First Time Brake Flush
Discussion in '1st Gen. Tacomas (1995-2004)' started by TheCreekRat, Sep 18, 2017.
  1. Sep 18, 2017 at 1:44 PM
    TheCreekRat
    TheCreekRat [OP] Well-Known Member
    99' TRD Off-Road
    -level kit
    Doing my brake fluid for the first time this afternoon. Seems pretty straight forward and I was able to get my hands on a motive universal brake bleeder.
    Still if anyone had any tips I am all ear. I see most people recommend a box-end wrench and I only have a reg. 10mm, but that doesnt seem to be a deal breaker.
    Just hoping i dont spray that shit everywhere,
  2. Sep 18, 2017 at 1:51 PM
    TheCookieMonster
    TheCookieMonster cookies!!!!!!!!!!!
    North East
    1995 Hi Lux 22re 4x4 5speed
    Michelin MS2 K&N drop in filter
    don't forget to bleed the proportioning valve too,
    JJSilverTaco likes this.
  3. Sep 18, 2017 at 1:56 PM
    pray4surf
    pray4surf Well-Known Member
    Rick
    Oceanside, CA
    98 PreRunner conv to 4x4
    F&R suspension, OBA, Custom bed rack, RTT, rear frame plates, 4x4 conversion from prerunner, many other
    Box end wrench' is just fine. You do run the risk of 'rounding' the bleeder if you use an open end wrench.
    Keep an eye on the power bleeder reservoir and don't let it run out of fluid...
    Start from the device furthest from the master cylinder and work closer (RR, LR, PV, RF, LF)
    find some clear hose that fits tightly over the bleeder screw and run that down to a glass jar to catch the waste. When bleeding for air in the lines, bleed into fluid and you can see the bubble exit, bleed ti there are no more bubbles.
    Bleed each item until clean/new fluid (and bubbles) come out - The RR will take the longest.
    Pressurize the power bleeder, open RR bleeder, close bleeder when done. check power bleeder reservoir
    Repeat with remaining components
    Bulldogs129 likes this.
  4. Sep 18, 2017 at 2:33 PM
    Toyota4x46921
    Toyota4x46921 Well-Known Member
    Michael
    Warner Robins, GA
    I couldnt get my motive to work...wouldn't clamp on the damn reservoir .
  5. Sep 18, 2017 at 4:34 PM
    TheCreekRat
    99' TRD Off-Road
    -level kit
    Thanks for the tip. Found it about my rear driver side wheel area. Everything was a success.
    Brakes feel better now. Only thing I noticed was I could not get all the dirty fluid master cylinder due to it being somewhat split in two. I got as much out as I could. Figure this is normal. I am not a big car guy and this is the first time I have done this as I said. Just trying to learn.
    Dalandser likes this.
  6. Sep 18, 2017 at 4:35 PM
    TheCreekRat
    99' TRD Off-Road
    -level kit
    Took a little jiggering but just had to move the chain back as far I could behind the wires. May have lost a touch of pressure but just had to give it a few pumps in between.
  7. Sep 18, 2017 at 4:52 PM
    TheCookieMonster
    North East
    the old fashion pump brake hold,open valve works the best IMO
    skeezix likes this.
  8. Sep 18, 2017 at 5:30 PM
    Glamisman
    Glamisman Well-Known Member
    I take the resivoir completly off and soap and water it, dry it an dput it back on. I do this because I want new fluid pushing the old fluid out and not running all of the crap that settles in the bottom of the resivoir through the system.
  9. Sep 18, 2017 at 5:42 PM
    TheCreekRat
    99' TRD Off-Road
    -level kit
    Yeah I was trying to make it as simple as possible and not take the master off and bleed it.
  10. Sep 19, 2017 at 9:17 AM
    TheCreekRat
    99' TRD Off-Road
    -level kit
    Anyone know where I can just a spare screen/filter price. Mine was a bit frayed and busted through. Called around and no luck so far.
