Mod, LOTS of Poorboys EX-P paint sealant ;-)
    General Altimax Arctic FTW!!
  5. Jan 6, 2015 at 6:11 PM
    #45
    teneighty
    Same here, I'm on Ice and snow 4-5 months a year and never had a problem...
    I'm guessing driver error? :notsure:
  6. Jan 6, 2015 at 6:12 PM
    #46
    teneighty
    awesome tires! ^^^ had them on a few of my cars
  7. Jan 6, 2015 at 6:13 PM
    #47
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    I have an 01 4x4 TRD. I've had the same kind of ice situation at those same tracks in years past. It always stopped!!! Sometimes wasn't pretty,,, but,,, it stopped. Onetime it was (sideways),,,, but it stopped.:)
  8. Jan 6, 2015 at 6:14 PM
    #48
    Fightnfire
    Marysville, WA
    Have we found any common denominators? Oversized tires?
    "If your car or truck has antilock brakes (ABS), vehicle manufacturers advise buying new tires that are the same size as those installed at the factory. The reason: the diameter of the tires affects how the wheel speed sensors read, which affects the operation of the ABS and traction control systems. Installing different-sized tires in the front and rear can also impact the operation of antilock brakes. (You’ll know that the ABS has been deactivated when the ABS warning light comes on.)"
    http://www.mountainviewtire.com/new...ffect-braking-handling-and-your-odometer.html
    EDIT: In looking around a little bit it seems to be a very known problem that larger tires than stock can cause ABS to be over sensitive...
  9. Jan 6, 2015 at 6:23 PM
    #49
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    ABS INCREASES stopping distances on low traction surfaces : FACT
  10. Jan 6, 2015 at 6:24 PM
    #50
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
  11. Jan 6, 2015 at 6:24 PM
    #51
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    YELLING INCREASES THE CORRECTNESS OF STATEMENTS ON THE INTERWEBS
  12. Jan 6, 2015 at 6:28 PM
    #52
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    ABS causes a dangerous understeer condition. I've had it happen twice, hit the brakes to turn ABS comes on and the truck hardly turns headed for the ditch, I take my foot off the brake truck turns as intended. To slippery to stop but not slippery enough to lose control while turning. The ABS is to sensitive!
    Maybe, but common sense ain't so common.
    Click click click click click click click click click click click click click click...
    Yea, so...
    Maybe one day your ABS will fail and you'll stop better:rolleyes:
  13. Jan 6, 2015 at 6:31 PM
    #53
    robssol
    Rob
    S. Wisconsin
    265/65R17
  14. Jan 6, 2015 at 6:32 PM
    #54
    robssol
    Rob
    S. Wisconsin
    Stock size
  15. Jan 6, 2015 at 6:33 PM
    #55
    robssol
    Rob
    S. Wisconsin
    ABS SUCKS!!
  16. Jan 6, 2015 at 6:35 PM
    #56
    33yrsoftoys
    joel
    mid Michigan
    I sure hope so. Probably sooner,,, than later,,, cus I'm gonna CUT that friggin wire!!!!:):):):eek:
  17. Jan 6, 2015 at 6:35 PM
    #57
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    I've never had trouble on road with my ABS :poking:.
    PREPARE!!!! :crapstorm:
    Seriously, my trucks ABS must of been put together on a Wednesday because I'm having no issues in the snow and ice we've been bombarded with this year.
  18. Jan 6, 2015 at 6:36 PM
    #58
    robssol
    Rob
    S. Wisconsin
    Agree!
  19. Jan 6, 2015 at 6:39 PM
    #59
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    The picture isn't enough? Studs = traction on ice. Less "click click click". More stopping.
  20. Jan 6, 2015 at 6:43 PM
    #60
    robssol
    Rob
    S. Wisconsin
    Ha ha. Didn't even see the studs. Where did you get them? But I don't think they are legal here:notsure:
