First time checking mpg on the Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 07TaCo07, Feb 3, 2012.
  1. Feb 3, 2012 at 3:10 PM
    07TaCo07
    07TaCo07 [OP] Well-Known Member
    oregon
    07 double cab 6" lift
    6" fab tech lift, 35" toyo m/t, 17" teflon wheels
    So I had to take a trip and decided for the first time in two years to put more than $20 in gas and fill that effer up. $60 not as bad as I thought. But it still hurt. I calculated my miles and bigger tires then divided gallons and got 17.5 with my heavy toyo mts. It way more than I expected. I love my truck so much more now, didnt think that was possible
  2. Feb 3, 2012 at 3:14 PM
    garcm329
    garcm329 Well-Known Member
    Mario
    Rancho Cucamonga
    06 T4R
    Icon 2.5 front coils, toytec aluma series 2.0 rear shocks and toytec HD springs. ARB air locker in the rear. 285 70 R17 Kenda Klever RT tires on IVD bronze 6 speed 17” wheels. Wilco spare tire carrier.
    Nice!!:D
  3. Feb 3, 2012 at 3:46 PM
    07TaCo07
    oregon
    I did drive down then fill up. Without topping I off too
  4. Feb 3, 2012 at 3:56 PM
    07TaCo07
    oregon
    My bad. I know a lot of people that don't fill back up and say the needle is at half a tank so it must be a half tank left.
  5. Feb 3, 2012 at 4:03 PM
    canadaman
    canadaman Active Member
    Canada
    07 TRD Sport
    Yup,
    And some claim their trucks consistently get over 20 too...?? I doubt it. If you drive downhill with a strong wind going too and from .... then maybe :p
  6. Feb 3, 2012 at 4:05 PM
    magnetic10
    magnetic10 Well-Known Member
    Don
    Raleigh, NC
    10' SR5 Double Cab 4x4
    Grillcraft black mesh.
    I can get over 20mpg with the tires over 40psi and nothing but highway speed at around 65 any higher and it drops quick.
  7. Feb 3, 2012 at 4:41 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    It's largely the tires. Mine shake in sheer terror at the sight of sand or mud. If they could drop scat they would and then slip in it, scream while falling off the truck and then just run off into the woods.
    However, my last tank I filled at 357.2 miles and the (darned inconsistent) light wasn't even on. It's even the middle of winter, albeit a decidedly mild one, but still needing 4WD at times. Average since I started recording every fill since November 27 is 20.2, so technically over 20. :)
    +1 for fill to the auto shutoff, drive, fill up again and calculate, rinse and repeat often. Anything else is *insert comment referring to (insert least favorite) salesman here* for really knowing your mileage.
