First Tacoma. Help Me Undo Previous Owner Mistakes.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoRayPNW, Dec 18, 2024.
  1. Dec 24, 2024 at 9:14 AM
    majpooper
    majpooper Well-Known Member
    Dennis
    North Carolina
    2022 Black TRD OR
    OTT Tune Front 2" lift OME 888 coil Bilstein 5100 DuroBump extended front bump stops Archive Garage extended rear bump stops Rear 1.85" lift Icon RXT leaf pack Bilstein 5100 SPC UCA DX4 16x8 +10 wheels 285/75R16 KO2 viper cut CMC sway bar delete exhaust reroute exhaust cut just past the rear axle U-bolt flip LFD engine skid plate RCI transmission and x-fer case skid plates Spindle gussets
    I have been pretty happy with RXT pack in that I got the lift I wanted but there seems to be a lot of complaints on this forum about them - there is a whole thread complaining about the squeaks. I haven't had the squeaking yet - and I have had them on since march and almost 15K miles. On the other hand my bed is empty 99% of the time so no extra weight on them either.
  2. Dec 24, 2024 at 9:43 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    Congrats on your truck purchase! No ideas from me it sounds like you have pretty much decided what you want to undo.
  3. Dec 24, 2024 at 11:15 AM
    majpooper
    Dennis
    North Carolina
    2022 Black TRD OR
    NICE! Wheels and tires are looking good. Yeah, I agree take off the block. I mean really you are good2go as is the 5100s though will definitely improve the ride. You have really thought this out - get a little lift up front and then if you decide you want a little more lift in rear you have several options - like me you are not putting a real weight back there so you won't have to do spend much to get a little bit of lift.
  4. Dec 29, 2024 at 3:46 PM
    TacoRayPNW
    TacoRayPNW [OP] Active Member
    2018 TRD OF LB Quicksand
    Spent the day putting the 5100’s on the front.. My advice is never buy the 5100’s as an unassembled set. Spend the extra money to have them pre assembled. What a nightmare install that was.
  5. Jan 15, 2025 at 6:23 AM
    TacoRayPNW
    Update & FYI :
    I re-adjusted the front to 1.5" (was 1") and I am running 275/70/r17 BFG KO3's. And I have the SCS Ray 10's with -12mm offset. For daily driving this setup is good however, if I hit a bump while turning I still get slight rubbing on the front bumper. I haven't cut anything to get these to fit but I can't run mud flaps in the front.
    Still running the lift block in the rear for now, I don't like it but it's not hurting anything at the moment.
    If I were to do this over again I would go with a 0mm offset wheel, I think that would help to eliminate all the rubbing.
    Next thing I want to do is get the Bak Revolver X2 Tonneau Cover.
    majpooper likes this.
  6. Jan 15, 2025 at 9:37 AM
    BoomerGVNG
    BoomerGVNG GET OFF MY LAWN
    long island
    2022 TRD SPORT DCSB
    My only suggestion would be to use 265's. But that ship has sailed, 275's will rub on the fender and UCA on anything over 265 (some 265 also rub) especially at -12mm offset.
  7. Jan 16, 2025 at 6:08 AM
    TacoRayPNW
    I haven't had any rubbing on the UCA's with the 275's just on the fender. The 305's were definitely a problem though
    BoomerGVNG likes this.
  8. Jan 16, 2025 at 6:22 AM
    TacoManOne
    TacoManOne YotaWerx Authorized Tuner
    Paul
    Liberty Lake, WA
    2018 Blazing Blue TRDOR DCLB Premium JBL
    YotaWerx Tuned, Meso stuff, JBL upgrades, Bilstein 6112/5160, RAS
    Good advice. That's why I got mine preassembled. Still have not put them on yet. But this weekend they WILL get installed. So fun working outside in Spokane area in the winter. :rofl:
  9. Jan 16, 2025 at 10:00 AM
    TacoManOne
    Paul
    Liberty Lake, WA
    @TacoRayPNW do you have a tune on your truck? Any tune is better than stock especially with large tires. Let me know if you would like to drive my truck and see what a difference it makes.
  10. Jan 16, 2025 at 10:03 AM
    TacoRayPNW
    I don't have a tune but I have been driving with the ECT on lately though and it helps slightly. I have considered a tune or pedal commander, I am just not there yet
  11. Jan 16, 2025 at 11:32 AM
    majpooper
    Dennis
    North Carolina
    2022 Black TRD OR
    OTT tune IMHO is a better option than the pedal commander route - a little more expensive but you get what you pay for. You can probably push the fender liner forward a bit which is not to hard to do - plenty of Youtube videos - shouldn't have to cut plastic but even that is relatively easy. Anyway would love to see some pics.
  12. Jan 16, 2025 at 12:36 PM
    TacoManOne
    Paul
    Liberty Lake, WA
    Yotawerx is a great option too.
  13. Jan 16, 2025 at 2:01 PM
    BoomerGVNG
    long island
    2022 TRD SPORT DCSB
    pedal commander is junk, I got OTT mild/medium for $450. Best money I ever spent. Master Yoda from NJ is great to deal with. It’s CARB compliant too, which is great.
  14. Jan 17, 2025 at 8:30 AM
    majpooper
    Dennis
    North Carolina
    2022 Black TRD OR
    Did the same here in NC mild/medium as well for $450 - I would recommend that anyone buying a 16-23 Taco OTT be the first mod they get - I have no idea how stock 4th gens are tuned so can't say.
    BoomerGVNG[QUOTED] likes this.
  15. Jan 22, 2025 at 8:50 AM
    #35
    TacoRayPNW
    So how does OTT tune work? I live in WA so I can't go to NJ lol is there a company that I can buy the tune from and just plug it in at home? Or do I need to take it in to a shop somewhere? My only goal with a tune would be better throttle response and improved mpg's
  16. Jan 22, 2025 at 8:54 AM
    #36
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    Check out this link for locations.
    https://overlandtailor.com/retailer-locations
  17. Jan 22, 2025 at 9:48 AM
    #37
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    You are not going to tune your way in to better MPG's. I have the KDmax tune, and while I like it, I understood a tune isn't going to improve the negative impact a lift and larger tires had on the MPGs.
  18. Jan 22, 2025 at 10:24 AM
    #38
    TacoRayPNW
    I understand that a tune wont turn this thing into a Prius by any means lol my thinking is that with less gear hunting and a tonneau cover I'm hoping to average 19 to 20mpgs on the highway. Right now I am in between 16 and 17 on average.
  19. Jan 22, 2025 at 6:03 PM
    #39
    majpooper
    Dennis
    North Carolina
    2022 Black TRD OR
    Not sure that's doable around town - I have 33s nothing in the bed no tonneau cover or anything. Typically getting 16-17 around town but have hit 19-20 range on some longer trips on the Interstate. Not sure where the OTT tune factors in but I will say I do have a lead foot but on long trips the variable cruise control probably helps and I stay at the speed limit. I love the OTT tune - no gear hunting and the truck just "feels" better but I honestly did not notice a significant difference MPG wise.
    Chew likes this.
  20. Jan 22, 2025 at 6:42 PM
    #40
    TacoManOne
    Paul
    Liberty Lake, WA
    you can try my truck if you want to see the difference. I am a Yotawerx tuner and in your area.
    Chew likes this.
