First Tacoma... 1999 Extended 2wd 2.4L stick SR5... couple of questions....
Discussion in '1st Gen. Tacomas (1995-2004)' started by splice35mm, Mar 3, 2010.
  1. Mar 3, 2010 at 9:53 AM
    splice35mm
    splice35mm [OP] Member
    Tim
    Simi Valley, CA
    2002 Tacoma Xtra Cab 2wd
    I just bought this truck with 93,000 miles on it. Any particular service or other issues I should check? I'm changing all the fluids today, having belts checked. Anything else? I saw the "rusty frame" issue, but there doesn't appear to be an inordinate amount of rust anywhere.
    Was there a remote keyless entry available from Toyota when it was new? It has power door locks, but no keyless.
    What size speakers can I install in the four factory spots? I think it calls for the 5 1/4 inch round, but has anyone squeezed in 6 1/2 inchers?
    Thanks in advance for any advice. I parked my F-150 4x4 and will use this for commuting and hauling dirt bikes out to the desert. I already am in love with this little truck!
  2. Mar 3, 2010 at 10:01 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    the rusty frame issue...IF you have it...is from the inside of the frame out...being that your from Cali i highly doubt you have this issue though
    there shouldve been keyless entry available...cant remember if its RS3000 or RS3200
  3. Mar 3, 2010 at 4:02 PM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    There was no factory keyless entry option in the 1999 model year. If you wanted that function you had to add an accessory (e.g., Toyota or aftermarket alarm) to get it.
  4. Mar 3, 2010 at 4:10 PM
    scocar
    scocar Patron of the Farts
    Timing belt is due at 90K miles. Was that done?
    Oh, crap, sorry, you have a 2.4, not 3.4. My bad. I don't know what the 2.4 needs.
    Do you have any records? If not, you should do the whole 30K service. If it has a service record/schedule in the glovebox, check that.
    The other things I have discovered (on this site and on my truck) are steering rack bushings get soft, can replace with urethane (I think) Energy kit along withthe sway bar bushings, and the leaf springs are weak and sag. I'd like to do all this eventually...
  5. Mar 3, 2010 at 6:24 PM
    da0023
    da0023 The One, The Only
    Drew
    Alabama
    99 PreRunner SR5
    none
    the leaf springs are notorious for wearing out of the 1st gens (had it myself) the worst problem one would experience would be axle warp after coming to a hard/quick stop. being that yours is a stick ( that's what she said), you shouldn't experience it. anyhow, congrats on your tacoma, and I hope you enjoy it.
  6. Mar 3, 2010 at 9:27 PM
    splice35mm
    Tim
    Simi Valley, CA
    Thanks everyone! Most appreciated!
  7. Mar 3, 2010 at 9:33 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    We still get axle wrap on hard/jerky shifts. Its annoying.
