first time seafoam user
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ajw1986, Sep 26, 2013.
  1. Sep 26, 2013 at 7:50 PM
    ajw1986
    ajw1986 [OP] Well-Known Member
    Andrew
    Pitt Meadows, B.C.
    06 Money Pit
    Does my tank have to be almost empty or can I use it with like an 1/8th or 1/4 tank?
  2. Sep 26, 2013 at 7:57 PM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    Yes, as long as you fill it back up, all the way. It works alot better through your vaccum system though
  3. Sep 26, 2013 at 10:13 PM
    kingofthecrate
    kingofthecrate Well-Known Member
    NELA
    2014 DCSB 4BYE IN YOUR MOUTH
    What are you trying to achieve with using seafoam?
    Putting it in the fuel tank will just "help" clean injectors.
    Putting it through the vacuum lines will "help" with carbon on the valves..
    using shell or chevron with techron will do both and its not snake oil
  4. Sep 27, 2013 at 2:23 AM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    I soaked an old crusty spark plug from my Chevy in sea foam for a week and did not notice any difference. I should have done a write up about it to save some people money.
  5. Sep 27, 2013 at 9:20 AM
    10splaya22
    10splaya22 Well-Known Member
    Drew
    Blacksburg, Va
    2012 TRD Sport 4x4 DCSB
    +1. I've never used it but many people have said it helps.
  6. Sep 27, 2013 at 9:36 AM
    CWG
    CWG Active Member
    Seattle?
    2013 DCLB Sport
    Truck Covers USA Hard Tonneau, DynoLock, OEM steps, TRD SE Anthracite wheels, Duratrac tires
    I don't think they claim to be a pure solvent. A better test would've been taking a pic of the crusty spark plug, put it back in the Chevy, then run seafoam in a vacuum line as directed. Then, you could see if it has any validity or not.
  7. Sep 28, 2013 at 2:48 PM
    ManMan
    ManMan Well-Known Member
    Seafoam is not the magic "tune-up in a can" the internet makes it to be. It is not going to clean your valves, it's not going to "fix" anything. It may help clean out injectors or carb passages if they aren't too bad (have successfully done this on a weedeater that sat too long)
