First Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by nicnicman, Jun 2, 2011.
  1. Jun 2, 2011 at 7:15 PM
    nicnicman
    nicnicman [OP] Active Member
    Maine
    03 Tacoma SR5 4 Cyl Manual
    Hi everyone!
    I've been thinking about buying an older higher mileage Tacoma.
    One that I'm looking at right now is a 2002 SR5 XtraCab Auto with 182,000 miles on it. It's been through the corrosion resistance program and had a new frame installed with numerous other parts. It seems to be very well taken care of, and I know that Tacomas are hailed for their reliability, but I am concerned that major issues could pop up in the near future when buying a truck with that many miles. What are some things that I should be worried about when buying a Tacoma with high miles. How do their Automatic transmissions hold up?
    Also, I'm buying from a private seller and he is asking $8700 (about $800 over book value). Is the high price justified with the new frame and other parts that Toyota installed? I will try to talk him down a little, but I he seems firm with the asking price.
    I guess overall I would like to know if buying a Tacoma with such high miles would be a wise investment. I have saved for a while for this money and I want to make the most of it.
    Thanks for the help.
  2. Jun 2, 2011 at 10:00 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    well the fact that it has had the frame replaced and all that other misc. stuff should do nothing to add to the cost, because that was all done for free under the toyota rust coverage extension. 187,000 is high but not abnormal. There are plenty of people here around 250k. So it will last a while, you will just have to have a good thorough maintence check to make sure everyhting important is A ok, and that the previous owner didnt run the mechanical into the ground. I dont have much experience with high mileage tacomas because mine has next to nothing. So hpefully the 250k guys will chime in.
    You did not indicate weather it is a 4x4 or 2wd. As a 4wd, depending on where you live that sounds about right. These trucks hold their value like crazy, great if your selling, crap if your buying. If its 4x4 i would try to get the 800 off to get to kbb price. But if its a 2wd i would defanitly talk him down ALOT. For a 2wd with that high of miles thats a bit high.
  3. Jun 2, 2011 at 10:11 PM
    nicnicman
    Maine
    Thanks for the reply. It does have 4 wheel drive. Tacomas do seem to run high around here, and I have noticed people with new frames use them as leverage to get more than blue book. However, I would at least like to get to blue book value. I'm going to see him tomorrow; maybe cash will get him to come down.
  4. Jun 3, 2011 at 4:21 AM
    bicklebok
    bicklebok Well-Known Member
    Ronnie
    Montgomery, AL
    2000 Xtra Cab 4x4 SR5
    I have been watching Tacomas locally, ebay, and craigslist for several months now and all the ones I followed sold for more than KBB. Just bought mine a couple of weeks ago and paid more than book value, and I had to be quick to get it once it was listed on craigslist.
    From what I have learned, if that truck was well cared for, it should have many more miles left. Mine has 165,000. You may still want to check the frame because some others with frame replacements are having rust problems. If it's a 6 cylinder, find out if the timing belt has been replaced. That will also be a good indicator if maintenance has been done as scheduled.
    Hopefully some others will chime in as well.
  5. Jun 3, 2011 at 4:49 AM
    JeffsJeep04
    JeffsJeep04 Well-Known Member
    Jeff
    Menomonie, WI
    2010 DCSB SR5 V6
    Yeah, you really can't go by KBB on tacomas, they typically go for much more. I think NADA is closer. KBB said my truck was worth about a grand less then I paid for it. The bank said according to NADA it was worth $3400 more then I got it for (but I think they used retail). Use those two and craigslist, and you'll quickly get an idea of what a good price is.
  6. Jun 4, 2011 at 6:02 PM
    nicnicman
    Maine
    I went and checked out the Tacoma today and I got him to come down to blue book value. The truck is in great shape, but there are a couple of issues I saw. One, the check engine light is on. He said this may be due to something with the gas tank; I'm not to sure about this. And second, when he had a cap on it came loose and scratched the paint off all along the top of the bed rails where the cap meets the truck. It just happened recently and no rust has started to form.
    What could be causing the check engine light to be on, and how much do you think it would cost to touch up the paint?
    Other than these issues it looks good as far as I can tell.
    Thanks for any suggestions.
  7. Jun 4, 2011 at 7:26 PM
    nicnicman
    Maine
    The check engine light worries me. I think I'll ask the seller if I can have a mechanic inspect it.
  8. Jun 5, 2011 at 9:42 AM
    nicnicman
    Maine
    I just found a 2001 Nissan Frontier 4x4 Supercharged with 100k for about $500 less. I like the Tacoma a lot better, but the Nissan may be a better value. 183,000 miles is a lot even for a Tacoma.
  9. Jun 5, 2011 at 10:44 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    The check engine light (its throwing codes at you) is an easy free fix usually, go to any AAmco shop (or other place that'll throw the code reader back at it) they can tell you at least where to look for issue. & my own opinion i wouldn't want a Nissan supercharged or not, I had great luck with them when they still had the Datsun trade name (even though its always been Nissan motor corp.) those old Datsuns ran forever just like Toyotas . But its your $$$$ go with what you feel best with, My TRD just turned over to 162,000 & running strong as it did when it had 94,000 (I bought used) No oil leaks, same MPG (3.4's were never real gas sippers)
    good luck with whatever your choice man...
  10. Jun 5, 2011 at 3:25 PM
    JBear
    JBear Spiral Out... Keep Going!
    Orange County, CA
    2003 Extra Cab 5 spd 4x4 TRD Off-Road
    2" suspension lift with King Coilovers up front. Standard Bilsteins on rear with a Fabtech 1.5" AAL. Leer 100XL Shell.
    1st, supercharged is just asking for problems... 2nd, if you plan on taking your truck off-road, keep in mind the Nissan has a pumpkin no bigger than your fist... I'm jus sayin' :smack:
  11. Jun 5, 2011 at 5:20 PM
    nicnicman
    Maine
    Why do you say the SC is asking for problems? Does Pumkin = Engine???
  12. Jun 6, 2011 at 10:19 AM
    JBear
    Orange County, CA
    SC makes everything work over-time, that's all. Just faster wear. And Pumpkins = Differentials. Sorry, maybe that's not a common name outside of my social ring, lol. Nissan diffs just seem so dang small to me. Just my opinion, though. I'm loyal to Yoda. Completely biased opinion.
  13. Jun 6, 2011 at 4:28 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    I think a supercharged 4x4 nissan would be fun, but yes, it is causing the engine to work harder and hotter. Also having an S/C means more moving/complicated parts, more stuff to break, and unless you drive like there is an egg under your foot, worse mpgs.
