First time clutch replacement 2003 4x4
Discussion in '1st Gen. Tacomas (1995-2004)' started by Smellygreentaco, Jan 14, 2017.
  1. Jan 14, 2017 at 5:55 PM
    Smellygreentaco
    Smellygreentaco [OP] Member
    Texas
    2003 Tacoma 4x4 green
    Stock
    Hiya fellows,
    Trying my hand at clutch replacement. (Don't let your friends drive your prized vehicle).
    I have all the required parts and have begun disassembly. I fear I may have already screwed up by not marking rear drive shaft to transfer case...have I ruined timing? Can I fix before damage is done?
    Phew, deep breath, getting back at it.
  2. Jan 15, 2017 at 1:44 AM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Definitely didnt affect your timing(engine timing that is if thats your concern?) my man, worst case scenario is there might be some slight vibes with the drive shaft not perfectly balanced now, if thats the timing you mean, live and learn i suppose...
    No possible way to affect engine timing working on anything that has to do with the drive train!! Stop sweatin it you're golden on that end of things. Maybe you dont mean timing in regards to that but rather your worried about a misaligned drive shaft. It might create slight vibes like i already mentioned but that would be a fairly.easy fix since it would just take a test drive then a reposition to check for continued vibes and continue till they're gone...no damage would be done if the drive line is offset from its original position though, youre safe!
  3. Jan 15, 2017 at 3:01 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    With reference to driveshaft timing the critical timing to be worried about is when you split a 2pc driveshaft. Is it better to put d-shaft back to original spot on rear-end and transfer case flange - yes. But you'll be fine.
    cruiserguy likes this.
  4. Feb 4, 2017 at 2:47 PM
    Smellygreentaco
    Texas
    Stock
    Thanks fellows. Much stress alleviated.
    Currently having problems getting the tranny separated from motor.
    I'm positive everything is unhooked...just could be frozen together given that it's 160k mileage truck and this has never been done before.
    I had to step away from my project for a week but I'm back at it. Have shaken the literal hell out of tranny but it will not come loose! Even tried using pry bar but no luck.
    Going to try and get some more muscles working on it with me next time I try.
  5. Feb 4, 2017 at 2:56 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Does it seperate at all? If not, there's gotta be a bolt still in bell housing somewhere, no?
  6. Feb 4, 2017 at 3:15 PM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    Mine was the same way. Finally used a come-a-long to separate. Had separation anxiety or something.
    TacomaJunkie8691 and ManBeast like this.
  7. Feb 4, 2017 at 3:37 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    You I hope have help ??
    I would not wish anyone to be doing this alone
    I have had to make a tool out of a chisel welded to a 20" piece of 3/4" pipe to tap things on both sides to get things started .
  8. Feb 4, 2017 at 3:40 PM
    ManBeast
    ManBeast Well Feared Member
    Zach
    Orange Park FL
    2015 DCLB:TOTALED-> 2014 4R TRAIL
    Loled at this, thanks.
  9. Feb 4, 2017 at 3:44 PM
    Xbeaus
    Beau
    I had help. It stayed on the trans jack. Just needed a little help. Crazy how stuck it was.
  10. Feb 4, 2017 at 3:49 PM
    Smellygreentaco
    Texas
    Stock
    Really appreciate the comments guys, and ideas.
    All bolt removed most assuredly. Has partially separated but won't come free. Might need to use come-along. Best idea I've seen so far.
    Can't get enough leverage with pry bar with tran-jack in the way.
    I'll give it a go a bit later on with more man power and come-along.
    Thanks a bunch everyone! Happy Saturday!
  11. Feb 4, 2017 at 3:50 PM
    Xbeaus
    Beau
    I think that culprit because that's how mine was is the pilot bearing.
  12. Feb 4, 2017 at 3:51 PM
    Xbeaus
    Beau
    Just be careful. I had pieces of 2x4 wedged around there in case it flung out to fast. Good luck!
  13. Feb 4, 2017 at 3:57 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    push in the clutch.
    Wait....only of the slave is still in place.
  14. Feb 4, 2017 at 5:30 PM
    TacomaJunkie8691
    TacomaJunkie8691 1999WineTacoma
    WA State
    1999 Wine Tacoma SR5 Exta-Cab 4wd V6
    Completely Stock except for Ranch 5000 Shocks and Struts.
    What kind of clutch kit are putting in it?
