First Tacoma
Discussion in 'New Members' started by Mikeyjd, May 17, 2014.
  1. May 29, 2014 at 2:42 PM
    #41
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Make it hard to do u-turns/parking but steering at speeds over 5mph shouldnt be too bad.
  2. May 29, 2014 at 3:22 PM
    #42
    Mikeyjd
    Mikeyjd [OP] MPG Enthusiast
    Mikey
    Grand Rapids, MI
    97 3.4L 4x4 DLX
    Grill Block, Front Belly Pan, 3 inch lift shims in front, AAL rear suspension lift, Ultragauge Instrumentation, Flush Topper, Full Synthetic Fluids
    I wouldn't expect my little wife to manage without power steering, but I think i may actually prefer it after just a couple runs :)
  3. May 29, 2014 at 5:23 PM
    #43
    Chopper678
    Chopper678 Professional Threadjacker
    Devin
    Texas
    '07 SR5 PreRunner V6 DCSB
    5100s@0.85"+Eibachs, Toytec 2" AAL, Weathertech floor liners, WO seat covers, UltraGauge, ammo box mod
    If you didn't like it (Sounds like you do) you could always get a larger steering wheel like they did before power steering.
  4. May 30, 2014 at 6:31 AM
    #44
    Mikeyjd
    Mikey
    Grand Rapids, MI
    97 3.4L 4x4 DLX
    It'd be cheaper/easier to reinstal the PS belt, or I could loop the fluids to remove the pressure from the pump. I may do that either way.
  5. May 30, 2014 at 6:39 AM
    #45
    Chopper678
    Devin
    Texas
    Reinstalling the belt would be defeating the purpose of removing it... with a larger wheel you could keep it off.
  6. Jun 1, 2014 at 7:06 PM
    #46
    Mikeyjd
    Mikey
    Grand Rapids, MI
    97 3.4L 4x4 DLX
    I'm leaving it off. I like driving it better without it.
    2014-06-01
    468.7 mi
    754.3 km
    15.944 gal (US)
    $3.85/Gallon ($61.38 total for this fill)
    29.4 mpg (US)
    8 L/100 km
    New (old) tires 245/75/16 + more under body panels. Ran 91 octane ethanol free this tank. Pretty good tank considering I hauled a trailer around for part of it.
  7. Jun 1, 2014 at 9:26 PM
    #47
    Chopper678
    Devin
    Texas
    Gratz! Hey, you'll never guess... I went against my instinct and tried pulse and glide this tank after getting a 21MPG tank with normal driving habits, saved P&G for this one so as to get an accurate difference.
    Normally, if I fill up my truck to the BRIM (About a gallon after the auto shut off at the pump) I will get 100 miles at 1/4, and if I behave 200 at 1/2.
    This tank, I just let it auto shut off (For accurate calculations I use the same pump and let it auto shut off) meaning about a gallon less, and I hit 125 at the 1/4!! Hoping for ~250 at the 1/2, I did a lot of city driving this weekend. Pulse and glide rocks! Goal is a +3 or +4 change with P&G.
  8. Jun 1, 2014 at 9:59 PM
    #48
    tylershane17
    tylershane17 Back to Back World War Champions
    Tyler
    Northwest Alabama
    2000 SR5 4x4
    Brushguard, Off Road Lights, Sony Xplod Stereo, Tool Box.
    Subbed for curiosity
  9. Jun 2, 2014 at 5:25 AM
    #49
    Mikeyjd
    Mikey
    Grand Rapids, MI
    97 3.4L 4x4 DLX
    You should get some instrumentation. It would give you instant feedback on your different technique. I use and recommend UltraGuage.
  10. Jun 2, 2014 at 6:26 AM
    #50
    Chopper678
    Devin
    Texas
    I am working on it. I want to get one before I do any of the planned mods to the truck to see just how everything is affected. Why do you recommend ultraguage over scangauge? Also, do I need to buy any special part or equipment to hook it up? How easy is calibration?
  11. Jun 2, 2014 at 1:13 PM
    #51
    Mikeyjd
    Mikey
    Grand Rapids, MI
    97 3.4L 4x4 DLX
    You can have 8 gauges per page (instead of 4) with the Ultra and it's half the money. It comes with a wire to hook up to your OBDII output under your steering wheel. It's easy to calibrate.
  12. Jun 2, 2014 at 1:36 PM
    #52
    Chopper678
    Devin
    Texas
    Sounds great! Yeah I have seen the SG... Size did not impress. What's their selling point? :confused: And I had no idea that was there. Sweet!
  13. Jun 3, 2014 at 1:29 PM
    #53
    Chopper678
    Devin
    Texas
    Okay, I am disappointed... I don't know what it could be but I hit 125 at the 1/4, (awesome, should have checked MPG there) and then at 202.1 miles I was about 1/8 inch from the half mark! :confused: Calculated straight from odo and pump, same pump same shutoff 22.95 MPG, adjusted for error = 22.55 MPG. So I gained about 1.8 MPG from Pulse and glide coupled with minimal idling. (When I started the truck I left within seconds, and cut it off as soon as I parked)
    Was hoping at least 24. :(
  14. Jun 3, 2014 at 2:01 PM
    #54
    Mikeyjd
    Mikey
    Grand Rapids, MI
    97 3.4L 4x4 DLX
    It's hard to learn optimal technique without some form of instrumentation. Give time. 1.8 mpg is still like an 8% increase :)
  15. Jun 13, 2014 at 11:43 AM
    #55
    Mikeyjd
    Mikey
    Grand Rapids, MI
    97 3.4L 4x4 DLX
    2014-06-13
    539.9 mi
    868.88 km
    15.413 gal (US)
    $3.89/Gallon ($59.96 total for this fill)
    35.03 mpg (US)
    6.71 L/100 km
    This tank had 90 octane ethanol free. 90% Back roads. 40 mpg is the next tank goal.
  16. Jun 13, 2014 at 11:54 AM
    #56
    Mikeyjd
    Mikey
    Grand Rapids, MI
    97 3.4L 4x4 DLX
    Before Side Skirts
    Old inverted running boards used as a mount
    After
  17. Jun 13, 2014 at 12:42 PM
    #57
    Chopper678
    Devin
    Texas
    Nice!! Getting into the land I wouldn't go lol but sweet! You are really dedicated to this thing. Don't forget to post your gains from the ultragauge reading on the front! BTW, I have some interesting information for you... PM pending
  18. Jun 18, 2014 at 9:00 PM
    #58
    Chopper678
    Devin
    Texas
    I am unsure what you are doing when you say you used inverted running boards as a mount and what you did between pictures. Could you explain?
  19. Jun 21, 2014 at 2:44 PM
    #59
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    I removed both PS and AC along with a bunch of serpentine pulleys from my 2.7, and run just one simple short belt that only turns the alternator and water pump.
    Last fillup was 25.5 mpg. :)
    Greg
  20. Jun 21, 2014 at 2:54 PM
    #60
    tooter
    Greg
    Los Angeles
    Hey Mikey, :)
    I'm one of those frugal guys too. :cheers:
    I saved up enough money over the years to built a modest home with no mortgage, and also live debt free on very little money. That's the American way. :oldglory:
    Greg
