First time changing oil on this truck, strange dip stick reading?
Discussion in '1st Gen. Tacomas (1995-2004)' started by RDF, Dec 22, 2016.
  1. Dec 23, 2016 at 9:39 AM
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
    Good luck with your truck OP. Hopefully no real damage was done you're not the first person to do that and ya won't be the last. Crossing fingers for ya that your truck is okay.
  2. Dec 23, 2016 at 9:40 AM
    Roadeater
    Roadeater Well-Known Member
    Kennesaw, Ga
    2004 Black Tacoma Prerunner TRD V6
    I believe car will be fine. Transmission fluid drained out of the pan isn't even half of what's in the transmission if I am not wrong
    Boerseun likes this.
  3. Dec 23, 2016 at 9:40 AM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    Glad you got the answer and I am sure it will be okay since you were able to drive it without noticing anything, and only drove it a short distance. Won't hurt to have it checked out though. Good luck.
  4. Dec 23, 2016 at 10:04 AM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    The trans pan only holds about 5 quarts of fluid, there is about 11 quarts total in the transmission and torque converter, so I doubt you did any damage on a short drive.
    I'd wonder what having 2x the oil in the crankcase would do to piston rings, seals, etc
  5. Dec 23, 2016 at 1:29 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    You are probably fine, as others said, you didn't drive it without ANY oil in the tranny, just less.
    To check the atf, you can drain it again and check for metal flakes in the oil. Run the fluid thru a coffee filter, and if you see shiney bits, you might be in trouble, and best to take it to a specialist. If the oil i clean, however, you are probably fine.
  6. Dec 23, 2016 at 1:33 PM
    Clearwater Bill
    Billy
    Largo Florida
    Based on his short drive, nothing.
    cruxofthebisquit likes this.
  7. Dec 23, 2016 at 1:51 PM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    If the level is high enough the crankshaft/rods will hit the top of the oil and whip it up causing the oil to be filled with air/bubbles, then the oil pump won't have enough pressure or pump enough oil.
  8. Dec 23, 2016 at 7:39 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    If it were a HP engine running lots of RPM that's more a problem. These things are the AK47 of engines. I think they'll run on mud.
  9. Dec 23, 2016 at 7:46 PM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    Lesson learned
