First Time Posting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mikey_0048, Sep 29, 2021.
  1. Sep 29, 2021 at 3:09 PM
    Mikey_0048
    Mikey_0048 [OP] New Member
    Grey 2012 Tacoma Prerunner
    I have a 2012 Tocoma Prerunner with a 6 cylinder. I would a to purchase a scanner that will do take care of all scans and resets. Any suggestions.
  2. Sep 29, 2021 at 3:23 PM
    Brian_d
    Brian_d Well-Known Member
    Socal
    Welcome!
    Get a Bluetooth obd2 from Amazon, pair it with your phone, download the "torque" app and you can scan & clear dtc's with your phone
    eherlihy likes this.
  3. Sep 29, 2021 at 3:36 PM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    Welcome aboard:hattip:
    Scanguage. Doesn't need Bluetooth
  4. Oct 1, 2021 at 1:55 PM
    Mikey_0048
    Why not?
  5. Oct 1, 2021 at 6:16 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Because it plugs into the OBDII port.
    It’s a stand alone unit.
  6. Oct 1, 2021 at 6:39 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    There's lots of stuff out there depending on what you want it to do. If you want something that can just do engine codes and data a bluetooth adapter and phone app will probably be your cheapest option (<$50), if you want something that will do codes and data on all modules on the vehicle your probaly gona be in the $200-400 range, if you want something that will do functional tests and bi-directional controls probably $400+.
    TnShooter likes this.
  7. Oct 1, 2021 at 9:46 PM
    Waasheem
    Waasheem
    2007 xrunner
    Auto parts stores have theirs used to pull up codes. If you want to have your own the choices are endless. I’ve seen them cheap as 20, and high as near 10k. Of course the high end ones is what a good repair shop would have. I’ve heard good and bad things about the Bluetooth ones. I’ve got a snapon micro scan, $400, it’s really bluepoint, their budget line.
