First time off roading
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Starman1251, Oct 22, 2023.
  1. Oct 22, 2023 at 6:23 PM
    Starman1251
    Starman1251 [OP] Member
    2023 icecap Tacoma SR 4x4
    Took my 23’ Tacoma SR off roading for the first time today! It was definitely an experience, handled the loose sand going up hill really well and on 4H! Looking forward to doing more.
  2. Oct 22, 2023 at 6:28 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Awesome! These trucks are very capable, it's usually the driver holding it back. Stay in your comfort zone and keep going!
    And welcome to TW.
  3. Oct 22, 2023 at 6:28 PM
    Bishop84
    Bishop84 Well-Known Member
    Now you gotta buy some tires! Any photos?
    RIX TUX, Junkhead, shakerhood and 2 others like this.
  4. Oct 22, 2023 at 6:36 PM
    Starman1251
    I did not but I’ve been thinking of getting new tires though!
    Junkhead likes this.
  5. Oct 22, 2023 at 7:00 PM
    RicerRabbit
    RicerRabbit Well-Known Ricer
    '22 White TRD Off-Road DCSB Manual | '03 Lancer Evolution
    Itz JDM tyte, yo!
  6. Oct 22, 2023 at 7:30 PM
    Starman1251
    Will start doing so! Today was just a feeling out process
  7. Oct 22, 2023 at 7:51 PM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    Nice. I remember how impressed I was with the truck’s capabilities the first time I took it off road.
  8. Oct 22, 2023 at 8:44 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    I wanted new tires on my new 2021 - couldn't justify the cost - and big ole screw ( TWICE ) in the same tire ( SAME PLACE ) gave me
    reason to do it. Was surprised the OEM Firestones were down to like 5/32 after 2 years - mostly pavement riding, 15,000 miles rotated
    every 5k... so I bought some Wildpeaks - and really am happy with them. Put some on the wife's subaru a few months back after her
    OEM's hit 44k.... I do like them.
    Lots of choices out there, the name-brands and popular tires are all good.
  9. Oct 22, 2023 at 9:50 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Good stuff! Go wheel that stocker and see what it really needs,,,, or doesn’t. Just take it easy and have fun.
    71tattooguy and Starman1251[OP] like this.
  10. Oct 22, 2023 at 10:30 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    I use S-mode for 4Hi. S-mode limits top gear that can be used. Setting to 1 or 2 on a steep-winding-gravelly road can save using the brakes which can cause loss of control. Slowing down (like on deep snow) is safer. 4Lo is just 4Hi that limits top speed to about 18 MPH in S4.
    SR does not have Crawl Mode or Multi-Terrain Select, but play with S-mode for transmission-braking instead of wheel-braking.
  11. Oct 23, 2023 at 5:06 AM
    Starman1251
    Thanks for that! I’ve been wondering if using S-mode would help in any situation. To be completely truthful I’m really knew at this so any advise would help, I won’t usually be in gravel where I’m at but the tougher trailer will have steep hills with loose sand (live in a desert area) so I appreciate any recommendations!
  12. Oct 23, 2023 at 5:20 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Make sure you air down and have a way to air back up.
    21TacoTRDPRO and Starman1251[OP] like this.
  13. Oct 23, 2023 at 5:56 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    S-mode will help control speed on long descents. It won't do anything to help uphill or running trails.
    My general advice - have fun, go cautiously, do some googling and have some basic ideas on how to get unstuck. Nothing too advanced, and don't go out buying $50,000 worth of recovery gear, but just get the basic concepts down (deflate tires, shovel/pile material, know basic repairs). My rule of thumb is to get out and walk every obstacle I'm unsure about - if the water goes above my shin or if the mud sinks the sole of my shoe / halfway to ankle for sand, I don't try it. (Or at least, I don't try it alone.) My other rule is that if i feel momentum starting to shift away from forward motion and towards downward motion, I get off the throttle. It's easier to address a buried sidewall than to risk a buried axle. :cookiemonster: Every trail is a puzzle to visualize before the truck crosses it - what path do I have planned for each wheel, will the tires float over the surface or sink into it, will the wheels slide off my intended path, will the bits in between strike the undercarriage?
    Most of all, enjoy it. Go have fun.
  14. Oct 23, 2023 at 6:30 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Honestly the best way to keep speeds low and stay there with minimal braking is 4LO. My truck is manual so a little different, but in 4LO and 1st or 2nd gear it will just crawl around with no brake or throttle input. Same deal when I had my automatic 3rd gen. I don't offroad, but play around in the pastures around the house (with permission) to exercise the 4Wd system.
  15. Oct 23, 2023 at 6:43 AM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Stock tires are P-rated, so I wouldn't air them down too much. Probably no lower than 20 psi, unless you are beach driving, then maybe down to 15. The sidewalls aren't that tough. If you are getting decent traction without airing down, the only reason to air down is for ride comfort.
    Starman1251[OP] likes this.
  16. Oct 23, 2023 at 6:47 AM
    RichochetRabbit
    Air up/down. Dropping from 35 PSI to 20 PSI works wonder for the trail but kills tires onroad. I have Viair 88P godd quality, lower price) , which get smy 4 tires back to 35 PSI. Connects to battery instead of inside-truck DC outlet because of amps pulled. I keep a package of spare automotive fuses for the 88p with the compressor. Others will advise 300P or higher, but as long as you have something.
  17. Oct 23, 2023 at 7:41 AM
    paulisinataco
    paulisinataco Well-Known Member
    Utah
    2022 sr access cab 4x4
    Rock Lobster and Starman1251[OP] like this.
  18. Oct 23, 2023 at 8:15 AM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    I was out "off roading" one day in the desert. We were exploring a lesser used power line/gas line maintenance road. I have the Taco in 4x4 Low and I sweating the clearance of the larger rocks with only the stock Sport skid plate. I am telling my with how amazing my Taco is doing and incredible it is that we can get up these "climbs." No shit there I was when around the turn coming down one of those "climbs" was a 2WD Van. About a 1995ish Chevy van. I did pull over and give the van the road to safely continue their "off road" experience. Anyways, I never know what I am going to see out there in the desert.
  19. Oct 23, 2023 at 8:49 AM
    t2c
    t2c Well-Known Member
    I've had something similar take place on the way to a camp ground. After a 1 hour climb, my back was killing me. We finally get there and I see an early 2000s Honda Civic or Toyota Corolla parked there. I was mind blown to say the least.
  20. Oct 23, 2023 at 8:51 AM
    TRD-Troll
    TRD-Troll Smoked Orc 75% off
    NV
    2019 TRDOR DCSB AT
    I have seen 4 door sedans and mini vans in places in the NV desert that are shocking. They can make it but it definitely can end poorly for the car in terms of damage.
    Watching Matt’s Off-Road Recovery on YT shows how often people do it.
