First time building a new computer
Discussion in 'Technology' started by MxRacer190, Apr 20, 2012.
  1. Apr 21, 2012 at 6:47 AM
    Cypherian
    Cypherian Well-Known Member
    Mid Atlantic Region
    This is where I would go I tried to stay in your budget but in order to get solid performance and upgrade ability this is the Total Cost after rebates 802.93 with 16GB of ram. I know it is over your stated wishes of price, however when I spec out machines I look at future upgrading. If anything though I would go with the I5 mother board combo and then use your own hardware choices from there. I am sure others here will either agree or disagree with my choices. I was given very sage advice long ago when I used to drag race by my grandfather and it holds true in a lot of things.
    “Speed Is In Direct Relation To The Size Of Your Wallet”
    Diablo 3 Does not support SLI at this time just checked..
    Case: $60.00 After Rebate $50.00
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811129066
    I have two 900’s they make some solid cases with ease of use MB trays etc and come with fans for the top and front. Its all about the COOLING for gaming.:}
    750w Power Supply 89.99 After rebate 69.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817371051
    This is the min I would go if you run two video cards step up to 1k watts as with less power there is likely to be issues.
    Mother Board and Cpu Combo $366.98
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.882275
    Intel Core i5-2500 Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 2000 BX80623I52500</SPAN>
    Comes with CPU fan again its all about cooling
    Memory: 48.99 After rebate 38.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820104231
    You can start with one set for 8gb if you can I would go with two for a total of 16gb
    Video $139.00 after rebate $119.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814150573
    I would run one and see how it performs as I said support for SLI or CrossFire is limited .
    Hard drive $80.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822136775
    I agree with the others SSD is the way to go but with in your stated price this is where I would go or your original choice I am just partial to WD.
    CD / DVD $37.00
    http://www.newegg.com/Product/Product.aspx?Item=N82E16827249071&SortField=0&SummaryType=0&PageSize=10&SelectedRating=-1&VideoOnlyMark=False&IsFeedbackTab=true#scrollFullInfo
    I like Plextor for its quiet running and stability with various media manufacturers.
    Hope this helps good luck with your build,
    Cypher
  2. Apr 21, 2012 at 7:03 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    As everyone has stated I would go with two hard drives. If you can swing the cost of an SSD for your OS then great but if you can't I would at least get two drives. I would also get 16 gigs of RAM. The motherboard you picked can handle 32 gigs and RAM is cheap nowadays.
    I didn't look at the case but I am assuming it has a power supply with it. I didn't see a price for an OS disc so I assume you already have that as well.
  3. Apr 21, 2012 at 7:52 AM
    goufcustom
    goufcustom 7.62x63mm
    MD
    2021 4x4 TRD Sport DCLB
    Just my thoughts,
    Case - $75 (not sure if 450W is enough)
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.877309
    HD - $110
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822148591
    RAM - $75
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820233189
    CPU - $185
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819115089
    Motherboard - $100
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813130648
    Go with whatever DVD drive you want, and the graphics card you had picked is nice too. That total is about $700, and I bet you can find it all on sale over the next few weeks.
  4. Apr 21, 2012 at 2:38 PM
    wileyC
    wileyC Well-Known Member
    Centerville, OH
    2012 PreRunner Double Cab TRD Sport
  5. Apr 21, 2012 at 5:22 PM
    MxRacer190
    MxRacer190 [OP] Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    Thanks Cyph! and thanks so far to everyone else. I don't think I'll jump on the SSD yet. Most likely I will along down the road. I think I'll take everyone's advice and get the i5 CPU/MOBO Combo Cyph linked me to. But, I think I'll keep the rest of my stuff I had already picked out. I don't plan to hardcore game, so I don't think I'll need a huge PSU or a high dollar case.
  6. Apr 21, 2012 at 7:27 PM
    khx73
    khx73 Well-Known Member
    Saint John NB, CAN
    11 MGM DCLB TRD Sport +leather
    Rear camera anytime switch, 4x4 Illuminated Switch (from rcbs204) , rear view mirror lift bracket (from ImMrYo), 75 cent tailgate anti-theft. Technically not mods but give me a break I'm trying to fill space here... OEM Leather pkg, keyless unlock & ACC chime silence, BakFlip G2, Ultra Gauge EM, WeatherTech floor mats, OEM roof rack
    MxRacer190:
    Do yourself a favor and partition your big HDD into two. Make the first one 128GB (C drive). And use the rest for the D: partition. Put your OS and commonly used apps on your C, and big stuff on the D. That way, if and when you pick up an SSD, you can clone the C partition over to the SSD, and away you go.
    Also, if your OS shits the bed on you, you can wipe, re-install and still have all your data on your D partition.
  7. Apr 22, 2012 at 12:09 PM
    Cypherian
    Mid Atlantic Region
    Khx73 is correct split your drive into two partitions load one with only programs and the other data. Make sure you make the proper adjustments to default saving locations in your programs like office and IE etc. However, I will caution you if the drive crashes your out your data and programs. So either invest in a small usb drive and use it as an alternate data back up or get a smaller secondary hard drive and set it as your back up location using win7's integeral back up routines.
    Cypher
  8. Apr 24, 2012 at 12:45 PM
    MxRacer190
    Georgia
    06 SR5 4x4 Indigo
    Okay, I keep making and remaking builds lol. I think finding parts is more fun than playing the games on the computer, lol. Here is what I have. I kind of went over budget, but I'll be using Newegg's 12 months no interest "Preferred Customer" plan. I'll be buying my CPU locally though, so that's why I had to add stuff on Newegg to reach the required $500 for the plan.
    Intel Core i5 2400 LGA 1155 Boxed Processor
    $158 with tax
    ASRock Z68 PRO3 GEN3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
    $105
    XFX HD-685X-ZCFC Radeon HD 6850 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card
    $120 after mail-in-rebate
    Mushkin Enhanced Blackline 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory
    $45
    Seagate Momentus XT ST95005620AS 500GB 7200 RPM 2.5" SATA 3.0Gb/s with NCQ Solid State Hybrid Drive -Bare Drive
    $90 after promo code EMCNFHN53
    BYTECC Bracket-35225 2.5 Inch HDD/SSD Mounting Kit For 3.5" Drive Bay or Enclosure for use with the above SSHD
    $5
    Rosewill CHALLENGER Black Gaming ATX Mid Tower Computer Case, comes with Three Fans-1x Front Blue LED 120mm Fan, 1x Top 140mm Fan, 1x Rear 120mm Fan, option Fans-2x Side 120mm Fan
    Rosewill HIVE Series HIVE-650 650W Continuous @40°C, 80 PLUS BRONZE Certified, Modular Design, Single +12V Rail, ATX12V v2.31/EPS12V v2.92, SLI Ready, CrossFire Ready, Active-PFC Power Supply
    $100 after combo discount
    LG DVD Burner Black SATA Model GH24NS70 - OEM
    $17
    Grand total after mail-in-rebates: $660.90
  9. Apr 30, 2012 at 9:01 PM
    MxRacer190
    Georgia
    06 SR5 4x4 Indigo
    Posting from my new computer! It's 100% now.
    CPU - Intel i5 2400
    GPU - XFX Radeon 6850
    MOBO - Asrock z77 Pro3
    RAM - Mushkin 1600 2x (4GB)
    HDD - Samsung by Seagate Spinpoint F3 500GB 7200RPM
    Optical Drive - LG DVD Burner
    PSU - Rosewill 650w 80Plus Bronze
    Case- Rosewill Challenger
    Monitor - MAG 24" LED/LCD 1080p
    Currently downloading LoL until D3 :D
    I'll be buying an SSD later on down the road.
