First thing to know about going "Off Road" is keep recovery in mind.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CaptainBart45, Dec 12, 2020.
  1. Dec 12, 2020 at 11:48 PM
    CaptainBart45
    CaptainBart45 [OP] Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    Am I wrong?
  2. Dec 12, 2020 at 11:57 PM
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    I wouldn't argue that. Being proactive about knowing where you are going, going with others, limitations, and recovery gear. That doesn't mean that people need to go out and drop 5K on recovery gear either.
    Skydvrr, Dryfly24, whatstcp and 7 others like this.
  3. Dec 13, 2020 at 8:03 AM
    TacomaBeast67
    TacomaBeast67 Well-Known Member
    Calgary, Alberta
    2017 TRD Sport, Dbl Cab, Manual
    K&N Cold Air Intake, N-Fab Rock Rails, Removeable Steps, BAC Revolver X2 tonneau, 265/70/17, engine bay LED’s, Amber/clear strobes
    Nope, you’re not
  4. Dec 13, 2020 at 8:11 AM
    synaps3
    synaps3 Wag more bark less
    Dave
    Los Alamos, NM
    2017 White SR5 4x4 DCLB
    SOS armor, ARE MX walk-in, Fox coils, Dakar leafs, etc
    Second thing is don't go alone. Good recovery techniques can only get you so far in some cases. Plus, offroading is more fun with friends.
    Junkhead and CaptainBart45[OP] like this.
  5. Dec 13, 2020 at 8:14 AM
    EvilElvis
    EvilElvis Well-Known Member
    PNW
    2012 3wd
    Important to know the limitations of your tires.
    Junkhead, boston23 and Hobbs like this.
  6. Dec 13, 2020 at 8:31 AM
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    I'd argue knowing how to use the vehicle features first. Nothing like getting stuck as the first time to figure how to use MTS or the locker, or how to use 4LOW for that matter.
  7. Dec 13, 2020 at 9:24 AM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    And the driver, and the recovery equipment, and like @mattleg said know what all these fancy buttons do!
    Dryfly24, CaptainBart45[OP] and Hobbs like this.
  8. Dec 14, 2020 at 9:18 AM
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    If it’s a tough stretch get out and walk it first. Look at it from different angles. Then drive
    BRFab, shakerhood, Dryfly24 and 4 others like this.
  9. Dec 14, 2020 at 7:52 PM
    CaptainBart45
    Bart
    Work in progress...
    Lately seems like every time I go out in the desert I run across folks stuck in the sand. They have no supplies and no gear. Getting out of the house and exploring the desert is fun but think ahead.
    Dryfly24 and whatstcp like this.
  10. Dec 14, 2020 at 7:54 PM
    jimmerheck
    jimmerheck Well-Known Member
    Vancouver, WA
    2019 Tacoma Limited in white
    I like watching the you tube videos from Matts Off Road Recovery. You can learn a lot.
  11. Dec 14, 2020 at 8:01 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    NorNev and Greatdane01 like this.
  12. Dec 14, 2020 at 8:59 PM
    Kev250R
    Kev250R Well-Known Member
    Kevin
    Orange, So.Cal.
    2020 Tacoma TRD Off-Road 6MT
    Floor mats, junk in center console
    You're not wrong, but I like to study the area where I'm going to be off-roading well before I get there. For me that means looking at maps, Googling route numbers to see what pop's-up. I'll play around on Google Earth too which helps get an idea of what might be out there. Guide books help too. I generally spend a week every year off-roading and exploring around different parts of Utah and Arizona and have a lot of maps with notes written on them and guide books. I recently added GPS to my off-road car so I'm getting better at playing with Waypoints. Prior to that I always carried a hand-held unit with where I started set in it.
    Recovery gear and knowing what your vehicle can do are important too of course. I'm a couple of weeks away from taking my Taco on it's first long road trip out of state which will involve a couple of days of four-wheeling, so I spent a couple of hours last weekend in my local mountains on some trails playing around with A-Trac and the rear locker since I've never used those off-road before.
    CaptainBart45[OP] likes this.
  13. Dec 14, 2020 at 9:29 PM
    2000prerunner23
    2000prerunner23 Well-Known Member
    steve
    All true ... but for people who also off road “fast” in the desert, it’s important to run through a section slowly before you smash out like a trophy truck and bottom out hard lol. Also roll over the jump a few times slow to check your speed and get it right before you send it.
    As far as gear for going a bit faster than stock ... spend twice as much money on the rear suspension vs the front
    . Much much safer. You’re welcome and drive safe !
  14. Dec 14, 2020 at 10:03 PM
    sagexp
    sagexp Well-Known Member
    Back home, AZ
    2002 Tacoma DC 4X4 2017 Tacoma DC 4X4
    I'd say slightly more important is survival gear. First aid kit. Way to make fire, keep warm, enough water for several days and a way to treat found water. Maybe some emergency rations (though most will do just fine for a couple weeks without food). Every vehicle should have that, but especially one that ventures off road. Even for just a "side trip". It's the unprepared yuppies in Range Rovers that venture out for a "side trip" or take a "short cut" that wind up eating snow, heating up rocks in tin cans to "stay warm" and then try to walk out only to have their carcasses be found in the spring.
    A close second to that (and I would even say is part of "survival gear"), is recovery gear.
    Recovery gear and techniques can fail. You can get hurt trying to employ them. Comms can fail. Vehicles can fail. Let someone know where you're going, and when they will hear back from you. And be prepared to stay healthy until help comes.
    As for not going out alone....do it all the time. Weeks on end sometimes, many miles out. Love the solitude. But my loved ones know where I am, and when to expect check ins. And where to start the search should I stop checking in.
  15. Dec 15, 2020 at 4:42 AM
    NorNev
    NorNev Phone? Call someone who gives a shit.
    Dave
    39° 31′ 6″ N, 119° 59′ 19″ W
    KDMAX Tuned 17 2•2X2•2 Hood Scoop
    A Few
    Rakso[QUOTED] likes this.
