First Tacoma
Discussion in 'New Members' started by blair1cn, Sep 27, 2011.
  1. Sep 27, 2011 at 8:05 PM
    blair1cn
    blair1cn [OP] Member
    Just ordered my 2012 Tacoma DC TRD 4x4 with the Off-Road Package. Fully loaded with the new touch screen enTune thingy. Should be here tomorrow or Thursday.
    Not new to the 4x4 community at all but going to be getting into the long travel stuff after some research on this site and a few others.
    Any insight to where to start? :D
  2. Sep 27, 2011 at 8:30 PM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    Locker anytime, skids, build some sliders, tires and lift...
  3. Sep 27, 2011 at 8:33 PM
    jeff b
    jeff b Well-Known Member
    Phat bank roll is where most LT starts.
  4. Sep 27, 2011 at 8:37 PM
    blair1cn
    Rear locker handled. Probably going to go with my standard "start with sliders" procedure.
    My other rig is a LX450...nuf said. :eek:
  5. Sep 27, 2011 at 8:43 PM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    Add a relay and you can engage your locker in 2wd 4hi and 4lo. Stock can only engage in 4lo. Did it this weekend finally, not hard.
  6. Sep 27, 2011 at 8:44 PM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    How big you planning on going for your tires?
  7. Sep 27, 2011 at 8:45 PM
    ATriplett513
    ATriplett513 Well-Known Member
    Phoenix, AZ
    2011 Dbl Cb, 4x4, 4.0L, 6-speed
    If you're going really serious with it, do an internal cage. One of the most overlooked things I see here.
    Even if you don't need it, it's good to have. Like a condom.
    I would rather have one and not need it, then need one and not have it.
  8. Sep 27, 2011 at 8:51 PM
    Scooter
    Scooter Canadian Member
    Manitoba, Canada
    08 Double Cab TRD Sport Short Box
    Pop n Lock Power Tailgate Lock, Bak Flip Tonneau Cover, Factory DLR installed, Defrost with A/C Off, EZ Down Tailgate Damper, Code Alarm Security System with Remote Starter, Rear Spring TSB, Ming rust proofing & paint treatment, 3M fabric protector, Cargo Mat, Scanguage II, DYI Illuminated 4X4 Switch, Versa-Gate box extender & cargo divider, Toyota Roof Rails, Grom USB Audio adapter with bluetooth, LED Bed lights, OEM Backup Camera with LCD Display Mirror
    :wave:Welcome! :canada:
  9. Sep 27, 2011 at 8:52 PM
    blair1cn
    You do a write up on this? What's the relay part number and details for installation?
  10. Sep 27, 2011 at 8:53 PM
    blair1cn
    33's at most.
  11. Sep 27, 2011 at 8:55 PM
    onesixseven
    onesixseven Well-Known Member
    Tyler
    Santa Clarita California
    02 Prerunner SR5
    3.5" Kind Coilovers Total Chaos UCA's 31" BFG A/T's 8000k hi/lo HID kit Flowmaster Super 44 5% tint all around exterior LED's Deck Plate Mod bedlined flares debadged Full Fosgate/JL Audio Stereo
    welcome Canyon Country CA
  12. Sep 27, 2011 at 9:01 PM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    write up found here
    http://www.tacomaworld.com/forum/technical-chat/4838-cheap-free-mods.html#post45412
    i used radio shack relay #275-0218
    http://www.radioshack.com/product/index.jsp?productId=2049722&tab=summary
    and final wire up followed this
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/38476-locker-mod-problem.html#post630170
    make sure it's a 12V DC relay
    pull the glove box out, at the top where the latch is, pull the plastic piece off after removing the 10mm bolt and you'll see the 4wd ecu...follow the steps in the pdf on the first link and wire up with the 218 relay with the last link setup
  13. Sep 27, 2011 at 9:03 PM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    with a 3" lift you'll clear 33s with minor trimming...i'm sure you can cut the cab mounts yourself if you rub...check your back spacing on your wheels because the stock wheels will not clear the uca's with 33s
    sounds like you'll be doing some coil overs at some point which will also require new uca's but you'll still need to watch the back spacing on your wheels
  14. Sep 27, 2011 at 9:08 PM
    blair1cn
    First thing I'm doing when this truck is delivered. I like the idea of locker in 2wd.
    More tire, less BS. After some research I plan on doing it all in one shot so I'm not redoing and cutting stuff that I really don't need to in the long run with the setup I want.
    When you hitting the trail next?
  15. Sep 27, 2011 at 9:15 PM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    so many times where a trail isn't that hard but is a loose bastard where it will come in handy....i'm also thinking during the winter it could come in handy..
    i'll be heading up saturday up mcclellan mtn with a buddy in a rubicon with the gfs...it's not really a hard trail but will be good getting up...trail is fun in the spring when it's loaded with water, but i'm sure it's dried up a ton by now..i'm sure we can get your new taco up there...might add some pinstriping along the way though
    still some time left to hit up some harder trails too, i'm usually able to shift things around enough to wheel on the weekends
  16. Sep 28, 2011 at 4:23 AM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    [​IMG]Welcome to TW from Sparks, NV. [​IMG]
  17. Sep 28, 2011 at 5:41 AM
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    07 Regular Cab SR5 4x4
    These two links will get you what you need for LT rear and mid-travel fronts:
    http://www.definedengineering.com/
    http://downsouthmotorsports.com/
    These links will get you pretty much everything else:
    http://www.cbioffroadfab.com/
    http://www.armortechoffroad.com/
    http://www.chaosfab.com/86000.php
    http://engage-offroad.com/products.html
    The rule of thumb when going long travel is, figure out how much parts and labor are going to cost and then double that.
    Also this is a good thread to read and ask tech related questions:
    http://www.tacomaworld.com/forum/long-travel-suspension/109317-long-travel-bs-thread-342.html
  18. Sep 28, 2011 at 7:36 AM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    if you are looking at this option, check out this guy's truck...some great tube work done around the truck...
    http://www.tacomaworld.com/forum/1s...re-tire-mounts-lets-see-them.html#post3599591
    full build..
    http://ttora.com/forum/showthread.php?t=92588
