First time in the snow with my Taco...Yikes!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mit122, Nov 26, 2013.
  1. Dec 9, 2013 at 9:29 AM
    #221
    ruCKYes
    ruCKYes Active Member
    Englewood/Castle Rock
    03 Tacoma TRD
    4" ProComp Susp. lift 17" Pro Comp Alloys 305/70 r17 Maxxis Bighorn TRD headers Flowmaster Exhaust
    My Simplest suggestion is always:
    Use 4wd for acceleration, control in turns & hillclimbing; & drive as if you have No Brakes :D
  2. Dec 9, 2013 at 11:13 AM
    #222
    Hungry
    Hungry Toy Truck Fan
    Barney
    Georgian Bay, Ontario
    Extang Freedom Trifold Tonneau Cover
    We in Georgian Bay are used to the squalls / lake effect snow. I've had 3 sets of tires between my 2007 4x4 Access cab long bed and now my 2010 DCSB. We get loads and loads of snow to the point where the school buses are cancelled half a dozen times a winter (can you say: lawsuits?) :D
    I've been happy with my Hercules (Korean or Zhinese?) Avalanche dedicated snow tires in 2 WD all of last winter. Hardly needed it to run in 4WD, ever.
    Then I sold those for a set of Cooper AT/3's and they are working well so far this winter. My son is getting ownership of this 2007 and my 2010 has a set of Wrangler Duratracs on them right now. It's been a week now with lots of snow and I'm impressed so far with the Duratracs in the snow. At least they are not as noisy as the dealer warned me. Then again, it's cold, the windows are rolled up, and I gotta heater in my truck and I'm off to the.... (you know the rest). :)
    I was watching the news and Weather last night and all of you 'Merican Taco bros are getting walloped with winter weather! Please stay safe out there! :D
    Hope this helps,
    Cheers,
    Barney
  3. Dec 9, 2013 at 12:15 PM
    #223
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Taco can handle it, except ABS trying to kill us, the rest is running perfect.
    Stupid ABS...
  4. Dec 9, 2013 at 12:24 PM
    #224
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    I just today drove to work in the snow for the first time with my '13 and the stock BFG A/T's which everyone got me all nervous about actually aren't that horrible. On my '04 the last tire I had on there was Cooper AT3's and they were great tires.
  5. Dec 9, 2013 at 9:18 PM
    #225
    mutilatedjak
    mutilatedjak n00b waffle
    WA
    11 DC SB TRD Sport 6spd
    BP-51s, Dakar leafs, ARB bumper, 4xinnovations rear HC, 3x trail camera, pure android, lightforce 170s, Dick Cepek 255 85s extreme terrain.
    Thanks! I normally do metal or electronica but the Cash was calling me heh.
  6. Dec 10, 2013 at 7:28 AM
    #226
    Phil5393
    Phil5393 Well-Known Member
    Phil
    Long Island, New York
    TRD Sport
    Its my first time with this truck in the snow how many 50 pound sand bags would be good to put in the bed and where is the best place to put them? Right over the rear axle?
    Thanks
  7. Dec 10, 2013 at 8:00 AM
    #227
    jethro
    Geoff
    Southern NH
    Probably anywhere from the rear axle back. Theoretically if you put all the weight at the tailgate you would be cantilevering more weight over the rear axle. When I used tube sand I would put one right over the axle next to each wheel well, and one at the very rear of the bed.
  8. Dec 10, 2013 at 8:26 AM
    #228
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Over the axle
  9. Dec 10, 2013 at 3:17 PM
    #229
    DenisSeattle
    DenisSeattle Well-Known Member
    TRD Off Road
    I thought the ABS in my '11 turns off in L4 but I checked and apparently that's with diff lock on. So apparently it can be switched.
    This is my first rig with ABS and after 2 years I'm still impressed with the truck's ability to stay straight while stuffing the brakes on compact snow. My previous 18+ vehicles required brake feathering and pumping that extend the stopping distance anyway. I'll take the ABS.
    That said, review your user manual "Fuse layout and amperage ratings" section. Without fuses "ABS NO. 1" or "ABS NO. 2" you risk that your anti-lock brakes may not operate as designed.
  10. Dec 10, 2013 at 3:22 PM
    #230
    OZ-T
    Peter North
    British Columbia
    ABS bypass mod
  11. Dec 10, 2013 at 3:26 PM
    #231
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Don't take out the bigger of the two fuses. Your brakes stop working completely. The ABS pump runs the power brakes, and without it there is enough vacuum to get one or two good test stops in, then nada. :eek:
    Like Oz-T said, there's a bypass mod somewhere if you search around some. I just unplugged all my wheel speed sensors myself, but I understand Automatic trans tacoma's use the signal for the wheel speed sensor for the Speedometer. Mine has a fifth sensor in the T-case for the speedo.
  12. Dec 10, 2013 at 4:39 PM
    #232
    peiscooter
    peiscooter Well-Known Member
    Prince Edward Island
    2021 TRD Sport
    4 bags, one in each corner of the bed.
  13. Dec 10, 2013 at 5:28 PM
    #233
    cheeseit
    cheeseit Well-Known Member
    Vancouver B.C.
    2005 SR5/TRD OR Tacoma
    3 inch toytec lift
    Not gonna lie I thought you guys were full of shit about the ABS being so awful but I drove for the first time in snow yesterday and it locked up coming out of driveway when I was barely moving and I tapped the brakes. I don't want to do the ABS kill mod so I guess I have to drive super careful in slick conditions. I'm glad I found that out coming out of my driveway and not at the highway going 80.
    Sure was fun doing donuts up at the mountain before and after snowboarding though.
  14. Dec 10, 2013 at 5:31 PM
    #234
    OZ-T
    Peter North
    British Columbia
    I really think that our wet snow has a lot to do with the ABS being so touchy
  15. Dec 10, 2013 at 5:43 PM
    #235
    cheeseit
    Vancouver B.C.
    3 inch toytec lift
    Probably the snow seems to be perpetual slushy here.
  16. Dec 10, 2013 at 5:44 PM
    #236
    OZ-T
    Peter North
    British Columbia
    Yep
  17. Dec 10, 2013 at 5:44 PM
    #237
    rescuetech53
    rescuetech53 Dispatcher 53
    Shadoe
    North East PA
    12 Tacoma Sport
    Awesome tire! I would say is has to be the tire. I live near Scranton pa and we've had snow for the past few days and haven't had a problem. I drove to Ithaca Saturday and didn't have a problem.
