First time buyer advice: is this a good truck??!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by freshtaco93, Jan 25, 2021.
  1. Jan 25, 2021 at 9:18 AM
    freshtaco93
    freshtaco93 [OP] New Member
    Hi all
    I am fairly inexperienced and am looking to buy my first truck. Been using and abusing a 2010 Sienna for years as an adventure rig and figured it’s finally time to get a proper truck.
    I’ve heard mixed things about the 2009 Tacoma what are your thoughts? Is this a year to avoid?
    I found what looks like an awesome truck but I’m not sure if it’s a good buy. Help!
    (here is the truck in question: 2009 Toyota Tacoma Regular Cab
    https://reno.craigslist.org/cto/d/reno-2009-toyota-tacoma-regular-cab/7258011753.html)
  2. Jan 25, 2021 at 9:22 AM
    BINK05TRD
    BINK05TRD Well-Known Member
    Massachusetts
    TRD OR AC SILVERSKY 15
    Welcome to the forum :hattip:
    Nice little rig :thumbsup:
    Have it looked at by a qualified mechanic.
    Not sure if it’s going to make a good adventure rig though.
    Good luck with your search.
  3. Jan 25, 2021 at 9:23 AM
    noco_taco
    noco_taco Well-Known Member
    Colorado
    2007 White TRD Off-road
    Looks pretty clean from the pictures, seems on the higher end of price for sure. Seeing as you said you wanted it as an adventure rig, do you want 4wd? Also that have the smaller engine which may feel pretty underpowered to you. Best advice I can give for buying a vehicle is go test drive it, and if time allows, give yourself a few days to sit and think and not make an impulse decision. Also I’d highly recommend test drive one with the v6 and 4wd. But only you know what your adventures require. Good luck!
    BINK05TRD likes this.
  4. Jan 25, 2021 at 9:26 AM
    freshtaco93
    To clarify a bit more: I’m not really looking to go “off-roading” so much as having a vehicle that I can drive on dirt roads and camp out of. I do a lot of rock climbing and mountain biking.
    this vehicle is located several hours away from me and I’ll be meeting the seller halfway. Not sure if I can arrange for a mechanic to look at it before I purchase. Is this a bad idea?
  5. Jan 25, 2021 at 9:30 AM
    BINK05TRD
    Massachusetts
    Real bad :eek:
    $9k is a lot of money to take someone’s word
    that the truck is sound.
    Slick Taco likes this.
  6. Jan 25, 2021 at 9:35 AM
    freshtaco93
    THANK YOU I think I needed someone to tell me that!
    I live in the Bay Area and most Tacomas go for way more than this around here even at higher mileages. The ones close to home I can/will get checked out by a mechanic. Just saw this post last night and thought it could be worth it
  7. Jan 25, 2021 at 9:40 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Each individual has their own definition of a "good truck". The answer depends on what you want to do, your budget, your willingness to search, willingness to travel for inspection.......
    Above all, TEST DRIVE IT and have a mechanic look it over. Be aware, the mechanic will probably want a fee for his service.
    If the deal seems to good to be true, then it probably isn't true.....walk away.
  8. Jan 25, 2021 at 9:42 AM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    I’ve been driving a 2010 RC for more than 11 years, but make sure this one has no rust and no previous accidents before you buy it...
    Welcome to TW! :hattip::wave:
  9. Jan 25, 2021 at 9:44 AM
    eon_blue
    Azusa, CA
    If you want something that can take you off the beaten path, I would look for a 6 lug Tacoma not a 5 lug one (that one is a 5 lug).
    The 2wd 6lugs (Prerunners) are built on the 4x4 frame and offer much more ground clearance.
    They will cost a fair bit more though
    MSN88longbed likes this.
  10. Jan 25, 2021 at 9:45 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    2009 is not a bad year.
    If you're ok with 2WD, it's a good little truck that will get good gas mileage.
  11. Jan 25, 2021 at 9:49 AM
    sgage
    sgage Well-Known Member
    2007 Red Tacoma SR5
    I don't think it's a particularly bad price, except I'd want 4WD and some slightly beefier tires. But without a chance to really have it looked at, and to take it for a test drive, I'd be wary. It looks nice and clean, and you gotta love the color :) My last two trucks were 4L sixes, but I've been very happy with the 2.7L 4cyl in my 2007 reg cab (I don't do any towing):
    EDIT: I just realized it has an automatic transmission. I think with the 2.7L 4cyl engine, you really want manual...
    Taco505 likes this.
  12. Jan 25, 2021 at 10:12 AM
    Taco505
    Taco505 Well-Known Member
    Alex
    New Mexico
    2011 4cyl 4x4 5 speed
    OME 884's/90021, MD Dakar/Nitrocharger.
    I think that is a bit steep for a 2wd but overall the 4cylinder trucks are super stout and there really aren't any huge issues. The problems you were mentioning are more specific to the V6 and are something to consider when looking for an older 4.0L. I would recommend taking it to a mechanic local to where you plan to meet the seller for a pre-purchase inspection if you aren't comfortable inspecting the truck yourself.
    I've had pretty much that exact same truck for 10 years and it was great but I have to be honest the auto is pretty awful, if you know how to drive stick I would highly recommend that over the auto. If you are just planning on hitting highways or grated dirt roads the 2wd will be more than fine but you may find yourself wanting the 4x4 at some point that's what happened to me and I now have an 11 5speed 4x4.
    Keep in mind about the space difference moving from a Sienna to a regular cab Tacoma will take some getting used to. Depending on how tall you are there can be a decent amount of storage behind the bench.
  13. Jan 25, 2021 at 10:22 AM
    MSN88longbed
    MSN88longbed Sporty Shorty
    Goleta, CA
    2014 Single Cab 4x4, Auto, Blinding White
    Kings all around, Method 306, Cooper STT Pro 265 75/R16, JBL amp, Morel Speakers, Undercover tonneau, Alcan leafs, SOS sliders, RCI skids, SSO Slimline, Engo winch.
    I paid a company called Lemon Squad to professionally inspect mine that was out of state.
    Just a consideration.
    I agree with what everyone else says.
    My auto is not peppy.
    If you keep the small wheels on it, it should be fine though.
    mabepossibly likes this.
  14. Jan 25, 2021 at 10:44 AM
    mabepossibly
    mabepossibly I know enough to make an ass of myself
    Andrew
    Albany, NY
    2021 TRD OR Manual
    Skids, Sliders, Lights
    As others have said, get an inspection.
    even though a basic 4cyl 2WD Tacoma is probably one of the top 5 most reliable and durable cars sold ever, there is no guarantee this thing doesn’t have a bunch of shady bodywork or something.
  15. Jan 25, 2021 at 11:04 AM
    Gen2 Man
    Gen2 Man Well-Known Member
    Midwest
    07 Sport DCLB
    3rd Gen Sport wheels
    Has anyone mentioned rust ? Looks like they did. I’ll second that
  16. Jan 25, 2021 at 11:06 AM
    Brian_d
    Brian_d Well-Known Member
    Socal
    How many miles does it have on it?
  17. Jan 25, 2021 at 11:08 AM
    eon_blue
    Azusa, CA
    Shhh! Every time you say the 'R' word, somewhere/someplace a 1st gen Tacoma breaks in half
    Look what you just did
  18. Jan 25, 2021 at 11:18 AM
    mabepossibly
    Andrew
    Albany, NY
    2021 TRD OR Manual
    The truck is from Reno. Unless it spent the last 10 years in Boston, it’s unlikely to be an issue.
