First time Stuck!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoDaTugBoat, Feb 19, 2011.
  1. Feb 19, 2011 at 8:04 AM
    TacoDaTugBoat
    TacoDaTugBoat [OP] Well-Known Member
    Goshen, Ct
    13 DCLB TRD Sport
    I was not expecting such a snowy winter. I had parked a trailer in a field at my grandmothers house. That trailer is now trapped behind a snowbank. I thought I could run it. Well you can see the results...
    So I got totally stuck on the frame. I was able to put it in 4lo leave it in gear jump out and the tires were still spinning. They were probably still 6 inches from solid ground. Had to have my buddy pull me out with his F-350 plow rig. Took a couple good yanks. Guess it has to happen sooner or later.
  2. Feb 19, 2011 at 8:07 AM
    0BlackTaco6
    0BlackTaco6 Ive got tiger blood
    New Hampshire
    06 BSP DC SR5 4x4 6 speed
    Color matched and satoshi grille, hella 500ff behind, bhlm, sockmonkey bedsides, 17" sports 265/70 grabber at2's.
  3. Feb 19, 2011 at 8:11 AM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    This is always my biggest fear which keeps me from trying risky things. If it's fresh powder, you can drive in it deeper than that as long as you don't stop (did that yesterday as we've gotten 3 feet out of this storm since Wed morning, but they finally plowed the roads last night). If the snow's been sitting and has already compacted, or has been plowed into a pile, then you gotta be real careful about centering up on the frame. I turned around a couple of years ago on one of our closed, paved forest roads when I saw a patch was too deep...and proceeded to watch two families in an Excursion attempt it. That was real dumb on their part as the Fords have very, very little clearance (I think it has less than 6 inches). Just like you, all 4 wheels were in the air. Had to wait for two full-size SUV/Trucks to come along with winches where they could reach from the dry pavement. Those Excursions are heavy.
  4. Feb 19, 2011 at 8:11 AM
    Junebug McQuinn
    Junebug McQuinn Well-Known Member
    Wylie, TX
    2011 TRD Off Road Pre-Runner
  5. Feb 19, 2011 at 10:24 AM
    DueNorth
    DueNorth Well-Known Member
    Southern Ontario, Canada
    2014 BSP TRD Sport DCSB 6sp
    Well at least you didn't have to dig yourself out, like I've done a few times this year already.
  6. Feb 19, 2011 at 11:52 AM
    HuntnTruk
    HuntnTruk Tacohead
    Kevin
    New York-not the City
    Indigo SR5 4x4
    I dont even see how you got to where you are. There are no visible tracks. Did you let it sit there overnight or something?
    ETA: I think I can see where you came in from
    Locker and atrac help a lot I have found.
    This was not fluffy powder either.
  7. Feb 19, 2011 at 3:56 PM
    TacoDaTugBoat
    Goshen, Ct
    13 DCLB TRD Sport
    I was getting a running start down the road in 4hi and veered off, felt like I hit a big pillow. I was trying to shoot through where the bank was looking lower. Neither a locker or ATRAC would have gotten me out of this. Using TRAC I had all 4 spinning at different times. The whole wheel wells were full.
