First solder job...help please (resolved)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ensemble88, Oct 18, 2018.
  1. Oct 18, 2018 at 7:09 AM
    Ensemble88
    Ensemble88 [OP] Well-Known Member
    San Diego, CA
    2017 Black OR DCLB
    King suspension, SSO bumper w/winch, Pelfreybuilt sliders, morimoto fogs
    Hey guys. So I got a rexxing dash cam a while back and decided to upgrad to a new one. The kdlinks R100. kdlinks uses the cig lighter for power. I wanted to use the empty fuse spot under the driver's side for power all the time like I did with the rexxing. To use the parking feature.
    Problem is, klinks uses a different power plug than the rexxing so I figured I'd just solder the connector end I need onto the existing wiring harness. It's just a black and red wire so shouldn't be hard...
    Now I've never soldered anything before, so went and got a little solder iron and flux etc. to try and figure out how to do this thing.
    IMG_20181017_174921.jpg IMG_20181017_175025.jpg IMG_20181017_175406.jpg IMG_20181017_181419.jpg
    I electrical taped each wire and reinstalled...plugged it in to the kdlinks and...no power light comes on. Damn.
    So I tested it with a multimeter. The voltage seems to constantly vary, it never settles on a single amount. I went back and there's a fuse inline with the harness on the red wire. I think this might be what is causing it but I'm not sure. What do you guys think? Is it the fuse, or just my shitty solder job :confused: If I delete the fuse I don't have much wire left to play with on that end.
    Or could it be something else?
    Pic of the fuse
    9TRDTCO likes this.
  2. Oct 18, 2018 at 7:15 AM
    Sch0227
    Sch0227 Well-Known Member
    Steven
    Dallas, TX
    2017 TRD Parts bin
    Sharks with lasers
    In the future throw some heat shrink on those wires before soldering them, to cover / protect after. Electric tape is caca.
    Is the voltage changing after the fuse? Have you tried changing the fuse? It may also be a poor connection between the wire and fuse holder. If you move the wire back and forth at the fuse holder does the voltage change? Check resistance on the fuse, if it's good, then plug everything in and start bending the wire back and forth gently at all connections and when it powers on, or off, youce probably found the weak link.
    9TRDTCO and Ensemble88[OP] like this.
  3. Oct 18, 2018 at 7:18 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Could be a lot of things. Do you get power to your new fuse, do you get 0 or near 0 resistance between your solder joints, did you tap into a power line that is always on/hot or did you tap into a line that requires the key in accessory.
    Ensemble88[OP] likes this.
  4. Oct 18, 2018 at 7:19 AM
    mhornco
    mhornco Well-Known Member
    Maybe a dumb question, but do both cams use the same voltage. The mini USB plug (rectangular in pic) is likely 5 volts. Is the other same voltage as well? If they aren't and you switch harnesses things wont work
  5. Oct 18, 2018 at 7:31 AM
    Ensemble88
    San Diego, CA
    2017 Black OR DCLB
    Yeah I learned that one the hard way, heat shrink all the way. Also, I'm cutting back a lot more of the black outer insulation next time, felt cramped the whole time I was doing the job...
    No resistance between red solder joint
    Power line is the unused always on 12v source on the driver's side fuse block
    Hmm, well I know cig lighter is rated for 12v. Unless there's a mini transformer built into the cig attachement, it should be shooting out 12v I would think. I will try this too.
    Inline fuse is a glass 3amp, 250v, not blown, and no resistance across it.
    ok it'll take me a bit to try all these things out and I'll be in class for the next few hours. Thanks for the quick responses guys. Looking forward to figuring this out.
  6. Oct 18, 2018 at 7:35 AM
    Ensemble88
    San Diego, CA
    2017 Black OR DCLB
    Well shit...it is the wrong voltage after all. :facepalm:
  7. Oct 18, 2018 at 7:50 AM
    Deacon Blues
    Deacon Blues Well-Known Member
    Colorado
    2017 SR5
    You're using rosin core solder yes?
  8. Oct 18, 2018 at 7:53 AM
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    Yeah the new cam need s 5v. Your are now giving it 12v.
  9. Oct 18, 2018 at 7:55 AM
    ProForce
    Anthony
    Alaska
    Put it back how it was, solder wire onto to sig lighter plug. Tape it up, then connect those new wires to the truck. Hide the cig plug behind dash somewhere
    vicali likes this.
  10. Oct 18, 2018 at 8:04 AM
    Sch0227
    Steven
    Dallas, TX
    2017 TRD Parts bin
    Sharks with lasers
  11. Oct 18, 2018 at 8:04 AM
    Ensemble88
    San Diego, CA
    2017 Black OR DCLB
    I think so, but I am using flux on the wires just in case. Not sure what kind of solder came with the kit.
    Yep! Well Amazon is selling a kit with the transformer I need with the mini USB for the same price as a transformer by itself so I think I'll just buy the kit. Thanks for your help all and I learned a few things so not a total loss. :)
  12. Oct 18, 2018 at 8:07 AM
    Deacon Blues
    Colorado
    2017 SR5
    The rosin core is the flux, ditch that tub of goo.
    I doubt they gave you acid core but who knows, that might be a "plumbing kit".
  13. Oct 18, 2018 at 9:09 AM
    Ensemble88
    San Diego, CA
    2017 Black OR DCLB
    AUCEE Dash Cam Hardwire kit, Mini USB Port,DC 12V - 36V to 5V/2A Max Car Charger Cable kit with Fuse,Low Voltage Protection for Dash Cameras https://www.amazon.com/dp/B077C1HTPK/ref=cm_sw_r_cp_apa_.-kYBbTY4HY7H
    I think this looks like the best option. I wouldn't mind soldering again but this seems easier and costs about the same. Thanks for the help guys :)
  14. Oct 18, 2018 at 10:11 AM
    9TRDTCO
    9TRDTCO Well-Known Member
    What kind of knife is this?
  15. Oct 18, 2018 at 11:02 AM
    Ensemble88
    San Diego, CA
    2017 Black OR DCLB
    It was a gift, called a SOG Kilowatt. It's pretty neat, this was it's first use. I think I'll stick to a dedicated wire stripper/cutter tool though. The 22 guage hole wasn't very good at stripping (a wee too big) and I ended up needing to delicately use the knife to skin the insulation from the actual wires.
    9TRDTCO[QUOTED] likes this.
  16. Oct 18, 2018 at 12:04 PM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    I always offset the two splices so they are not next to each other but staggered. Less chance of a short and less bulge.
