first tacoma 1999 2wd v6 pre runner 187k changing tie rods
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaJoe2004, Aug 31, 2025.
  1. Aug 31, 2025 at 3:08 PM
    TacomaJoe2004
    TacomaJoe2004 [OP] Member
    joseph
    1999 2wd v6 tacoma
    none
    im looking into changing my tie rods ball joints and had a few questions,
    should I just change the rods as a whole or am I able to replace the ball joint and keep the rod?
  2. Aug 31, 2025 at 3:25 PM
    noodles93
    noodles93 Well-Known Member
    Charleston, SC
    1999 Tacoma Prerunner 2.7
    Just get the entire tie rod, 555 makes solid replacements. Can you even get just the tie rod end ball joint?
  3. Aug 31, 2025 at 3:37 PM
    TacomaJoe2004
    joseph
    1999 2wd v6 tacoma
    none
    that what I was wondering thank you, it don't seem I can get that end ball joint without the rod
  4. Aug 31, 2025 at 3:38 PM
    t0p_d0g
    t0p_d0g My Tacoma is my happy place
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    While you are at it replace the lower ball joints they’re the weak part of the front suspension on these trucks.
  5. Sep 2, 2025 at 4:44 PM
    TacomaJoe2004
    joseph
    1999 2wd v6 tacoma
    none
    Will A premium party get me a couple thousand miles just need a temporary fix don’t want to be stranded on old OEM
  6. Sep 3, 2025 at 7:11 AM
    noodles93
    Charleston, SC
    I mean there’s the “do it right or do it again” methodology. I used Napa tie rods and they barely lasted 2 years. After paying for a new alignment it would have been cheaper to do the good parts first. But they worked fine until they didn’t.
    Andy01DblCabTacoma and t0p_d0g like this.
